My wife's '06 A4 2.0T, 200k+ miles......car died on her this morning, and her description of the event sounds like it ran out of fuel. Car gradually lost power until it stopped. Electrics seem o.k., and car will crank and idle for 5-10 seconds after it sits for 20 or so minutes, but stumbles and dies. Gauge says it has a 1/4 tank. The first thing I'm planning to do is add 4-5 gallons of fuel just to be sure, but I'm not confident that's the issue. Cam shaft and LPFP were replaced at 118k miles, I replaced all 4 coil packs a month ago (car stuttered under load and was throwing mis-fire codes on all 4 cyl.'s) and it has ran fine ever since. It currently shows a P2181 and P0442 code.....I have the coolant temp. sensor and a new N80 valve, but haven't replaced them yet. I don't think that would cause the current problem anyway.
Any advice? I'm hoping it's just water in the gas, or maybe the fuel gauge sending unit is bad and the tank is actually empty. Is there a fuel filter on these cars? HPFP bad? MAF sensor bad? Anything you guys can think of to check would be greatly appreciated.
