Following up...(sorry for the delay).
I would highly recommend installing the 034 billet aluminum subframe bushings. The car feels firm under all conditions whether cornering, accelerating, braking etc etc. The engine feels locked in. NVH did not increase other than additional road noise from the tires (poly lower control arm bushings).
While i had the subframe removed, decided it was an opportune time for an upgrade to the exhaust system. Installed JHM Piggies and AWE's Track Edition exhaust (had fitment issues but thats for another thread). Also installed 034's Street Density motor mounts and tranny mounts. And finally a Spulen Rear diff mount.
The job was a bit tedious. Removal of the subframe wasn't bad. You'll need a shop press to press out the old OEM bushings. They're a bit of a pain. You'll have to make a bit of clearance on the steel subframe in order to get the bushings to fit in place. I shaved a little bit off the bushings as well so that they would fit snug into the subframe. Sanded and repainted the subframe. Re-installation wasn't too bad. Took me about 2-3 days due to the piggies and such. If you're just doing the subframe bushings, it might only take a day or so. Difficulty...i'd say its a 6 out of 10. Its all worth it though.
I have pictures if you'd like to see. Let me know...
