Results 1 to 15 of 15
    Jul 21 2004
    South Florida
    Unitronic DL501 DSG TCU software....
    I apologize if this is a repost but I just received an email from Unitronic (I subscribe to most tuners websites for news) and it gave this link to their new DL501 TCU programming...
    https://www.getunitronic.com/news/Un...rade-for-DL501
    Unitronic is pleased to present its Performance Software for the DL501® (S-tronic®) DSG®*. Unitronic's Performance Software Upgrade for the Transmission Control Unit (TCU) is flashable via the OBD-2 port of the vehicle and is calibrated alongside its already released ECU Performance Software to ensure a harmonious operation. Unitronic Performance Software for the TCU is also UniConnect+ compatible.
    What you may experience with your stock DSG software
    As with previous generations and other variants of the DSG, ECU Performance Software and engine hardware upgrades resulted in shortcomings in the stock control logic; gear change setpoints, gear shift speeds, limitations in allowed torque through the gearbox, engine rev limitations, and much more; all stemming from the increase in engine output. In Drive-mode, drivers often experience premature upshifts as a result of the stock calibration being aligned with the factory engine output. In Sport-mode, part throttle acceleration held the gears too long, causing an awkward driving experience. In Drive-mode and/or Sport-mode, shift points are often misaligned with peak engine output, costing drivers with imperfect acceleration. And Manual-mode is not a true “manual” mode, as gear changes still occur at redline and engagement of the kickdown button still result in unwanted downshifts.
    Why choosing Unitronic Performance Software for your DSG
    Utilizing its extensive knowledge of the TCU from its offerings for previous generations and other variants of the direct-shift gearbox, that developed a strong reputation in the market, Unitronic's Performance Software for the DL501 DSG will deliver a complete night and day driving experience. With two Stages, Stage 1 & 2, Unitronic's Performance Software for the DL501 DSG is precisely re-calibrated to ensure shift points in Drive-mode and Sport-mode are aligned with increased output and powerband of a Unitronic tuned engine to ensure maximum acceleration, deliver lightning fast gear changes to gain valuable time during acceleration, and raises TCU torque limitations to ensure the TCU does not intervene during acceleration. Unitronic's Performance Software for the DL501 DSG will allow drivers to feel more connected to the vehicle and will experience a total transformation in the driving experience.
    Take advantage of our Software Value Packages
    Already a Unitronic flashed customer? Receive an instant 100$ Rebate on the Unitronic Performance Software for DSG.
    Combine purchases of Unitronic Performance Software for ECU and TCU and receive a 150$ Rebate.
    FEATURES
    Engineered with Strict Industry Standards
    With over 10 years of experience with Bosch and Siemens engine management systems and calibrations, Unitronic is able to utilize its expertise, industry leading tools, and equipment to ensure an optimal calibration; delivering maximum performance, while maintaining complete OEM-like reliability and drivability.
    Extensively Tested Under Various Driving Conditions
    Development begins using its in-house engine dyno housed in an environmentally controlled cell; closely monitoring a plethora of operational data, utilizing industry leading calibration tools and resources. Additional validation and results comparison are completed using its in-house Maha Chassis dyno as a second step of product development. Beta calibrations are then tested in race and street scenarios, using multiple cars throughout the world under various driving conditions. This engine calibration strategy ensures Unitronic Performance Software delivers maximum performance, OEM-like drivability and reliability anywhere in the world. Unitronic Performance Software is only released to its Clients once development is thoroughly completed in accordance to Unitronic’s strict standards.
    Optimized Responsiveness and Drivability
    Cruising upshifts set point are improved for maximum responsiveness when you require power quickly.
    Optimized "D" Mode for a Comfortable Driving Experience
    Smoother and predictable shifting to ensure a pleasant ride for your daily commute.
    Optimized "S" Mode for Maximum Acceleration
    Sport mode features lightning quick gear changing and precisely calibrated shifting points to achieve the fastest acceleration possible when combined with your Unitronic ECU Performance Software.
    Optimized "M" Mode for Maximum Acceleration and Kickdowns Removed
    Fastest shift possible; up to 3 times faster compared to OEM calibration.
    Optimized TCU Performance Software Stages
    Unitronic's Stage 1 TCU Performance Software shift points are optimized to give you the best performance possible out of your OEM software or your Unitronic Stage 1 ECU Performance Software.
    Unitronic's Stage 2 TCU Performance Software shifts points are optimized for your Unitronic Stage 1+ and up ECU Performance Software.
    Gear Display Enabled in D and S Mode
    Like in M mode, gear display is enabled in D and S mode.
