Results 1 to 40 of 43
    Stage 2 Banner Advertiser Three Rings
    Oct 11 2016
    Montreal, QC
    Unitronic TCU Upgrade for DL501® (DSG®) - Now Available!
    Unitronic is pleased to present its Performance Software for the DL501® (S-tronic®) DSG®*. Unitronic's Performance Software Upgrade for the Transmission Control Unit (TCU) is flashable via the OBD-2 port of the vehicle
    and is calibrated alongside its already released ECU Performance Software to ensure a harmonious operation.
    Unitronic Performance Software for the TCU is also UniConnect+ compatible. Learn more about UniConnect+ HERE!
    What you may experience with your stock DSG software
    As with previous generations and other variants of the DSG, ECU Performance Software and engine hardware upgrades resulted in shortcomings in the stock control logic; gear change setpoints, gear shift speeds, limitations in allowed torque through the gearbox, engine rev limitations, and much more; all stemming from the increase in engine output. In Drive-mode, drivers often experience premature upshifts as a result of the stock calibration being aligned with the factory engine output. In Sport-mode, part throttle acceleration held the gears too long, causing an awkward driving experience. In Drive-mode and/or Sport-mode, shift points are often misaligned with peak engine output, costing drivers with imperfect acceleration. And Manual-mode is not a true “manual” mode, as gear changes still occur at redline and engagement of the kickdown button still result in unwanted downshifts.
    Why choosing Unitronic Performance Software for your DSG
    Utilizing its extensive knowledge of the TCU from its offerings for previous generations and other variants of the direct-shift gearbox, that developed a strong reputation in the market, Unitronic's Performance Software for the DL501 DSG will deliver a complete night and day driving experience. With two Stages, Stage 1 & 2, Unitronic's Performance Software for the DL501 DSG is precisely re-calibrated to ensure shift points in Drive-mode and Sport-mode are aligned with increased output and powerband of a Unitronic tuned engine to ensure maximum acceleration, deliver lightning fast gear changes to gain valuable time during acceleration, and raises TCU torque limitations to ensure the TCU does not intervene during acceleration. Unitronic's Performance Software for the DL501 DSG will allow drivers to feel more connected to the vehicle and will experience a total transformation in the driving experience.
    Take advantage of our Software Value Packages
    Already a Unitronic flashed customer? Receive an instant 100$ Rebate on the Unitronic Performance Software for DSG.
    Combine purchases of Unitronic Performance Software for ECU and TCU and receive a 150$ Rebate.
    FEATURES
    Engineered with Strict Industry Standards
    With over 10 years of experience with Bosch and Siemens engine management systems and calibrations, Unitronic is able to utilize its expertise, industry leading tools, and equipment to ensure an optimal calibration; delivering maximum performance, while maintaining complete OEM-like reliability and drivability.
    Extensively Tested Under Various Driving Conditions
    Development begins using its in-house engine dyno housed in an environmentally controlled cell; closely monitoring a plethora of operational data, utilizing industry leading calibration tools and resources. Additional validation and results comparison are completed using its in-house Maha Chassis dyno as a second step of product development. Beta calibrations are then tested in race and street scenarios, using multiple cars throughout the world under various driving conditions. This engine calibration strategy ensures Unitronic Performance Software delivers maximum performance, OEM-like drivability and reliability anywhere in the world. Unitronic Performance Software is only released to its Clients once development is thoroughly completed in accordance to Unitronic’s strict standards.
    Optimized Responsiveness and Drivability
    Cruising upshifts set point are improved for maximum responsiveness when you require power quickly.
    Optimized "D" Mode for a Comfortable Driving Experience
    Smoother and predictable shifting to ensure a pleasant ride for your daily commute.
    Optimized "S" Mode for Maximum Acceleration
    Sport mode features lightning quick gear changing and precisely calibrated shifting points to achieve the fastest acceleration possible when combined with your Unitronic ECU Performance Software.
    Optimized "M" Mode for Maximum Acceleration and Kickdowns Removed
    Fastest shift possible; up to 3 times faster compared to OEM calibration.
    Optimized TCU Performance Software Stages
    Unitronic's Stage 1 TCU Performance Software shift points are optimized to give you the best performance possible out of your OEM software or your Unitronic Stage 1 ECU Performance Software.
    Unitronic's Stage 2 TCU Performance Software shifts points are optimized for your Unitronic Stage 1+ and up ECU Performance Software.
    Gear Display Enabled in D and S Mode
    Like in M mode, gear display is enabled in D and S mode.
    Improved Launch Control
    Optimized set points to maximize accelerations and improve 60ft time. Launch control set to 4000 RPM in the B8/B8.5 S4 & S5.
    Increase Clutch Pressure for Higher Torque Output
    Increased clutch pressure to maximized friction force. This results in higher torque capacity without clutch slipping.
    Increased Torque Limiter
    Ensure TCU does not intervene during acceleration thus reducing engine power output.
