    Senior Member Two Rings calebtbay's Avatar
    Sep 06 2016
    2006 Range Rover Sport SC, 1998 Range Rover P38, 2005 Izuzu NQR, 2007 Toyota Forklift
    Bedford, IN
    Backup Camera Install, Anyone done this before?
    This is all on a 2004 Audi S4 w/ 134k miles.
    I purchased the top of the line Kenwood head unit from best buy. It has the apple car play and Garmin navigation. Naturally it has an input for a backup camera. I am sure as most of you are well aware, once you get a double din unit in the dash with the install kit getting it out is nearly impossible. I also have two amps, a capacitor, and a one 12" sub. I have alot of temporary wiring. I want to go back through, clean everything up with the proper connectors and get everything hidden real well.
    The backup camera is giving me troubles.
    The model I got is a black cube that must be screwed to the trim that holds the license plate lights, and it has to have a hole for the wire. So I had to drill 3 holes. IT LOOKS AWFUL! So bad in fact that I have given up on it and ordered a new trim piece and a new camera. The camera I got goes in the license plate light spot and replicates the light as well. I had to order the dude from China and its still not here yet. I wanted to get my wiring figured out before it gets here so I am ready to rock and roll.
    I found the wire in the rear driver (left) side tail light that is for the reverse light bulb. I used a soldering iron and heat shrink tube to make a nice tap into the line there. I have +12v running up to the front to the Kenwood units purple REVERSE light wire. I have checked it with a multi meter and when I put it reverse it gets between 11 and 14V at that connection behind the head unit.
    It triggers NOTHING in the head unit. It seems like it would at the very least trigger the head unit to display that video feed even if there was no power to the camera. It doesn't. Sometimes if you start the vehicle with the clutch in and reverse gear it makes the head unit get a bit weird and take a moment to come on, but thats all I get. So I am left to assume that if its not getting a video signal than it doesn't even switch. I have the connection grounded the a temporary ground, which is kinda sketchy but based on my multi meter its a good ground. I hooked up the ground wire in the trunk area and then strip it a little about 6" back and check for ground there and its good (I have a lot of extra wire for testing purposes. So the camera is getting 12v. It shows nothing. I am guessing I fried the camera with a short at some point during all of this, or it was faulty to begin with.
    Do any of you whom have ever hooked one of these up know of some kind of stupid mistake I am making. I have positive current everywhere I should have it and ground everywhere I think I should have it, and no dice.
    I sure don't want to jack up the replacement camera so it would be good to know what I am doing wrong. Any help is appreciated.
    It might also be important to note that before this my passenger side mirror would tilt down when I put it in reverse. It struggled to do so, and didn't do so every time. That quit working all together. I didn't really like it to do that anyway so I'm not heartbroken but it might be a factor.
    Jun 07 2013
    West
    I just did this to a different car with a GPS unit that has an AV input via mini-jack. I had trouble due to the mini-jack having a different wiring order than the RCA to mini cable adapter, but some cutting and shuffling got the video signal and video ground to the right place. You need to make sure both the camera has power and ground and the video signal is getting to the correct point on the head unit. I would get an inexpensive test monitor. Get this one:
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Did you perform the system setup on the head unit for View Camera per the manual?
    Did you see this camera option?
    https://www.amazon.com/gp/product/B0...A1DYXENTQ4AAZG
    Sep 06 2016
    Bedford, IN
    I got it all figured out. It was some settings within the head unit itself. The camera works great!
    If anyone has any camera wiring questions I will be happy to share how I hooked it up.
    One problem I am having is the the camera replicates the plate light. That light isn't working. I am positive its an LED. Is there something extra I need to do to make it work?
    Jun 07 2013
    West
    Are the two copper pieces making correct contact as the OEM light? Those are what deliver the power and ground to the LED.
    Sep 06 2016
    Bedford, IN
    I believe so. I had to take that whole trip piece out to drill the hole. So I put it in the trim piece and then put the trim piece back on the car.
    I know that in some cars you cant simply replace the light because of some kind of signal in the wiring. Is there an extra part needed, or special lights required for this car to run LED lamps? If you replace range rover lamps with LED units they dont work and it causes and error.
