Results 1 to 26 of 26
    Established Member Two Rings Mussa's Avatar
    Oct 31 2015
    Istanbul - Turkey
    Question Is the 3.0 TDI intercooler direct fit on? (All OEM Parts Bought)
    I'll buy the OEM 3.0 TDI intercooler (8K0145805E) from the Audi dealer. I want to know whether this will fit without any other equipment, modes or trimming? I've seen some threads stating that it's a bit struggling issue.
    I need to know this because I want it to be installed by the authorized Audi service. If any modifications are requested they may not install it.
    Thanks in advance.
    EDIT: Bought all the necessary parts. Will post the pictures.
    2011 A4 B8 2.0 TFSI Quattro S line S tronic // APR Stage 2 98 RON - OEM Dual Exhaust - OEM 3.0 TDI FMIC
    - USP HFC - RS4 Black Grille
    Veteran Member Three Rings Townending's Avatar
    Aug 29 2014
    Claremont, CA / Big Bear, CA
    I had to trim the plastic guards/air channels that go on each side of the inter cooler, but this plastic is so thin you can cut it with a nice pair of scissors. Other than this minor trimming, it clipped right in for me, no other modifications needed.
    2009 BMW E92 M3 - SilverStone II - Full IPE F1 Exhaust - Stage 2
    2013 A4 Quattro - Moonlight Blue
    Mods : APR K04 E85 - Solowerks S1 Coilovers - Treadstone TR8 - RS4 Honeycomb Grille / Foglight Grilles - ECS Intake tubing - Hardwired Valentine 1
    034 Motor Mounts / Tranny Mount + Insert - ECS Rear Diff Mounts + Insert - Alzor Style 349 Wheels 19"x9.5" ET 40 - 265/35/19 Michelin PSS - VAGCOM Mods
    Oct 31 2015
    Istanbul - Turkey
    Thanks for the response. It's all upto the service, hope they wont deny on doing a minor trim work. Or maybe they would want to change that air duct to the one that suits the 3.0 tdi intercooler.
    Btw, the oem intercooler costs quite cheap at the dealer, only $150 plus $60 for labor.
    EDIT: It's $350 at the audi dealer
    Oct 31 2015
    Istanbul - Turkey
    Another thing, the orijinal hoses are 2.25" the 3.0 tdi IC is 2.5".
    Will the orijinal rubber hoses fit without any problem? Will it pop out in the future due to stress?
    Oct 31 2015
    Istanbul - Turkey
    Here are the parts needed for installing the 3.0 TDI IC:
    1- OEM IC (Behr 8ML376746181, OEM code: 8K0145805E)
    Price: $170
    2- OEM left-right air guides (Part no: 8K0121283F and 8K0121284F)
    Price: $22
    Will install them tomorrow
    Oct 31 2015
    Istanbul - Turkey
    I installed the IC on Sunday.
    It was pretty easy taking off the bumper and IC. However the original 2.25" hoses were a pain in the ass to fit the 2.5" inlet-outlet of the new IC. I was really close to give up:)
    Other than that I also installed the new air guides rather than trimming the old ones. The total cost for this upgrade was $200. I think it is worth doing this upgrade especially for a tuned car. I like to be at the safe side.
    Finished:)
    Dec 01 2012
    Charlotte, NC
    Great info here!
    I can see now that the 3.0 TDI intercooler is thicker when compared side by side with the OE intercooler.
    For stage 1/2 applications, what's the measurable benefit here? Do you know?
    Just curious if this dropped your intake charge temps and if so, by how much.
    I'm trying to quantify spending the $200 by convincing myself with facts, lol.
    :D
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    Buy a TR8 or TR11 for about 250 and then 20 or so for a couple hoses and clamps and you've got a much better alternative.
    My 2009 A4 Prem+ Build thread
    Veteran Member Three Rings Malk's Avatar
    Nov 17 2004
    Socal
    Post #61 by context.eax in a thread from 2012: http://www.audizine.com/forum/showth...n-thread/page2
    Quote Originally Posted by context.eax View Post
    Today I installed the 3.0TDI IC on my A4 B8 2.0TFSI.
