Results 1 to 2 of 2
    Jul 27 2016
    Houston,TX
    Clutch dropped to floor and wont return -- b8.5 s4
    Bought the car a couple months ago with 18,xxx miles. PPI indicated that the pads had tons of life left (green)
    Couple days ago my BRAKE warning light comes on and i figured it was a sensor unplugged or something. Fast forward to that same night, I'm leaving the house and feel the pressure of the clutch is way off. Needless to say the pedal dropped to the floor and i could no longer engage a gear.
    Im thinking now that my BRAKE warning light may have come on because of a leak in either the master or slave cylinder? as the fluid level decreased my clutch slowly stopped engaging?
    anyone dealt with this issue? clutch showed ZERO signs of giving way, no slipping or anything.
    Car is EPL Stage 1 for the last 5k miles
    thanks guys
    Established Member Two Rings bwizard's Avatar
    Oct 10 2016
    Colorado Springs, Colorado
    Yes a leak probably slave you can more than likely add fluid and bleed pump it back up and find the leak.
    Sent from my HTC6535LVW using Audizine mobile app
    weekly driver 02 S4 2.7t auto stock
    Wife's 04 A4 1.8t auto stock
    Daughter's 97 A4 AEB Bored to 2.0t K04 sport cams
    My role family tech.
