Results 1 to 17 of 17
    Oct 02 2005
    The Moon
    JHM Experts, need your advice!
    So once again I'm contemplating headers for my car. The hesitation has always been on how much of a difference there really is.
    My S4 has the following JHM go fast parts
    Intake Manifold
    Piggy pipes
    Tune
    Has other stuff of course, but let's keep it simple with that.
    How much of a difference will I really experience going from said setup to swapping piggies for headers?
    I suppose if we were to quantify it, what kind of 1/4 mile, 0-60, etc difference would one experience?
    Appreciate any input.
    Veteran Member Four Rings roboto_1337's Avatar
    Jul 05 2016
    B7 S4 6MT, Porsche 958.2
    Ontario, Canada
    I was once told that Red makes things go faster...
    Oct 02 2005
    The Moon
    Quote Originally Posted by roboto_1337 View Post
    Already did that mod noob. Thanks for your insight.
    Jan 29 2010
    north ga
    It will probably be close to as much difference as your car now vs when it's at sea level. The down low power is much more instant, that's the biggest thing you notice. And of course not sounds much meaner and has a throatier grumble.
    And I hope you added more coolant after that picture was taken.....
    Jan 14 2009
    Audi's
    Quote Originally Posted by p3u View Post
    Intake Manifold
    Piggy pipes
    Tune
    Your cars always been one of my favorites!!!! So headers will make it that much sweeter!!! Have you done the crank pulley and flywheel upgrades ? LW rear rotors ...? Small mods but it all helps. I haven't been on the dyno again since I upgraded to headers and 2.5 catback but its a nice difference in power. Car just runs smoother and rev's easier and sounds meaner. The butt dyno would say the performance difference is 20-30whp. If you look at the old 1/4 mile videos jhm put out with the v1 headers they went from a 13 second with piggies to a 12.7 with the addition of headers. If your cars due for the timing service then go for it! Ceramic coating them helps as well! Forgot to mention if you decide to go catless and like having your windows down the smell is burtual. I gave a good review of my thoughts about the headers in my build thread. Hope that helps
    Jul 05 2016
    Ontario, Canada
    lol
    Veteran Member Four Rings TarlCabot's Avatar
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    headers do not any hp, they only change exhaust note and add some tq....
    PAST
    2004 Audi (B6) S4 4.2L
    2006 Audi (B7) S4 4.2L 25th Anniversary Special Edition #167
    Current
    2015 Audi (B8.5) A4 2.0T P+ Sline ECS-Luft-Technik Intake System/Air Scoop v2/Silicone Intake Tract Set with turbo muffler delete, GFB DV+ VTA Performance Blow-Off Valve, JHM FMIC/ECU and TCU (Automatic 8 Tip Quattro) Stage 2 tunes. Cosmetic RS4 Honeycomb Mesh Front Grille and Fog Light Vent Grilles
    Veteran Member Four Rings FastEddie's Avatar
    Apr 01 2012
    Queens
    The headers are incredible, but ill be honest, unless you have the funds or are already pulling the engine for something else, i would just buy a real nice set of downpipes. I love my headers but they are pricey.
    SUSPENSION-KW V3-Hotchkiss RS4 sway bars-034 Adj UCA-034 strut mount-034 F&R end links-034 motor mounts-034 Snub mount W/bracket-034 Trans mount l BRAKES-ECS Stage 4 BBK-ECS rear rotors & lines, Hawk pads l Engine-JHM Tune-JHM 6 rib pulley-Milltek catless DP's-FI exhaust l EXTERIOR-RS4 black grille-Custom headlights-LED city & DRL lights-ECS LED tail lights & plate lights l INTERIOR-Custom steering wheel-SRP pedals-ECS LED lights-MOMO shift knob-Gen 2 RNSE & AMI l WHEELS-OEM RS4 W/ Michelin PSS
    Apr 01 2012
    Queens
    Quote Originally Posted by TarlCabot View Post
    And where did you come up with this information?
    Active Member Four Rings S4orgy's Avatar
    Nov 11 2008
    05' B6 S4 B.R. 2000 B5 2.8 B.B.
    New Britain/Farmington, CT
    Quote Originally Posted by Mr. Corey View Post
    I thought they hit 12.7 with the ported intake manifold & without headers?
    05' B6 S4 Brilliant Red 6MT: JHM 93 Tune ● JHM Ported Manifold w/spacers ● JHM Lightweight Pulley ● JHM Lightweight Flywheel ● JHM STG3 Clutch ● A.W.E. Catless 2.5" Downpipes ● Custom 2.5" Corsa Non-Res Exhaust w/x-pipe ● KW V3 Coilovers ● Stern Adjustable Upper Control Arms ● JHM Short Throw Shifter
    00' B5 A4 2.8 5MT: Gone
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    Quote Originally Posted by S4orgy View Post
    The JHM 12.7 run was with the intake manifold and V1 headers along with all the other NA mods.
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    hahaha! straight from a Warhammer 40k ork mouth...
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    Quote Originally Posted by FastEddie View Post
    considering he is running piggies, he would probably see some hp gains, but not any more then dps and full exhaust
    pretty much everyone running these including JHM have verified this
    PAST
    Current
    Apr 03 2010
    Northern Virginia
    Quote Originally Posted by Terry.Reese View Post
    Yep, finally someone else that knows that reference.
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    Corey's car sounds amazing and pulls strong but again. Price vs gains - i wouldnt do it. If youre thinking about going blower/turbo way then yes but other than that my opinion is you can spend 2500$ better :) but thats just my opinion.
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Jan 14 2009
    Audi's
    Considering the resale value has gone down considerably with the platform with its achilles heal..... timing service and shitty valve seals. Its opened the doors for people who can't afford to maintain the car are buying them and not giving them the proper love and TLC it requires to keep it going. If your prepared to invest 7-10k in parts for a DYI or closer to 14k if a shop does the work to give the engine an overhaul with timing, adjusters,valve service, and all the while your their items...... the price of headers negligible. If your planning on pulling your engine just for the headers then its a ton of work for the gains. My car is a weekend warrior in the summer. If it was a daily driver I wouldn't of invested the time and money for the marginal gains. By no means is the V8 S4 a fast car..... its quick, but a bolt-on B8 S4 or even a S3 would be able to keep up with and even pull on a stage one SC V8 car. In my opinion the newer platforms aren't as fun to drive. If you have a clean well cared for example of a goodwood avant, which from photo's it looks like you do.... I wouldn't hesitate in adding headers to make it even more fun to drive. It took me 4 exhaust setups before I got to my current configuration which is for sure my favorite. But its easy to go back and forth with the Price VS. Gains question. In the near future I'll be going full retard with the addition of the stage one SC but even that is hard to pull the trigger on.... given the love hate relationship we all have with the 4.2.
    Veteran Member Three Rings s4ski's Avatar
    Jul 01 2013
    2005 S4 Avant, Skiis
    Anchorage, AK
    This is an informative thread. I did catted downpipes, all the while wondering if I made the right choice relative to waiting for TC work and doing headers then.