    Car now feels a bit faster so I am happy. Did some logging also using VCDS in 3rd gear. WOT from 2000RPM to 6000RPM
    Here is a IAT compare log I mad. Found an old log from the stock IC with same ambient temp at 18C. (Car's setup is also the same except for the IC of cource :))
    I also had a log with stock IC at 13C and the max temp I could see in it was 42C so at 18C the new 3.0TDI IC performs better then 2.0TFSI stock IC at 13C.
    So question is then how many HP is 8C colder IAT? Any one?
    Mods:
    ECU: Revo Stg 2. Performance B
    Milltek Sports Exhaust
    034M HFC
    3.0TDI IC
    Regards,
    This is the only comparison I've seen anyone do between the stock and tdi IC. Not clear if he averaged multiple pulls. Graphs for back to back pulls would be better to compare, but it appears to make a decent difference at 18C ambient.
    I agree with Lambda13. For the cost of a Treadstone and hoses, you can't go wrong. Lettuce has some good graphs from a TR8 his thread to compare. (context.eax graph is 18C vs. lettuce is 26C ambient)
    Post #165 from Lettuce thread: http://www.audizine.com/forum/showth...d-Beyond/page5
    Quote Originally Posted by lettuce View Post
    Ran some logs today for a top secret project. I've been meaning to check out my IATs since installing the new Treadstone TR8 intercooler, so I made some graphs I thought you guys might be interested in as well. Ambient temps were around 80 degrees F, so around 26 C.
    2nd gear pull:
    3rd gear pull:
    Max temps in the 2nd gear pull were only 33 degrees C while staying pretty much steady between 30 and 32 during the entire pull, actually getting colder at higher RPMs. That's 6-10 degrees F over ambient through the entire RPM range at 20-23 PSI.
    Max temps in the 3rd gear pull hit 35 degrees C, rising from a baseline of 30 C. The temps stayed steady until 5k RPMs at which point they rose to 35 and then quickly dropped to below baseline (29 C) when letting off the throttle. That's 6-15 degrees F over ambient through the entire RPM range at 20-23 PSI.
    Pretty damn impressive performance from a $250 intercooler.
    Aug 18 2016
    San Jose, CA
    Is this the correct one? I bought one for $69 on ebay. It says "interchange" part number 8K0145805E.
    http://www.ebay.com/itm/122025164828
    Nov 17 2004
    Socal
    Quote Originally Posted by SukhShanti View Post
    Edit:
    Yes that is the correct one.
    Nov 17 2004
    Socal
    The tdi IC part # Mussa posted is the best way to search on ebay: 8K0145805E
    For reference, make sure the compatible car is a C7 A6 3.0 TDI
    Nissens is the OEM manufacturer and their part # is 96618.
    Best price I've found for a Nissens tdi IC is from Rock Auto at about $170:
    http://www.rockauto.com/en/partsearc...le.com+URL+%2F
    This one is $100 but isn't branded.
    https://www.hansautoparts.com/8K0145...tercooler.aspx
    Aug 18 2016
    San Jose, CA
    I was just about to post that Hans Autoparts one, I think I will go with that one.
    Thanks for the help Malk. FYI, I did ebay search 8K0145805E and that's how I came across the ebay one. That same seller does have 8K0145805G as well. (see below) This is why I assumed the 8K0145805E was correct.
    http://www.ebay.com/itm/New-Audi-Int...1XfZSX&vxp=mtr
    Nov 17 2004
    Socal
    Thank you for pointing out you did search by part number and I stand corrected. It does look like the one you ordered is the tdi size part # 8K0145805E
    I was looking at compatible cars and the first page is all 4 cylinder turbo A4's but there's also S4's listed as compatible so that list is wrong.
    Aug 18 2016
    San Jose, CA
    Hmm, I think I will keep my ebay order and roll the dice on it then, will post pictures once I receive it.
