Results 1 to 4 of 4
    Oct 09 2015
    Las Vegas
    Help! Washed Cylinder, What to do now?
    Hello all. I have a 2010 A4, it has no compression in cylinder #4. I took it to Audi for a diagnostic, and they told me it has a washed cylinder, and I need a $14000 new engine. WHAT!!! Apparently Audi doesn't offer short blocks, and a new long block is $10,000+ labor and parts(new injector and misc nuts and bolts). Does anyone know of a fix for this. I don't have $14,000 to replace a motor on a car that's worth around $10,000 now (or less since it has a bad motor). I can spend $2000-$3000, but certainly not $14,000... anyone have any ideas or know a good mechanic in the Las Vegas area. Any help would be much appreciated. Thanks.
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    Quote Originally Posted by shawn9509 View Post
    time to get an s4
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    Since you're obviously out of warranty, take it to an indy shop and source a used engine instead. Should come in around 1/3 of what Audi is charging.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Established Member Two Rings PurdueB8A4's Avatar
    Mar 04 2016
    2015 Nissan Rogue
    Indianapolis
    2009 Quartz Gray Metallic Audi A4 Prestige
    aFe | Akebono | APR
