    Established Member Two Rings cullenrd's Avatar
    Oct 10 2016
    VA
    Blow off/ Diverter Valve
    Has anyone put a diverter valve on their 2.7t?
    http://www.ecodetuning.com/store/aud...ter-valve.html
    Jun 05 2014
    Olympia, WA
    What is the reason you want to spend 159 per diverter valve? I was going to upgrade my diverter valves in hopes to gain more power. Turns out, they are not necessary unless they are not working correctly. I have been told that the N710 are a good upgrade for reliability over the stock diverter valves. I think ECS tuning has them on their site for a reasonable price...
    40$ each I think
    Oct 10 2016
    VA
    Just wondering if anyone tried and gained anything off of it
    Active Member Four Rings alien_brain's Avatar
    Jun 04 2013
    SE MI
    you wont gain anything, but you may lessen the shockwave your oem DV is giving your turbo. a metal one may hold higher preassure than the plastic oem from 14 years ago. the aftermarket ones may last longer but also can require maintenance. its not a gain thing.
    Junior Member Two Rings
    Mar 23 2016
    After the APR tune, I replaced my DVs with the tunable Forge units. Car runs a lot smoother now, with the green spring installed (15-23psi). See my Sept 27 post, I had some issues with the position of the valves.