    Senior Member Two Rings shayan_a4's Avatar
    Jul 12 2014
    2014 VW GTI and 2014 mercedes SL550 2014 b8.5 audi a4, c7 A6
    woodland hills
    yea, when i got one it fit perfect, with just a bit of trimming lol, but for the most part it was an easy install
    Aug 18 2016
    San Jose, CA
    Got my IC in today. It doesn't have a part number on it, but I measured the core and it matches the exact dimensions of 8K0145805E, the OEM 3.0 TDI intercooler, so it is the correct one. I haven't installed it yet, so I cannot comment on performance yet.
    Anyway there are more available for $69 if interested.
    http://www.ebay.com/itm/New-Intercoo...RXbM~R&vxp=mtr
    Now, I just need to buy an RS grill for my A5 so I have extra reason to rip my bumper off
    Oct 22 2012
    Markham
    such a good deal at $70. keep us posted on if it performs..
    Oct 31 2015
    Istanbul - Turkey
    Quote Originally Posted by forcefed7 View Post
    Great info here!
    :D
    I didn't do any logs or measurements. Above there is a comparison log for oem vs tdi . Hope this gives an idea.
    Now the whether is cold but, after long hard drives it still pulls strong and no turbo lag. I'am happy with the upgrade. I don't recommend an IC bigger than 8 lt unless the hp is 270+, it may cause turbo lag.
    Nov 12 2016
    Fl
    Quote Originally Posted by Mussa View Post
    congrats on the new IC!
    for the hoses, I brought a pot of boiling water to dip the hoses in for a few minutes to help with the inlet/outlet fitment
    Veteran Member Three Rings Discipulus's Avatar
    Sep 20 2016
    Portland, OR
    Price: $170
    Price: $22
    @Mussa (Or anyone who can answer), those part numbers for the Left/Right Air Guides - are those the part numbers for the original B8 A4 or are those different ones with larger slots for the upgraded 3.0 Intercooler? I was just about to purchase these along with the intercooler but couldn't tell if they are the original small ones or the larger ones! If they're the originals, and need modification... then I'll just cut mine to fit rather than buying new ones and having to cut those as well.
    Oct 31 2015
    Istanbul - Turkey
    Quote Originally Posted by Discipulus View Post
    Those part numbers are for 3.0 TDI A4. For 2.0 TFSI the part numbers are 8K0121283G and 8K0121284G. You can either buy them for direct fitment or trim the small ones.
    Sep 20 2016
    Portland, OR
    Awesome, thanks!
    Sent from my SM-G930V using Audizine mobile app
    APR Stage 2 DP | JHM 207mm Crank | JHM HX | EPL TCU | JHM Race Pipes | JHM High-Flow Cats | Euro-Spec SQ5 Springs | Bilstein B8 Shocks | 034 Motor Mounts | ECS Drivetrain Inserts | ECS Aluminum Cross Brace | AFE Pro Dry air filter | 034 Silicone Intake Tube | 034 RSB | TRW metal endlinks | ECS Stainless Brake Lines | RSNAV S3
    2015 Q5 3.0T - Current
    2011 A4 6MT - Sold
    Apr 27 2018
    Massachusetts
    im pulling this one up from the dead.
    Is there a written tutorial that any of yall used to perform this install? Looking for one.
    Any updated places to get the intercoolers?
    Veteran Member Four Rings bb-tt's Avatar
    Apr 30 2018
    2017 TTS, 2011 Avant, 82 c3 vette, 2002 TT (sold), 2010 CC (sold), 2013 Jetta, 2018 Q7, 2019 Tiguan
    DFW, TX
    Quote Originally Posted by beantownb8.5 View Post
    Pretty straight forward don't know that a guide exists or would be needed, order the nissens from Rock auto. It is perfectly fine for stage 2, but would not prevent heat soak with the k04. Actually after thinking about it you could download one of the aftermarket guides from apr, ie, ecs... But again pretty straight forward.
    2011 A4 Avant S-line Prestige
    Nothing to see here, keep moving!
    WPT+
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    Does anyone have a picture of how they trimmed the air guides? Just trying to go at it with a final picture in mind rather than trial/error approach. Thanks!
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
