Results 1 to 11 of 11
    Senior Member Two Rings Hammerzeit's Avatar
    Nov 21 2008
    Bellevue, WA
    B7 RS4 Euro Flat-Bottom Steering Wheel w/ OEM Airbag
    SOLD! Thank you
    | AMD |
    AKA: funS4me
    Jul 17 2008
    1976 BMW 2002; C5 RS6; B5 S4
    Florida
    Plug and play for the B6 S4 with MFSW?
    Nov 21 2008
    Bellevue, WA
    Quote Originally Posted by BertieS4 View Post
    Hi Bertie, The wheel is a direct bolt on for sure. The airbag and media button functionality requires the same clock spring wiring harness as the B7. I did a quick search and it looks like the later model B6 S4's use the same wiring and require no mods. Older models, without RNS-E presumably, require about $500 in misc parts. The Euro wheel limits you to basically two functions that require programming; Radio volume control and ability to scan through the interface on instrument cluster....no phone, navi or media controls beyond that. Just looks perdy. ;)
    You'll need to research to be certain. Here's a couple of links to start with...
    http://www.audiworld.com/forums/s4-b...07-s4-2661250/
    http://www.audizine.com/forum/showth...-wheel-install
    http://www.audizine.com/forum/showth...eering%20wheel
    http://www.diyaudi.com/Home/Home.html
    Cheers
    | AMD |
    AKA: funS4me
    Nov 21 2008
    Bellevue, WA
    | AMD |
    AKA: funS4me
    Established Member Two Rings DAYTA's Avatar
    Dec 30 2014
    Is the Euro FBSW the same diameter as the OEM RS4 steering wheel? Or is it smaller?
    Nov 21 2008
    Bellevue, WA
    Obviously smaller top to bottom since it's a flat bottom wheel, but I believe they're about the same diameter across. Euro wheel has about an extra 5mm of leather thickness to it, which makes it look smaller in diameter compared to the US wheel. 370-375mm
    Here's a pic from an old 'zine post comparing the two.... A bit exaggerated since the stock wheels closer to the camera. But you get the idea
    | AMD |
    AKA: funS4me
    Veteran Member Four Rings b6bydesign04's Avatar
    Nov 14 2005
    Charlotte, NC
    I want a FBSW so bad, and really want to keep it authentic with the RS4 wheel, but I use my steering wheel volume all the time. Did it take a while to adjust to not having them on the steering wheel? Looks to be in great shape and so far best price I've seen recently though, should sell no problem. GLWS!
    -Sean
    '06 Lexus GX470 | Dobinsons | fifteen52 | BFGoodrich | Prinsu | Gobi | Orangeboxx | RSG
    '11 BMW E90 M3 | ESS S/C | Recaro | M Performance | iPE | BC Racing | BPM | Volk | Coby
    F.T.W.L.T.B.D.W.I.C.T.W.
    Nov 21 2008
    Bellevue, WA
    Thank you kindly! It's my 3rd time buying (and reluctantly selling) the Euro wheel over the years. It's easy to program the volume controls through vag-com, but I really got used to scanning through songs and radio stations on the stock mfsw and that's not a programmable feature on the euro. Easy to forget though, the wheel feels vastly superior to the stock one, in terms of grip, thickness and tighter turn radius. You'll be fine with volume on this wheel
    | AMD |
    AKA: funS4me
    Jul 17 2008
    Florida
    Quote Originally Posted by funS4me View Post
    Cheers
    I have the older model B6. Whereas I could do without the other functions, I'd need to know the airbag would work.
    Veteran Member Three Rings my_RS4's Avatar
    Apr 15 2016
    Beach Cruiser
    Venice
    Very nice wheel. GLWS!!
    Sent from my iPad using Audizine mobile app
    IG @myRS4 | 2007 RS4 | Phantom Black | Ti Converted | Milltek'ed | KW H.A.S. kitted | Rotiformed (SPF DDT 19X10 +25) | PSSed 275/30/19 | LED DRL'ed + Citied + CC'd | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | Apikol rear-diff mounted | JHM Lighweight Flywheeled | Ziza lit | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded
    Nov 21 2008
    Bellevue, WA
    LOCAL SALE PENDING! Will update listing according on Sunday!
    Salute!!
    | AMD |
    AKA: funS4me
