I am in dire need of help. It’s like regular help, only it’s dire.
This weekend, I replaced my air filter, removed my throttle body and cleaned it, same for the Air intake temperature sensor that is next to the TB. Also, I my hand went behind the engine trying to touch the “rear coolant flange” as I have a nice leak.
When starting the engine, the idle was very rough, so I did a throttle body adjustment (TBA) using VagCom. The lower/upper limit code was no more, but the rough idle remain.
Diagnostic;
1. I’ve bought a starter fluid for small motor, so spraying it all around would increase the Idle, thus identifying the vacuum leak (if any). Nothing, no increase in idle or sound.
2. MAF, I’ve unplugged the MAF nothing changed in the idle, then replugged it nothing again. I’ve logged the MAF value and I have a peak of 139 g/s at 6200 RPM (about 163 hp). This is the normal value.
3. I’ve bought hose clamps to test every check valves. (Not done yet).
Other symptoms;
•Brake booster not working, happened 2 times at start up within a week, otherwise it work fine.
•I can no longer hear or feel the turbo.
•I can no longer hear the Diverter Valve (DV/Bypass).
I need your help!
Edit : Audi B6 2003 1.8T AMB Quatro
