    Stage 2 Banner Advertiser Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    :: EuropaParts.com :: Ross-Tech's VCDS Vag-Com and Accessories
    If you own an Audi, Volkswagen, Seat, Skoda, or Bentley you need a powerful tool that will help keep your vehicle on the road. Ross-Tech VCDS® (VAG-COM Diagnostic Software) helps diagnose real problems instead of swapping out costly parts. With features found only on dealer level factory tools, VCDS surpasses the performance of aftermarket diagnostic tools and rivals factory tools for a fraction of the cost. Always know exactly how your vehicle is running instead of paying someone else to diagnose the problems, usually leaving you with a huge repair bill.
    WITH ROSS-TECH VCDS YOU CAN:
    • Gain factory level access to all systems in most VW, Audi, Seat, Skoda and Bentley models from 1990 through the current model year
    • Scan for and clear DTCs with 19,000+ fault codes decoded into plain text
    • Alter settings through module coding accessible only by factory level tools
    • Perform various country-specific modifications to your car (remove seat belt chime, enable gauge test/needle sweep, enable lap timer, operate windows and sunroof with remote, and much more)
    • View and log live data
    • Reset service reminder
    • Perform built in tests and calibrations normally reserved for factory level tools
    • Diagnose real failures instead of swapping parts!
    WHICH VAG-COM PRODUCT WILL WORK WITH MY CAR?
    VCDS HEX-NET Professional Kit - WiFi or USB connection, works on most models 1990-current, unlimited cars
    VCDS HEX-NET Professional - WiFi or USB connection, works on most models 1990-current, unlimited cars
    VCDS HEX-NET Enthusiast - WiFi or USB connection, works on most models 1990-current, limited to 10 cars
    VCDS HEX-V2 Enthusiast (USB, 10 VINs) - USB connection, works on most models 1990-current, limited to 10 cars
    VCDS HEX-V2 Enthusiast (USB, 3 VINs) - USB connection, works on most models 1990-current, limited to 3 cars
    THINGS YOU MUST HAVE TO RUN VCDS:
    • A computer with a USB port running Microsoft Windows (VCDS also works fine on Apple and Linux computers running Windows in a virtualized environment)
    • The Ross-Tech VCDS (VAG-COM Diagnostic Software) (free download from Ross-Tech)
    • Any of the Genuine Ross-Tech VCDS Interfaces sold below
    THINGS YOU MIGHT WANT WITH YOUR VCDS:
    • A copy of the VCDS manual to get you started (PDF format)
    • If you purchase a HEX-NET interface, a copy of the HEX-NET FAQ (HTML format)
    • An OBDII right angle extension cable if you want your diagnostic tool connected and away from the driver's feet and legs
    • A USB extension cable to extend the reach of a VCDS interface from the computer to the vehicle
    • For pre-1995 cars, a 2x2 adapter to connect between the 2x2 port in older vehicles to the OBDII connector used for current generation diagnostic tools
    • A Bentley repair manual which has a list of the diagnostic, troubleshooting codes and the recommended repair procedure
    • Europa Parts is an authorized stocking distributor of Genuine Ross-Tech VCDS (VAG-COM Diagnostic Systems) for Audi, Volkswagen, Seat, Skoda, and Bentley vehicles. Don't be fooled by cheap fakes, knock-offs and imitators as those can damage your car. This is the real deal, manufactured by the world's leading diagnostics solutions company.
    All of our Ross-Tech VCDS systems are always in stock and never drop-shipped. Order before 3pm ET and have it shipped the same day. Please contact us with ANY questions you might have about these widely acclaimed diagnostic systems. We'd be happy to help.
    Ross-Tech, VCDS, VCDS-Mobile, VCDS-Cloud and HEX-NET are registered trademarks of Ross-Tech, LLC, USA. Authorized use of these has been granted to Europa Parts LLC.
    FREE SAME DAY SHIPPING ON ALL ROSS TECH DIAGNOSTIC CABLES
    VCDS (VAG-COM) HEX-NET PROFESSIONAL KIT (WIFI/USB, UNLIMITED VINS)
    VCDS (VAG-COM) HEX-NET PROFESSIONAL (WIFI/USB, UNLIMITED VINS)
    VCDS (VAG-COM) HEX-NET ENTHUSIAST (WIFI/USB, 10 VINS)
    VCDS (VAG-COM) HEX-V2 ENTHUSIAST (USB, 10 VINS)
    VCDS (VAG-COM) HEX-V2 ENTHUSIAST (USB, 3 VINS)
    Hugh
    EuropaParts.com, Your Trusted Audi Parts Source
    Facebook: Like Us on Facebook
    Instagram: Follow Us on Instagram
    Aug 22 2010
    Piscataway, NJ
    All Hex Net Ross Tech Diagnostic tools qualify for FREE SHIPPING AND A FREE GIFT!
    Once you add a Hex Net Diagnostic Tool you can add a FREE GIFT to your order, the amount of the FREE GIFT should be deducted in your cart. (If the item is NOT deducted, it does not qualify).
