Results 1 to 12 of 12
    Oct 01 2016
    Frederick Md
    DSG front/central/gear oil change
    Just wanted to check if anyone has changed the fluid in the other oil cirucit on the DSG transmissions, the front and central diff and transmission gears. If so, what mileage and what oil did you use? Is this a DIYable maintenance item or take it to a shop?
    Oct 01 2016
    Frederick Md
    That's for the mechtronic oil circuit, I'm asking about the second dsg oil circuit for the two diffs and gears.
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    it is not required in AUDI maintenance schedule, at least for 2015 s4.
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Oct 01 2016
    Frederick Md
    Quote Originally Posted by jygesq View Post
    Correct, I don't follow their maintenance plan. I plan on keeping the car for 150k+ miles, so I tend to replace 'lifetime' fluids. While I don't doubt the stock fluid is very good, I also have never seen an oil that is truly lifetime. The question is, does 'lifetime' mean failure around 100k, or failure around 500k.
    I come from the BMW world. There are a lot of german environmental regulations that attempt to reduce liquid waste. When these regulations, and the advent of audicare/BMW maintenance packages, went into affect suddenly BMW/AUDI suggested maintenance intervals became much longer. BMW coolant/brake changes intervals doubled even though the fluid didn't change. Diff/manual fluid became lifetime, etc. These things won't effect people buying new and putting 15k mileage on a year because they will probably sell the car well before they hit 100k miles. That is not the case for me, I would like to maintain the car with the goal of seeing 250k.
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    Quote Originally Posted by s4osfan View Post
    I had one of local shops done that for me. The fluid you are talking about plus rear sport diff's gear oil, cost about $350 including labor and OEM fluids after tax (rate here is 9.8%). Not bad in my opinion.
    2013 S5 Misano Red, DSG, B&O, Sport Diff, MMI+, JHM 207mm crank pulley (7PK1370 Contitech belt), APR Stage II Dual Pulley, APR TCU tune, APR CPS, CR15, IE CAI
    2018 XC90 Inscription, B&W sound, Convenience Pkg, Air suspension
    2014 Mercedes E350 rwd
    2021 BMW 540i
    Oct 01 2016
    Frederick Md
    Quote Originally Posted by wangshuo1989 View Post
    That's not bad cost wise. How many miles when you did it?
    Jan 09 2016
    About 42K miles
    2021 BMW 540i
    Mar 05 2015
    2009 A4 Cab: S-Line / 1996 Camaro Z28
    East Granby CT
    WOW - that's a hell of deal - or they didn't use the right fluids or change all of them? Most folks have found ~$450 is the lowest price point for the DSG fluid change alone - and add on the Diffs - I would expect $600 at a minimum.
    Actually - I would question if they actually did the DSG - as I've yet to see anyone find the required fluid alone for under $250?
    But hey if you did actually get all those fluids changed out + labor for $350 - Props to you and the shop who did it - as they certainly didn't make any money!!!
    2012 Moonlight Blue Metallic S4 | Premium + | DSG | 19" Peelers |Sports Diff | MMI w/Nav | B&O Audio | Advanced Key |
    After-Market Add-Ons: Rallitek Aluminum Paddles | USP LED Interior Lighting | Phillips Xtreme +50% Headlight Bulbs
    Performance Upgrades: 034 Stage 1 ECU & TCU | | APR I/C |
    Stoptech Cryo Slotted Rotors with Porterfield R4-S Pads |
    034 Springs / Koni Yellow shocks | Tires = Michelin Pilot 4S (255/35/19)
    Oct 01 2016
    Frederick Md
    Quote Originally Posted by grovlet View Post
    We are not talking about the ATF fluid in the DSG transmission.
    Jan 09 2016
    It's only gear oil in dsg unit and rear sport diff, not clutch oil.
    2021 BMW 540i
    Mar 05 2015
    East Granby CT
    Ahh - gotcha - Reading Compression Fail on my part....
