Results 1 to 28 of 28
    May 30 2015
    2012 Ford Fusion (wife's car)
    Wellman,Tx
    I'm cool now.. but got a question
    Over the weekend I installed my retrofitted headlights.
    The kit is from TRS and it's the 5500k mini h1 kit.
    I absolutely love them, it's like it's daylight when my lights are on
    My question is/are
    Does the throw look right ?
    Why do the dip in the middle?
    Does the cutoff look right?
    I fixed the alignment today
    The cutoff does have a nice blue line but doesn't show up in the photo
    Veteran Member Four Rings Der Konig's Avatar
    Jul 09 2009
    '06 a4 2.0T 6MTQ, S3 '01.5 s4 avant 6speed, '12 KO4 Audi Q5
    Cleveland OH Area
    Its hard to tell but I think what you are referring to is a built in sort of step down cut off on the driver side headlight to avoid blinding oncoming traffic.
    not sure about the other questions.
    Edit: oh wait, it looks like a U. That im not sure. I assume due to how the light is dispersed and concentrated you need less height in the middle? dont know.
    '04 Corvette Z06 track car
    '15 F350 Platinum 6.7
    '06 APR S2+ A4 2.0T 6 Speed DD - current
    '12 Q5 2.0T P+ Built engine/CTS K04/IE tune - current
    '05 Ford F250 XLT 4x4 BP'd 6.0 - current
    '01.5 APR S3 S4 Avant 6 Speed - sold '04 Goodwood S4 6 Speed - sold '91 Jetta GL 1.8 8v manual swap - sold '99 SVT Cobra 08whp/308wtq - sold '01 Mustang GT - sold '88 Mustang LX 5.0 - sold '95 Jeep Cherokee Country - sold
    Senior Member Three Rings miA4's Avatar
    Jul 17 2015
    miami
    I would assume the U shape is due to a alignment issue. Maybe the lens is slightly tilted in one direction.... They look fine to me though.
    May 30 2015
    Wellman,Tx
    Thanks guys. You can't tell unless you shine them on a wall.
    I'll just run them now as is.
    The lights measure at 34 inches from ground at 25 feet
    Feb 15 2016
    Cambridge,Ontario
    if you are in doubt get them aimed professionally . There is nothing more irritating on the roads than driving down the road with an amateur ricer who threw on new lights to impress his buddies and blinds everybody just to look cool . don't be THAT guy ..
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    May 30 2015
    Wellman,Tx
    I'm not that guy.
    I was asking about the U shape
    The are aimed right now.
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~30 Road Bikes, Piper Aztec, Grumman AA1, Zlin242L
    Indiana
    The pattern doesn't look right to me. There shouldn't be a dip in the middle, and the cutoff should be on the driver's side so as not to blind oncoming traffic. If the first two pics are of the high beams there is way too much foreground lighting. More of the light should be projected down the road. In case you were wondering this is one of the main reasons why most systems on US made cars turn the fog lights off while on high beam.
    May 30 2015
    Wellman,Tx
    The first picture are pointing at the ground due being at an angle
    I raised the lights some today
    May 30 2015
    Wellman,Tx
    Jun 17 2013
    jersey city nj
    ing LM output
    May 30 2015
    Wellman,Tx
    Quote Originally Posted by vce1232000 View Post
    ing LM output
    Lm output?
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by fhh02a View Post
    Lm output?
    yes.
    Oct 24 2015
    Perth, WA
    You sure they were LHD headlights?
    My respray thread
    May 30 2015
    Wellman,Tx
    They came from a member on her.
    So I would say yes
    And what is LM output
    Jun 17 2013
    jersey city nj
    lumen
    May 30 2015
    Wellman,Tx
    lumen
    You saying
    Good or bad
    Jun 17 2013
    jersey city nj
    You saying
    Good or bad
    Here's a link to my factory bi-xenon nite lite up for a comparison http://www.audizine.com/forum/showth...all-amp-Review
    Veteran Member Four Rings rongeur's Avatar
    Jun 04 2011
    Clayton, CA
    Your rotational axis is off on both sides. Should be perfectly horizontal against a wall.
    2008 A4 2.0T Quattro 6MT S-Line QGM
    Stage 3 JHM TD05H-R on a fully built motor
    Build Thread
    May 30 2015
    Wellman,Tx
    Sorry I'm dumb
    Jun 17 2013
    jersey city nj
    Sorry I'm dumb
    ..........lol
    May 30 2015
    Wellman,Tx
    how would one fix the rotational axis?
    Sep 02 2008
    Boonies VA
    Depending on how the projectors are mounted to the headlights, I believe all you need to do is rotate them to fix that. Hopefully they are not glued!
    White Wagon
    Sep 30 2009
    Indiana
    I agree with rongeur. Rotational mal-alignment might explain both the 'U' shape of the beam pattern and the excessive foreground lighting (which raising the beams seems to only have helped a little).
    May 30 2015
    Wellman,Tx
    Quote Originally Posted by naiku View Post
    Which means I have to separate the housings to gain access
    May 30 2015
    Wellman,Tx
    Thanks YouTube
    Looks like I can do it from the back
    Now which way to go
    May 30 2015
    Wellman,Tx
    turns out. Im missing the bulb holder clip.. TRS has reviewed all photos and determined that the bulbs arent seated correctly.
    hopefully the clips will improve the bowing affect
    Jun 27 2011
    yea those are WAY off. Rotate those suckers and try to get rid of the awful hot spot in the center. Its seems like they're aimed WAY low too. They appear to be acting more like fog lights than main beams.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    May 30 2015
    Wellman,Tx
    just hope they can be rotated in the back
