Results 1 to 16 of 16
Thread: APR Stage1 v3.1
    Jul 24 2012
    Germany
    APR Stage1 v3.1
    Hello,
    my name is Kamil from Germany and i have a '2011 S4 6MT with APR Stage 1 v2.2. The car runs very well. I installed the tune at 28k km, now with 80k km and zero issues.
    I have seen there is a new Version v3.1 available for Stage 1.
    Is it worth to update respectively is there a noticeable increase in power ?
    Thank you
    Mar 01 2006
    Kitchener, ON
    I went from Stage II v2.? to Stage III v3.? and it was a noticeable change. At least that is what it felt like to me. Worth the cost to pay the authorized dealer IMO
    2023 Audi S3 / Stronic // Daytona Grey
    Past
    2018 VW Golf R // 6 MT // Deep Black Pearl
    2010 Audi S4 // Stronic // Phantom Black
    2001 Audi S4 // 6 MT // Light Silver Metallic
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Updating to the latest ecu/tcu software is going to be an improvement
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    Yes v3.1 is a massive improvement over v2, particularly the pump file. It is a free upgrade, probably just have to pay the flash labor fee at your shop
    Senior Member Three Rings Mat@1975's Avatar
    Jun 14 2015
    FRANCE
    Yes the Last update will be a nice improvement.
    Especially with your german high quality fuels( I am jealous. ..) like shell V power 100 or bp 102 as timing tables were set Very agressive.
    BR
    Mat
    Envoyé de mon SM-G850F en utilisant Tapatalk
    S4 B8.5 AVANT | S-Tronic | Full ADS | Sport Diff | Glacier White
    MRC Stage 2 Tune | MRC TCU Tune | AMS/Alpha Cooler| AWE + AFE filter intake with airbox hole
    KW HAS Springs | H&R Sway bar F&R | Custom 14 mm Front and (13 R / 16 L) mm Rear Spacers | CR-15 Strut Brace
    OEM Rotors | Michelin PSS 255/35/19
    Q5 calipers | Goodridge SS Lines | 2-pieces Girodisc Rotors Front & Rear
    Jul 21 2004
    South Florida
    Quote Originally Posted by VIPER86 View Post
    Hello,
    Thank you
    Keep in mind that most of the Audizine forum is USA based so we cant say what difference your update will make because we have different calibrations on the USA cars but generally when APR offers an update it is worthwhile to get it. You may want to give APR an email or PM though just to find out what the update entails. They can tell you with certainty
    Mike
    2018 Audi S5
    Gone-
    Jul 24 2012
    Germany
    I'm on v3.0 since Saturday and I like it. It feels smoother and more refined. In der lower rpms it feels slightly stronger.
    Overall its worth it.
    By the way, cold start feature is turned on.
    Veteran Member Three Rings Sean@APR's Avatar
    Feb 01 2013
    C7 S6
    Opelika, AL
    Yes! Go get it, you'll be happy you did. Maybe get a pulley too while you're at it. :)
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    Quote Originally Posted by Sean@APR View Post
    Yes! Go get it, you'll be happy you did. Maybe get a few pulley's too while you're at it. :)
    Corrected for you
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Veteran Member Four Rings Acejam's Avatar
    Dec 22 2009
    MA
    Is v3.1 newly released? I just got flashed Stage 1 ECU/TCU about 2 weeks ago...
    2014 Brilliant Black S4
    DSG / Prestige / Black Optics / Sport Diff / B&O / Carbon Atlas Inlays / Magma Leather
    Modifications: APR Stage 2 Dual Pulley + TCU, JHM 187mm Crank Pulley, APR Open Intake, APR CPS, AWE Touring Exhaust (90mm Silver), KW HAS, 034 Rear Sway, 034 Mount Inserts, Hawk HPS 5.0, S5 Rotors w/ PS4S (Summer), Peelers w/ LM-32's (Winter)
    Jul 24 2012
    Germany
    Quote Originally Posted by Acejam View Post
    v3.1 was Stage 2 only i think.
    v3.0 Stage 1
    Senior Member Two Rings SilvA4Q's Avatar
    May 27 2009
    '17 Audi Q7 3.0T P+
    Houston, Texas
    Is there a way to tell what version tune you have? I guess it would likely depend on the release date of the update and when you got flashed I guess. I was flashed in August and don't know what version I received.
    Current:
    '14 S4 Premium Plus
    ll S Tronic ll Glacier White ll Bang & Olufsen ll Sports Differential ll Black Optics ll APR Stage 1 ll CR-15 ll H&R Front and Rear Sways ll AWE Touring Exhaust ll Afe Cold Air Intake ll
    Veteran Member Four Rings stereojorge's Avatar
    Oct 15 2013
    2014 Audi S4 P+ DSG, 2015 Audi SQ5 Prestige
    Tampa, Florida
    Quote Originally Posted by SilvA4Q View Post
    Same here!
    '14 Misano Red S4/APR Stage II+ DP ECU+TCU & UC/187mm Crank & AWE 57.55mm SC Pulleys/CMD Charge Chamber Intake/KW V1 Coilovers/EuroCode Sway Bars & AluKreuz/CR-15/034 Trans Mount/Apikol Rear Diff Mount/ECS Rear Diff Carrier Mounts/CMD Test Pipes/AWE Reso.Downpipes/AWE Track Exhaust 102mm Tips/Vossen HF-3 19" x 9.5"/Michelin PS4S'/StopTech Drilled Rotors/Akebono Euro Ceramic Pads/StopTech SS Lines
    Also: 2015 SQ5 Prestige | 2003 A4 Avant Quattro 6MT
    Previous: 2010 S4 P+ | 2008 A4 S-Line
    Feb 01 2013
    C7 S6
    Opelika, AL
    You've got the latest released version. He's well behind that.
    Oct 27 2010
    Michigan
    My apr dealer always indicated the version+maps flashed on all receipts/work orders I have from them.
    Established Member Two Rings iant's Avatar
    Jun 10 2012
    Newport, South Wales, UK
    I'm on Stage 2 v3.0 Sean (as of June 2015) is there now a newer version, v3.1 maybe reading this thread and if so what are the gains over v3.0 mate