    Please view the individual product's description for details. Limit of one (1) free offer per order. Cannot be combined with any other promotion.
    For instance,
    will qualify for the following free gifts, ON TOP of FREE SHIPPING!
    NEBO LARRY C LED WORK LIGHT
    By Nebo Tools
    The Larry is now BRIGHTER THAN EVER! Now, equipped with new COB LED technology, the LarryC outputs 170 lumens of intense light. The rotating magnetic clip gives you convenient hands-free lighting by attaching to virtually anything. The reinforced plastic body design is water and impact-resistant, making this light basically indestructible.
    LIGHT
    • High-power 170 lumen COB LED work light
    DESIGN
    • Water and impact-resistant
    • Ergonomic non-slip grip
    • 180º rotating magnetic clip
    • Protective LED housing
    OPERATION
    • Top-positioned, ON/OFF button
    BATTERIES
    • Powered by 3 AAA batteries (included)
    SPECS
    • Size:(H) 6.375” x (W) 0.55” x (D) 1.25”
    • 0.1870 lbs.
    NEBO WORKBRITE WORK LIGHT
    By Nebo Tools
    The NEBO WORKBRITE adapts to your work environment, making it the handiest of work lights. The WORKBRITE features three different ways to provide you with hands-free lighting for the task at hand: a hanging hook, a 200º pivoting stand and a magnetic base. Aside from being handy, the WORKBRITE is... well, BRIGHT! 200 lumens of pure white light are outputted by the 20 LED face, and for standard flashlight use, another 6 LEDs are located in the head, providing 60 lumens of brightness.
    For handheld use, the WORKBRITE features an ergonomic, non-slip grip. For added durability, the body is also completely impact and water-resistant. Whether you are under the hood, under the sink, or just out in the dark, the WORKBRITE works great for any application. WORKBRITE... It stands! It hooks! It sticks! It lights! It WORKS!
    FEATURES
    • 20 LEDs (face) provide 200 lumens of white light
    • Bulbs rated for 110,000+ hours of life
    • 6 LEDs (head) provide 60 lumens of white light
    • 60 meters viewing distance with 200 lumen setting
    • Three convenient hands-free lighting options: hanging hook, 200º pivoting stand & a magnetic base
    • Impact-resistant / Water-resistant
    SPECIFICATIONS
    • Settings – 6 LEDs - 60 lumens / 20 LEDs - 260 lumens
    • Run Time – 6 LEDs - 40 hours of continuous illumination / 20 LEDs - 15 hours of continuous illumination
    • Size – 9.125" (H) x 1.75" (W) x 1" (D)
    • Weight – 0.3 lbs
    • Batteries – 4 AAA Batteries (Included)
    NEBO 14-IN-1 ULTRA SOCKET
    By Nebo Tools
    The NEBO 14-in-1 Ultra Socket comes with 7 screwdriver bits and 5 sockets conveniently stored inside the handle. The head of the Ultra Socket tilts a full 180º and locks at 0°, 45°, and 90°, working perfectly as a nut driver for those hard to reach places. The handle is ergonomically designed to add comfort and grip to improve performance. The Ultra Socket features a reversible ratchet mechanism making it easier to loosen or tighten any bolt. The 14-in-1 Ultra Socket meets and exceeds ANSI standards and is created to withstand more than the normal wear and tear.
    DESIGN
    • Head tilts and locks at 0º, 45º & 90º
    • Reversible ratchet mechanism
    • Ergonomic reinforced plastic handle
    • Socket adapter
    • Sockets and bits stored inside handle
    SOCKETS
    • SAE: 1/4”, 9/32”, 5/16”, 11/32”, 3/8” & Socket adapter
    BITS
    • Phillips: P1-P3, Slotted: 3/16” & 1/4”, Torx: T15 & T20
    SPECS
    • 8.25” (L) x 1.5” (W)
    • 0.75 lbs.
