Results 1 to 9 of 9
    Jan 29 2014
    awd transmission into a fwd car
    Hi guys I had a question and hopefully someone here knows the answer. I have a fwd Passat with a 2.7t swap into it. I was looking into putting a b5 s4 transmission into it because of the lsd in the transmission. I know the tranny bolts up directly but what would I do about the rear output shaft? Will it just work or do I have to change something. thanks
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Las Vegas
    I would say keep the stock trans. There's someone here who's made the O1E FWD though.
    Jan 29 2014
    my trans isn't lsd. so I'm getting a huge amount of wheel spin. didn't want to spend 1800 of a aftermarket diff
    Feb 06 2012
    Las Vegas
    Quote Originally Posted by SlammedB5.5 View Post
    Post pics and vids. I love the B5.5's. It's my favorite car.
    Jan 29 2014
    Quote Originally Posted by aysix View Post
    https://www.instagram.com/p/spnwArFh...n-by=juiced416
    https://www.instagram.com/p/svQ5Ldlh...n-by=juiced416
    https://www.instagram.com/p/6fYPJRlh...n-by=juiced416
    not sure how to post pics here. but Instagram user is Juiced416
    Dec 10 2013
    Borden, Ontario, Canada
    The 01E doesn't have an LSD, nor will it work without welding the center diff
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    I tried this before but it didn't work. Did I do it right?
    May 16 2008
    South Texas
    Do it if you want all your power to go to the open rear output flange.
    Veteran Member Four Rings slowSfaux's Avatar
    Apr 26 2015
    Phoenix, AZ
    Lol zba. That's all wrong. Welding only the pinion to the ring gear isn't enough. You have to weld all those roller bearings to their cages as well.
