Results 1 to 7 of 7
    Senior Member Two Rings Riker's Avatar
    Oct 11 2016
    Tri-State Area
    2014 A4 - Shop Manuals & Maintenance Advice
    Hey what's going on, I recently snagged a 2014 2.0T A4 Premium Plus and I've been trying to find some shop manuals for the car. Does anyone know where I might be able to find these?
    In addition are there any weird maintenance quirks with these cars or it simply oil, plugs, etc.? Also curious to know if any of you guys are running Rotella T6 in the 2.0T's. Thanks in advance!
    EDIT: I was also curious about the typical mod schedule on these cars. I've been reading that the stock DV is a weak point, are there any other odds and ends that need to be cleaned up with these vehicles?
    Active Member Two Rings eclaytor's Avatar
    Dec 19 2015
    Richmond/VA
    Im just running mobile 1 syn 0w-40. Another maintenance item to check up on is cleaning out the carbon deposits. My car has 85k miles so its on my to do list.
    __________________________________________________ ________
    2012 A4 Phantom Black - Sline - 6MT - Solowerks - 2 child seats
    Veteran Member Four Rings Dub_prime's Avatar
    Sep 10 2012
    2010 A4, 2008 Passat, 2002 GTI
    Bham AL
    I searched high and low for a week for the service manual, and aside from a few hacked together copies online that aren't complete you can do alldatadiy.com or the official Audi service site. The Audi site is insanely expensive... alldatadiy can be had for $16-24/year depending on promo codes.
    Active Member Two Rings leftlanecruiser's Avatar
    Jul 30 2013
    2011 A4, Meteor Grey, Sport Package; 2012 Subaru Outback
    New Orleans
    Shop Manuals: https://erwin.audiusa.com/erwin/showHome.do
    Start an account and pay for minimum amount of time and then save all manuals as pdf. A 1-day account is $35. I did this for my friends B6 and my B8.
    Established Member Two Rings gstrouse's Avatar
    May 13 2007
    2012 VW Tiguan SEL 2015 F-150
    Northampton, PA
    Oct 11 2016
    Tri-State Area
    Quote Originally Posted by eclaytor View Post
    Sounds good, thanks for the info! Do you perform your own service? I'm not particularly fond of dealer service for basic maintenance. I'm curious to know if doing your own oil and plugs will cause me any problems if I go in for an unrelated service.
    Assuming I have receipts and documentation of the install/change I should be fine, and obviously the oil and filters will be Audi spec.
    Quote Originally Posted by Dub_prime View Post
    Yeah I came to the same conclusion, wasn't familiar about alldatadiy though. Thanks bud!
    Quote Originally Posted by leftlanecruiser View Post
    Great tips, thanks man!
    Thanks for the links, much appreciated!
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Change your oil and filter every 5000miles, only use VW spec approved oils, and OEM filters.