    Improved Launch Control
    Optimized set points to maximize accelerations and improve 60ft time. Launch control set to 4000 RPM in the B8/B8.5 S4 & S5.
    Rev Limiter Increased
    Increase Clutch Pressure for Higher Torque Output
    Increased clutch pressure to maximized friction force. This results in higher torque capacity without clutch slipping.
    Increased Torque Limiter
    Ensure TCU does not intervene during acceleration thus reducing engine power output.
    APPLICATIONS*
    VISIT OUR PRODUCT PAGES FOR PRICING
    B8 Audi® S4®
    B8.5 Audi® S4®
    B8 Audi® S5®
    B8.5 Audi® S5®
    C7 Audi® S6®
    C7.5 Audi® S6®
    C7 Audi® S7®
    C7.5 Audi® S7®
    Mike
    2018 Audi S5
    Gone-
    Veteran Member Four Rings XxSullyxX123's Avatar
    Mar 04 2015
    2020 Jeep Unlimited Wrangler Rubicon Recon, 2023 Honda Pilot Elite
    Somers, NY, USA
    Looks like you beat Uni to the punch with a new thread by 10 minutes!
    2016 S4 P+ | Mythos Black | DSG | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | B&O | Carbon Inlays | Supercharged Badges ||| - SOLD
    2015 S4 P+ | Monsoon Grey | 6MT | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | Supercharged Badges | AudiGuard ||| - SOLD
    Jul 21 2004
    South Florida
    Lol, you heard it here first folks :) Good for them though. I need to buy my old car back now.
    2018 Audi S5
    Gone-
    Sep 27 2008
    Phoenix
    How does this compare to the TCU tunes that other vendors offer?
    Established Member Two Rings Garro's Avatar
    Sep 18 2016
    Round Lake IL
    I tried to purchase it directly from Unitronic Yesterday, Guy who answered took all my credit card information and 24 hours later still no charge on my card. Personally I think they themselves are overwhelmed by the release. If you really want it you may have to wait or get directly from a dealer who will charge you extra for the installation time.
    Dec 07 2014
    Mn
    Quote Originally Posted by Garro View Post
    Didn't they say 24-48 hours to process everything and get it on your account? I've been running it for a few weeks now and feel it's a great compliment to stage 2.
    Sent from my LG-H901 using Tapatalk
    2014 S4 DSG///Unitronic Stage 2+.
    Feb 22 2016
    Chicago, IL/USA
    I purchased through Unitronic directly the second I saw it was available..still nothing though. Since it's already the weekend, probably won't see it until Monday I assume.
    Sep 18 2016
    Round Lake IL
    Be happy! Seems you have a special hookup.
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    I think 48 business hours closed on Saturday. I'm waiting, I flashed to stock for inspection today and will wait till Monday afternoon until I start to get concerned. The hard part is driving to work with stock tune no good, been driving today with the gutless stock and I miss the tune. It reminded me of o contractor that went to lunch with me that drove a S5 and was impressed with the tune.
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Sep 18 2016
    Round Lake IL
    Just a reminder that after flashing the TCU you must re flash the ECU also I was told this more than once during the purchase but just like you I am playing the waiting 48 Hours game so I am thinking by Wednesday we should be good.
    Sep 18 2016
    Round Lake IL
    Got an email from Unitronic requestin TCU ID and Revision number now awaiting instructions on how to retrieve it via the Uniconnect Software because I
    don't have VAG-COM or VCDS. The wait continues.........
    Stage 2 Banner Advertiser Four Rings John@Unitronic's Avatar
    Apr 03 2008
    MK3 TTRS, B9 RS5
    Laval, QC
    Thanks for the interest, everyone! We've had great feedback from our Clients since the launch! For those adding our TCU Performance Software with UniConnect+, we've communicated with everyone by email and/or phone to retrieve the necessary information to add the software license to your account. If, by chance, we don't have tuned files already compiled and on our server for your TCU ID and Rev#, we're working to get them online and will be in touch with you once they're ready to go. As always, if anyone has any questions, please feel free to email me at john [at] unitronic [dot] ca.
    UNITRONIC — Performance Software & Hardware for your VW® /Audi® / Porsche®
    Web: GetUNITRONIC.com | Tel: (866) 341-2447
    Follow us on: Facebook | Instagram | Twitter
    Sep 18 2016
    Round Lake IL
    Quote Originally Posted by TexasDfwS4 View Post
    Did you get any other News on when we will get delivery of the TCU Tune?
    Sep 10 2012
    DFW
    I believe he said Monday, today. He's been really busy.
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Senior Member Three Rings Sukks2bu's Avatar
    Mar 12 2013
    Milton Ontario
    Standing by for feedback
