Results 1 to 2 of 2
    Stage 2 Banner Advertiser Three Rings
    Oct 11 2016
    Montreal, QC
    Unitronic TCU Upgrade for DL501® (DSG®) - Now Available!
    Unitronic is pleased to present its Performance Software for the DL501® (S-tronic®) DSG®*. Unitronic's Performance Software Upgrade for the Transmission Control Unit (TCU) is flashable via the OBD-2 port of the vehicle
    and is calibrated alongside its already released ECU Performance Software to ensure a harmonious operation.
    Unitronic Performance Software for the TCU is also UniConnect+ compatible. Learn more about UniConnect+ HERE!
    What you may experience with your stock DSG software
    As with previous generations and other variants of the DSG, ECU Performance Software and engine hardware upgrades resulted in shortcomings in the stock control logic; gear change setpoints, gear shift speeds, limitations in allowed torque through the gearbox, engine rev limitations, and much more; all stemming from the increase in engine output. In Drive-mode, drivers often experience premature upshifts as a result of the stock calibration being aligned with the factory engine output. In Sport-mode, part throttle acceleration held the gears too long, causing an awkward driving experience. In Drive-mode and/or Sport-mode, shift points are often misaligned with peak engine output, costing drivers with imperfect acceleration. And Manual-mode is not a true “manual” mode, as gear changes still occur at redline and engagement of the kickdown button still result in unwanted downshifts.
    Why choosing Unitronic Performance Software for your DSG
    Utilizing its extensive knowledge of the TCU from its offerings for previous generations and other variants of the direct-shift gearbox, that developed a strong reputation in the market, Unitronic's Performance Software for the DL501 DSG will deliver a complete night and day driving experience. With two Stages, Stage 1 & 2, Unitronic's Performance Software for the DL501 DSG is precisely re-calibrated to ensure shift points in Drive-mode and Sport-mode are aligned with increased output and powerband of a Unitronic tuned engine to ensure maximum acceleration, deliver lightning fast gear changes to gain valuable time during acceleration, and raises TCU torque limitations to ensure the TCU does not intervene during acceleration. Unitronic's Performance Software for the DL501 DSG will allow drivers to feel more connected to the vehicle and will experience a total transformation in the driving experience.
    Take advantage of our Software Value Packages
    Already a Unitronic flashed customer? Receive an instant 100$ Rebate on the Unitronic Performance Software for DSG.
    Combine purchases of Unitronic Performance Software for ECU and TCU and receive a 150$ Rebate.
    FEATURES
    Engineered with Strict Industry Standards
    With over 10 years of experience with Bosch and Siemens engine management systems and calibrations, Unitronic is able to utilize its expertise, industry leading tools, and equipment to ensure an optimal calibration; delivering maximum performance, while maintaining complete OEM-like reliability and drivability.
    Extensively Tested Under Various Driving Conditions
    Development begins using its in-house engine dyno housed in an environmentally controlled cell; closely monitoring a plethora of operational data, utilizing industry leading calibration tools and resources. Additional validation and results comparison are completed using its in-house Maha Chassis dyno as a second step of product development. Beta calibrations are then tested in race and street scenarios, using multiple cars throughout the world under various driving conditions. This engine calibration strategy ensures Unitronic Performance Software delivers maximum performance, OEM-like drivability and reliability anywhere in the world. Unitronic Performance Software is only released to its Clients once development is thoroughly completed in accordance to Unitronic’s strict standards.
    Optimized Responsiveness and Drivability
    Cruising upshifts set point are improved for maximum responsiveness when you require power quickly.
    Optimized "D" Mode for a Comfortable Driving Experience
    Smoother and predictable shifting to ensure a pleasant ride for your daily commute.
    Optimized "S" Mode for Maximum Acceleration
    Sport mode features lightning quick gear changing and precisely calibrated shifting points to achieve the fastest acceleration possible when combined with your Unitronic ECU Performance Software.
    Optimized "M" Mode for Maximum Acceleration and Kickdowns Removed
    Fastest shift possible; up to 3 times faster compared to OEM calibration.
    Optimized TCU Performance Software Stages
    Unitronic's Stage 1 TCU Performance Software shift points are optimized to give you the best performance possible out of your OEM software or your Unitronic Stage 1 ECU Performance Software.
    Unitronic's Stage 2 TCU Performance Software shifts points are optimized for your Unitronic Stage 1+ and up ECU Performance Software.
    Gear Display Enabled in D and S Mode
    Like in M mode, gear display is enabled in D and S mode.
    Improved Launch Control
    Optimized set points to maximize accelerations and improve 60ft time. Launch control set to 4000 RPM in the B8/B8.5 S4 & S5.
    Increase Clutch Pressure for Higher Torque Output
    Increased clutch pressure to maximized friction force. This results in higher torque capacity without clutch slipping.
    Increased Torque Limiter
    Ensure TCU does not intervene during acceleration thus reducing engine power output.
    Rev Limiter Increased
    APPLICATIONS*
    VISIT OUR PRODUCT PAGES FOR PRICING
    B8 Audi® S4®
    B8.5 Audi® S4®
    B8 Audi® S5®
    B8.5 Audi® S5®
    C7 Audi® S6®
    C7.5 Audi® S6®
    C7 Audi® S7®
    C7.5 Audi® S7®
    For more information, be sure to contact your local Authorized Unitronic Dealer to get yours now!
    *Subject to TCU Box Code availability.
    Unitronic -- Performance Software & Hardware for VW® / Audi® / Porsche®
    Web: www.getunitronic.com
    Tel: 1.866.341.2447
    Follow us on: Facebook / Instagram / Youtube Please note that this account do not accept PMs. For private questions, please email [email protected].
    Senior Member Two Rings Nixon_S4's Avatar
    Mar 27 2013
    BMW X1 2016
    Montreal
    Great news. However, can you confirm if the TCU tune allows / enables launch control on 2010 models?
    H&R Sport Springs | APR Carbonio intake | AWE Touring | 034Motorsport Brace | Stoptech ST60 | Chipwerke Pro | AvantGarde M510
