Results 1 to 16 of 16
    Apr 06 2015
    Cleveland, Ohio
    emmanuele design springs on mag ride car
    anyone with these on an mag ride s3 experience low speed (parking lot) clunking from the front end? i currently have the new VWR springs installed and get a lot of clunking. install shop confirmed everything is correct, but has reported lots of mag ride customers getting these clunks. just wondering about the ED springs before i buy and try. thanks.
    Registered User Four Rings EmmanueleDesign's Avatar
    Feb 11 2014
    2000 Audi S4, 1995 Audi S6
    Anaheim, CA
    Quote Originally Posted by marsh1665 View Post
    Clunking will be from one of the following:
    - Top nut on the shock is not fully tightened, allowing the shock body to move.
    - Sway bar end link nut is not fully tightened
    - Spring geometry causes the coils to bind
    If you have ruled out the first two, I would take a look at the spring itself to see if there are any signs of rubbing (paint missing). The mag ride had a TSB for the rear clunking, but not the front. It should be silent if everything else is in order.
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    Please keep us updated. very interested in these vwr springs.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Apr 06 2015
    Cleveland, Ohio
    ill check the sways and the top nuts again---im pretty confident in the shop i got the install done at but you never know. ill also take a look at the coils. i suspect compression might be the culprit. other than this annoying clunking, the ride is really nice. firm but compliant and a great drop. it'll be a shame if i have to bail on them because of this. thanks.
    Apr 11 2012
    Apr 06 2015
    Cleveland, Ohio
    mine is in the front, post spring install
    Established Member Two Rings ahfunaki's Avatar
    May 23 2016
    Northeast Ohio
    I was getting this noise: https://www.youtube.com/watch?v=lkPxdvmtzxk
    Turns out it was the top nut on the front shock. I hit it with the impact gun while still on the car ( just popped the little black cap off of the strut tower ) and haven't had an issue since.
    I love my ED springs...
    2016 S3 Premium Plus | Glacier White Metallic Exterior | Black / Titanium Gray Interior | Black Optic | Technology | LED | B&O
    Emmanuele Design Springs | 15mm Spacers Front & Rear | aFe Magnum FORCE Stage-2 Pro 5R Intake | OEM Resonator Delete | AWE SwitchPath Exhaust Remote
    Apr 06 2015
    Cleveland, Ohio
    mine only occurs at parking lot speed when the wheel is turned. its almost like a steering rack issue, but how could that be caused by simply swapping springs?
    Veteran Member Four Rings phillyquattro's Avatar
    San Francisco, CA
    I had a similar issue to the one your describing, though there's no way for me to know if it's exactly the same as I can't hear the sound your car is making. Mine ended up being the upper strut mount bearing was mangled. If that's your issue ECS makes a "Heavy Duty Front Upper Strut Mount & Bearing Kit" or you could just replace it all with a camber plate kit....which is what I probably should have done.
    2019 GT3 Touring
    2019 SQ5 Premium+ (Build Thread)
    2016 S3 Premium+ (Build Thread)
    IG: brandongray
    Apr 06 2015
    Cleveland, Ohio
    thanks. thats a good idea. the shop who installed the springs put in new bearings when the did the job, but maybe this setup just needs a more heavy duty one to work. ill check this out
    Jun 27 2009
    2012 A5 S-Line
    Quebec city
    I have the ED springs on my 2016 S3 with my mag ride for 5000 miles. One of the best mod I have put on the car. The drop is perfect, the ride is more comfortable. Actually a lot more comfortable. No noise at all.
    2018 RS3
    Unitronic stage 1
    Apr 06 2015
    Cleveland, Ohio
    so i got the car in and installed the ECS heavy duty strut mount and bearing kit and swapped out the VW racing line springs with a set of ED. i must say, the difference is almost magical. the springs are amazing.drop is much more OEM+ in appearance and the ride is better than new. great product. i can't say enough. i have my car on swapalease bc of a company car, but im really considering keeping it now---its that good. thank you!!!!!
    Veteran Member Three Rings Food4Audis's Avatar
    Jan 17 2014
    Brea, CA
    I have the ED springs with mag ride and I also got the Rear Strut TSB taken care of and the service technician also adjusted the mag ride for my lowered springs. smooth sailing since
    2018 Graphite Metallic Prem Plus Q7 2.0T
    ACIE (Audi Club of the Inland Empire) Admin
    Instagram @food4audis
    2016 S3 / DPE Flowtech Wheeles / APR Stage 2 / Emmanuele Designs Lowering Springs / PURE carbon fiber accents / Neuspeed intake / Bull X exhaust / RS Grille
    2013 S5 V6 AG M580 Wheels / APR Stage 2 / AWE Touring Exhaust / Bilstein PSS10 / Eurocode Intake / RS Grille
    Apr 06 2015
    Cleveland, Ohio
    what adjustments did they make on the mag ride? did they give you any grief about the aftermarket springs?
    Aug 19 2016
    Southern, NH
    Quote Originally Posted by JimboS5 View Post
    I am also interested in what adjustments were made.
    Feb 11 2014
    Anaheim, CA
    Quote Originally Posted by Wr3ks_S3 View Post
    There is a relearning procedure for the dampers that can be performed by the dealer. Some have reported that the ride quality improved after this procedure.