    NEBO ULTRA SOCKET COMBINATION KIT
    By Nebo Tools
    The NEBO Ultra Socket Combination Kit comes with 19 sockets conveniently stored in SAE and Metric trays. The base of the Ultra Socket unscrews to reveal the stored screwdriver bits and magnetic ¼" bit holder. The head of the Ultra Socket tilts and locks at 0°, 45°, and 90°, working perfectly as a nut driver for those hard to reach places. The industrial strength ergonomic rubber handle design adds comfort and grip to improve performance. The Ultra Socket features a reversible ratchet mechanism making it easier to loosen or tighten any bolt. The NEBO Ultra Socket meets and exceeds ANSI standards and is created to withstand more than the normal wear and tear. Ultra Socket and components are all conveniently stored in a 600D Polyester carrying pouch. View Ultra Socket Combination Kit Brochure
    SOCKET SIZES
    • SAE: 1/4", 5/16", 11/32", 3/8", 7/16", 1/2", and 9/16"
    • Metric: 6mm, 8mm, 9mm, 10mm, 11mm, 13mm, and 14mm
    SCREWDRIVER BITS
    • Phillips: P1-P3
    • Slotted: 1/8", 3/16", ¼"
    • Hex: 1/8", 5/32", 7/32"
    • TORX: T15, T20, T25
    • Magnetic 1/4" bit holder
    FEATURES
    • Comes with 19 sockets, 12 screwdriver bits and ¼" magnetic bit adapter
    • Head tilts and locks at 0°, 45°, and 90°
    • Industrial strength ergonomic handle design
    • Exceeds ANSI standards
    • 600D Polyester carrying pouch
    SPECIFICATIONS
    • Length – 8"
    • Diameter – 1.375"
    • Weight – 1.6 lbs
    NEBO DUO 250+ LUMEN HEADLAMP
    By Nebo Tools
    The NEBO DUO Headlamp is an all-powerful, hands-free lighting solution. The push button on/off button allows you to easily cycle through the FOUR light modes: one white LED (250 Lumens), 2 COB strips (80 Lumens) or 2 RED COB strips in steady or beacon mode. The red LED is a low-signature light, which ensures stealth in the dark, enhances night vision and makes reading in little to no light possible. The light from the 250-lumen power LED has a spot beam distance of 122 meters. Its signature 2 strip COB design fully illuminates your immediate area with its wide flood beam. The DUO Headlamp is tough, reliable, lightweight and completely shock-proof.
    LIGHT
    • High-power 250 lumen LED spot light
    • 80 lumen COB flood light
    • Red 10 lumen COB flood light
    • Red beacon light
    LIGHT MODES
    • Spot Light (250 lumens) - 3.5 hours / 122 meters
    • COB Flood Light (80 lumens) - 7 hours / 13 meters
    • Red COB (10 lumens) - 8 hours / 4 meters
    • Red beacon light - 48 hours / visible over 1 mile
    DESIGN
    • Fully dimmable
    • Water and impact-resistant durable housing
    • Power memory setting
    • Direct-to-red feature
    OPERATION
    ACCESSORIES
    • Dual adjustable head strap
    BATTERIES
    SPECS
    • 0.2 lbs.
    • One size fits all
    will qualify for all of the gifts above, and the following... ON TOP of FREE SHIPPING!
    NEBO SLYDE
    By Nebo Tools
    Combining the best that NEBO has to offer, the SLYDE features a powerful LED flashlight and COB work light all in one. At first glance, the SLYDE appears to be a simple, strong flashlight, emitting 250 lumens of intense white light... and it is! However, you will see the SLYDE is much more. The body of the SLYDE conceals a powerful 190 lumen work light. To reveal the COB work light, just SLYDE to open!
    LIGHT
    • High-power 250 lumen LED flashlight
    • High-power 190 lumen COB work light
    LIGHT MODES
    • Flashlight: 250 Lumens - 2 Hours / 230 Meters
    • Work Light: 190 Lumens - 3.5 Hours / 18.5 Meters
    DESIGN
    • Anodized aircraft-grade aluminum; water and impact-resistant
    • Work light is concealed inside the flashlight body; just SLYDE to reveal
    • Powerful magnetic base
    OPERATION
    • Side-positioned ON/OFF button with Soft Touch Technology
    BATTERIES
    • Powered by 4 AAA batteries (included)
    SPECS
    • Length: 6.5” (compacted) / 9” (extended)
    • Diameter: Barrel – 1.3125” / Head – 1.625”
    U.S. PATENT PENDING
    NEBO TEMPRA IR THERMOMETER & SPOT LIGHT
    By Nebo Tools
    Not just for the professional, the TEMPRA can help save time and money at work, around the house or in the car. Use the laser-guided infrared thermometer to make sure your car engine is firing on all cylinders. Check your HVAC to ensure your home is cooling and heating efficiently. The TEMPRA, just one more way NEBO helps get the job done.
    LIGHT
    • High-power 1340 LUX LED spot light
    LASER
    • Red laser guide for accurate temperature scanning
    TEMPERATURE RANGE
    • -4ºF - 716ºF
    DESIGN
    • 4x adjustable zoom
    • Infrared lens
    • Laser pointer
    • Backlit LCD
    • Adjustable emissivity for different surface materials
    • Fahrenheit/Celsius conversion
    • Ergonomic handle
    • Low battery indicator
    • Data hold function
    OPERATION
    • Back-positioned ON/OFF button for spot light
    • Trigger for laser and temperature scan
    BATTERIES
    • Powered by 4 AA batteries (included)
    SPECS
    • 0.7 lbs.
    • (H) 7.625” x (W) 2” x (D) 4.25”
    Hugh
    Aug 22 2010
    Piscataway, NJ
    The perfect Holiday gift...
    Hugh
    Aug 22 2010
    Piscataway, NJ
    Hugh
    Aug 22 2010
    Piscataway, NJ
    Ross Tech Diagnostic Systems starting at $199.00 SHIPPED!
    Hugh
