Yes, I searched.
It's what I would consider a fully built stage 3 car-
F21s
SSAC 3in catted downpipes
3in straight exhaust with a small 6in Vibrant race muffler
Bosch 550cc injectors / custom cnced spacers so the injectors would seat properly.
Bosch 044 fuel pump
ER intercoolers
Fx400 and flywheel
MBC set up in parallel with the N75
2.8 heads
Forge Diverter Valves
85mm MAF and 034 silicon throttle body boot
My questions is what are other f21 cars running in terms of a tune I am running eurodyne maestro, the issue is under turbo options there is nothing for the f21s so I am using K04s as my input there, not apples to apples. long and short the symptoms are it breaks up into boost then seems to over boost.
-When the car first hit the street it was set at 26 pounds it was breaking up into boost if I laid on it at 3 grand in 3rd fairly often, not good. If i am softer on the throttle and hold it at 3 grand for a bit 2-3 seconds it is much smoother.
-Dialed it down to about 24 psi via the MBC still much of the same breaking up into boost for a few seconds than pulling very hard. Spiking at 24-25 holding boost at 22psi
-Dialed it down to 22 psi symptoms still persisting but not as regularly, spiking at 23-24 holding at 21-22psi
-Dialed it down to 20 psi symptoms are mostly gone but the car feels flat out slow.
Currently the car idles very smoothly at 900rpms and all but two of my boost hoses were replaced in the rebuild.
I haven't been able to take logs but more importantly from a tuning standpoint I wanted to find out what everyone has been using for their f21 car and what they feel has been their "best tune/ most reliable" to get an idea of where I should go from here.
What I am trying to achieve- A fun, reliable, daily driver tune, with a smooth power curve ideally running 20-21 pounds, I don't need the car to make 400hp but 375 would be nice.