    Rev Limiter Increased
    APPLICATIONS*
    VISIT OUR PRODUCT PAGES FOR PRICING
    B8 Audi® S4®
    B8.5 Audi® S4®
    B8 Audi® S5®
    B8.5 Audi® S5®
    C7 Audi® S6®
    C7.5 Audi® S6®
    C7 Audi® S7®
    C7.5 Audi® S7®
    For more information, be sure to contact your local Authorized Unitronic Dealer to get yours now!
    *Subject to TCU Box Code availability.
    Unitronic -- Performance Software & Hardware for VW® / Audi® / Porsche®
    Web: www.getunitronic.com
    Tel: 1.866.341.2447
    Follow us on: Facebook / Instagram / Youtube Please note that this account do not accept PMs. For private questions, please email [email protected].
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    Good stuff! Saxon get on it lol
    just might make use of my uni connect after all
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Stage 2 Banner Advertiser Four Rings John@Unitronic's Avatar
    Apr 03 2008
    MK3 TTRS, B9 RS5
    Laval, QC
    Quote Originally Posted by DGVR6 View Post
    Oh he's on it! Looking forward to hearing from you soon, too!
    UNITRONIC — Performance Software & Hardware for your VW® /Audi® / Porsche®
    Web: GetUNITRONIC.com | Tel: (866) 341-2447
    Follow us on: Facebook | Instagram | Twitter
    Veteran Member Four Rings MadAboutCars's Avatar
    Aug 27 2015
    MY18 Audi RS6 P, MY18 Audi SQ5,MY16 Audi S6 (sold), MY12 Audi Q7 4.2L TDI S-line (sold)
    New Zealand
    John, how will I know when you have a my TCU version available. I was the person in New Zealand that you offered to let me try the TCU upgrade, but you didn't have my TCU version, and the Unitronic NZ dealer (Hennie) was a total let down when it came to getting my TCU firmware read from my car, so it never happened.
    2018 Audi RS6 Performance - Floret Silver, Titanium styling package, 21" titanium 5 V spoke wheels, Dunlop SP Sport Maxx GT 285/30/21, Black sports seats, Carbon inlays, Sports diff, Sport exhaust, Matrix LED headlights, 360 camera, Head up display, Active lane/side assist with adaptive cruise control, Park assist, Privacy glass, Electric tailgate with foot open
    Mods: Dura-Seal exterior/interior, Audi Sport door lights
    Apr 03 2008
    MK3 TTRS, B9 RS5
    Laval, QC
    Quote Originally Posted by MadAboutCars View Post
    Yes, I recall speaking with you. I'm really sorry to hear that it never worked out for you. Shoot me an email and I'll setup a notification for you, please.
    Sep 10 2015
    VA
    John a couple of question on my S6 c7.5 Are the amount of launches available increased and will it reduce my launch RPM so I can stop spinning all 4 tires when I launch.
    Apr 03 2008
    MK3 TTRS, B9 RS5
    Laval, QC
    Quote Originally Posted by Barritia View Post
    Yes, the launch limit is addressed. LC setpoint is 4800RPM, but traction will vary greatly on the surface prep, tires, etc., so if you would like an adjustment, please email me with your request.
    Jan 27 2016
    '14 QX80, '12 FJ Cruiser (Heavily modded)
    Denver
    If I buy the ECU 1+ and the TCU Stage 2, do I also get included access to ECU 1 and TCU 1?
    Current:
    '13 S7 (Innovation, B&O, LED's, AWE Exhaust, RS-Grille) -- '12 FJ Cruiser (Heavily modded) -- '14 QX80
    Gone but not forgotten:
    2014 Porsche Carrera S -- 2014 Toyota 4Runner -- 2002 Acura TL-S (My first 'luxury' car)
    Jan 27 2016
    Denver
    Also ... your dealers aren't ready to sell this apparently. The one I went to didn't have the TCU option or the $150 in savings. How do we take advantage? I have a credit card in my hand ready to be abused. :)
    Current:
    Sep 10 2015
    VA
    Thanks John I will give Rachael a call tomorrow. Is the $100 discount off the $850 price making it $750 if I already have stage 1+ and 2 from you guys already?
    Apr 03 2008
    MK3 TTRS, B9 RS5
    Laval, QC
    Quote Originally Posted by jfeger View Post
    We just released this today, so if your visit to one of our Authorized Dealer was prior to this afternoon, I don't think the combo discount would have been offered, since the DL501 Software hadn't been released yet. Send me an email to john [at] unitronic [dot] ca and I'll help you get everything you're looking for!
    You can access all of the stages up to the stage that you've purchased after the initial flash, yes. Please keep in mind that you can use Stage 1 TCU with Stage 1+ or higher ECU, though.
    Yes, the combo/existing client discount is applied from the retail price.
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    can't wait
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Aug 27 2015
    New Zealand
    Quote Originally Posted by John@Unitronic View Post
    Thanks. With the C7.5 S6 in manual mode, has the upshifting at rpm limit been removed in all gears?
    Apr 03 2008
    MK3 TTRS, B9 RS5
    Laval, QC
    No, it's maintained.
    Sep 10 2015
    VA
    John do your ECU tunes and TCU tunes run in UK models?
    Apr 03 2008
    MK3 TTRS, B9 RS5
    Laval, QC
    Yes, we can provide Performance Software for the ECU/TCU anywhere in the world. As with any, it is subject to tuned file availability for the E/TCU, but once we have the E/TCU details, I can confirm. If it's not currently available, it's usually a few days/weeks for us to compile tuned files for that particular box code.
    Aug 27 2015
    New Zealand
    That's disappointing.
    So what about D mode. You say it's "Smoother and predictable shifting". Does that mean it's any sportier? Does 3rd downshift to 2nd sooner? This to me is the worst thing about D mode. When you come out of a corner, unless you almost come to a stop it's still in 3rd and has a big delay before it gets going, even with the Untronic stage 1 tune.
    Senior Member Two Rings bucknutt76's Avatar
    May 28 2015
    Valencia, CA
    Has anyone actually installed this? Did it make a big difference with the performance tune? I currently have the performance tune and want to know if the tcu tune is worth it.
    2016 S6 Premium Plus
    Moonlight Blue
    Lunar Silver Diamond Stich Seats
    Layered Aluminum Inlays
    Drivers Assist
    S6 Sports Package
    Bose
    Sep 05 2015
    Nashville
    I ordered a few days ago. Still waiting for it to be setup. Guess my box code was not available yet. I had my ECU tune in a day. I will post once I get it installed.
    Sep 10 2015
    VA
    Same here they didn't have my box code. Was meant to have it but end of this week so will let you know later if I do.
    Apr 03 2008
    MK3 TTRS, B9 RS5
    Laval, QC
    Quote Originally Posted by Phi399 View Post
    We're working to get file requests resolved as quickly as possible. Thank you for your patience and understanding! If you have any specific questions or concerns, please do not hesitate to email me; john [at] unitronic [dot] ca.
    Sep 05 2015
    Nashville
    No worries. Being a new product and ordering quickly. I was expecting a delay. Looking forward to getting soon. I have only have great things to say about the ECU tune and the service you guys provide.
    Sep 10 2015
    VA
    John any update on the ETA of the tune. Not heard anything from Racheal yet.
    Oct 16 2012
    pa
    i know the last time i had talked with him he was hoping it was very soon. He has been working around the clock trying to keep up with the demand.
    i can't wait :)
    Sep 10 2015
    VA
    Any updates?
    Apr 03 2008
    MK3 TTRS, B9 RS5
    Laval, QC
    Any updates?
    We're wrapping up any outstanding requests this week; if you haven't already gotten news, thank you for your patience and expect some communication on it this week.
    Sep 10 2015
    VA
    Thanks John that's great to hear. Will give racheal a call tomorrow.
    Apr 03 2008
    MK3 TTRS, B9 RS5
    Laval, QC
    Better yet; shoot me an email and I'll reply once your file is online. If you ever would like an update, feel free to email me directly. You have my email.
    Dec 04 2016
    Ranson WV
    Any chance that the stage 2 DSG will be available for a 2017 C7.5 S6 anytime soon?
    Apr 03 2008
    MK3 TTRS, B9 RS5
    Laval, QC
    Quote Originally Posted by -Eric- View Post
    Please send an email to tech [at] getunitronic [dot] com with your TCU ID and Revision Number.
    Dec 04 2016
    Ranson WV
    OK Thanks
    Sep 10 2015
    VA
    John any update on my box code yet?
    Feb 25 2014
    Texas
    Holy crap they still haven't finished your tune? Saw you asking in November..
    Mickey (AKA: AudiS4B8)
    Instagram: ze_nardo6
    10.65 @ 129mph
    Sep 10 2015
    VA
    Yeah it's been a while. They were having some issues with my box code and they wanted to make sure everything was 100% correct with my specific tune before releasing it to public.
    Feb 25 2014
    Texas
    John, does Unitronic remove the speed limiter in your software?
    10.65 @ 129mph
    Apr 03 2008
    MK3 TTRS, B9 RS5
    Laval, QC
    Received your email; thanks for your patience. There's been progress, but nothing to share at the moment. Shouldn't be much longer!
    It's a different TCU Box, so as usual, we ensure that our Performance Software is ready for our Clients to thoroughly enjoy.
    Quote Originally Posted by AudiS4B8 View Post
    Which vehicle?
    Sep 10 2015
    VA
    Which vehicle?
    Dec 04 2016
    Ranson WV
    +1
    The thing that I like about Unitronic is that they work on something until it is truly ready for primetime and then release it. Some tuners would just do the job halfway, and then release it to their unsuspecting clients who would then need to come back to the dealer several times to get the unfinished product corrected. Not good. My stage 1+ has been super stable and smooth, it feels like you would expect it to if this was simply a higher performing sub-model direct from Audi. Not to mention that Unitronic's performance is very comparable with anyone else in the tuning game. They are all pretty close on performance. But, Unitronic tunes works correctly first time everytime. I am looking forward to the DSG stage 2 tune for my 2017 S6. I'm sure it's going to be awesome.
    Sep 10 2015
    VA
    +1
    Yeah i fully agree. Rather have a working tuned thats slow to be released than a bad tune thats rushed out.
    Aug 27 2015
    New Zealand
    Hey, Barritia. Must be over a year now. Did you ever get your Unitronic TCU tune.
