Results 1 to 33 of 33
    Established Member Two Rings MCMLXIX's Avatar
    Mar 11 2016
    Las Vegas, NV
    New to me 2016 A8L 4.0L Sport
    Just picked up a Mythos Black 2016 A8L with the 4.0L V8T at 455hp / 444tq.
    Drove it home today.. still learning
    I purchased the car from CarMax. I found a business card for the local Audi dealer so I test drove the car from CarMax to Audi to get the scoop. Turns out the previous owner WON the car at a golf tournament for a Hole in One shot. He added the wheel you see in the pictures when the car was delivered back in June and drove a whole 6,102 miles before giving it to CarMax... I am now the proud second owner...
    2016 A8L 4.0T Sport - Mythos Black Click HERE
    May 10 2015
    Pittsburgh PA
    Gorgeous car, the 4.0T is a magnificent engine! Enjoy!
    Any plans to modify it, or is it going to stay stock?
    Mar 11 2016
    Las Vegas, NV
    Stock-ish... Maybe lower a little with some programming, paint the calipers red and throw on a K&N filter...
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Wow, what a deal for the previous owner! Congrats on a beautiful car. What size are the wheels they look a bit small
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    I wouldn't have traded that beauty in if I won it like that... but great pickup for you! Congrats!
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    Feb 09 2016
    Houston
    More congrats on a beautiful car...
    1969?
    2014 A8L 4.0T - RS7 Turbos, DS1 Stage 3 Tune, Full E85, Stock Downpipes, Stock LPFP. 10.72@130.21 mph
    Mar 22 2016
    Las Vegas, NV
    Great Find!
    Mar 11 2016
    Las Vegas, NV
    Quote Originally Posted by Chris Morales View Post
    1969?
    I have a 1969 Camaro project and that't what started my screen name on all the forums...
    Mar 11 2016
    Las Vegas, NV
    Quote Originally Posted by q5 dave View Post
    21" OEM Audi wheels running 275/35Z21 Dunlop
    Mar 11 2016
    Las Vegas, NV
    I need more exhaust sound. It has the electric dual valves on the mufflers. Can these be removed without throwing any codes?
    Feb 09 2016
    Houston
    Quote Originally Posted by MCMLXIX View Post
    Don't remove them...unplug them. I noted that the default position on mine when they are unplugged is open valves. Double check that on yours. You will get "soft" codes from unplugging them...not codes that will trip a CEL or affect performance, but codes the dealer will see when you bring it in.
    That said, this won't give you much more exhaust sound. It is frustrating how quiet Audi thinks these cars need to be; I hate it as well. I don't think there are existing cat back exhaust options for the A8L. You can have the center resonator removed, but that won't affect sound much either from what I've read. You'll have to go with a custom option - e.g., replacing the rear mufflers or, if you're fortunate enough to have a mandrel bending exhaust shop around, a full custom exhaust. I'm going to have a custom mandrel bent exhaust made for my car at a local shop soon.
    Mar 11 2016
    Las Vegas, NV
    Plan A: straight pipe at the factory connection to remove the center resonator and both mufflers (hence the unplug on the valves)
    Plan B: removing the two individual resonators and the center resonator but leave the actual mufflers and keep the valves.
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    I wonder how that will work out. There's so much sound deadening the cabin is dead silent even at the speed limiter LOL
    Mar 11 2016
    Las Vegas, NV
    Maybe I'll unplug the connectors over the weekend and see what happens.....
    Mar 11 2007
    Colorado Springs
    Just beautiful!
    2022 Q8 S line Prestige Stock
    2012 A7Plus APR Stage II+ UC
    2012 A8L 4.2
    Still own them all...
    Mar 11 2016
    Las Vegas, NV
    Quote Originally Posted by A6sport View Post
    Just beautiful!
    Thanks.
    Its actually been raining in Las Vegas so I haven't crawled under to unplug the muffler flaps.... but I've been advised that they will flag in the system but not throw a CEL light.
    Next I've been researching the VCDS codes that let you change things that aren't enables from the factory...
    * Needle Sweep
    * Operate windows from the remote
    * Play DVD while in motion
    I would also like to find out if I can change the defaults for a few things...
    - My car has an Auto feature for the LED headlights that's not default to being active
    - I would like the radio to display the current channel as default and start in the Preset List
    - I would like to be able to push button start the car without needing to apply the brake pedal
    Veteran Member Four Rings nadroj81's Avatar
    Feb 12 2004
    Albany
    supersprint makes a center section exhaust, resonated and non. i think they are $775-1000. The mufflers are what cost a lot. 700-1200 depending on single tip or power loop. Supersprint.us They don't list all of the possible parts. Go to the italy supersprint site and you will get all the part numbers.
    Registered User Four Rings mike@vossen's Avatar
    Jan 23 2013
    Miami | Atlanta | Kingston
    Nice pickup..the S8/Sport bits completely change the look....much much better
    Mar 11 2016
    Las Vegas, NV
    Quote Originally Posted by nadroj81 View Post
    I can have a local shop handle a delete with some mandrel bent pipe for about half of the supersprint price...
    My only concerns are the sound when its done and if the factory muffler will be too restrictive
    Mar 11 2016
    Las Vegas, NV
    Quote Originally Posted by mike@vossen View Post
    Thanks Mike. I really wanted the S8 Plus but its out of my reach financially.
    I have been going back and forth with adding a small lip to the trunk. I think I want the stealth look and will remove the emblems, maybe drop it an inch or so with links and call it a day.
    Are you coming out to Vegas for SEMA?
    Mar 11 2016
    Las Vegas, NV
    Does anyone know what the diameter of the exhaust is that goes into the center suitcase style resonator? I would like to bring my own X pipe with me when I have it removed.
    What is our exhaust made of? Stainless steel or mild steel?
    Mar 11 2016
    Las Vegas, NV
    some quick pics in front of the house...
    Mar 11 2016
    Las Vegas, NV
    Went on a cruise with the Audi Club of Las Vegas to Death Valley on Sunday the 13th...
    https://youtu.be/7OytcxOfw00
    Veteran Member Four Rings OmaHahn's Avatar
    Apr 07 2011
    1st owner '64 1/2 Ford Mustang convertible D-Code (dads)
    Nebraska
    Must have been one hell of a golf tourney to give that away!! My friends and I throw an annual golf tourney with hole-in-one prizes and the insurance costs on some of the hole prizes are crazy - can't imagine the prize insurance on a 2016 A8L!! Great car, enjoy!
    2009 A4 3.2 V6 - sold
    2014 Ford SHO, 3.5 twin turbo with mods, 490WHP/545WTQ - sold
    2021 Dodge Durango SRT
    1964 1/2 Ford Mustang convertible, D-Code (original owner, Dad's ride I'm storing)
    Feb 25 2014
    Texas
    What are the specs on those wheels? 21x9 ET35? Any chance you would be willing to sell them?
    Beautiful car!
    Mickey (AKA: AudiS4B8)
    Instagram: ze_nardo6
    10.65 @ 129mph
    Mar 11 2016
    Las Vegas, NV
    Quote Originally Posted by AudiS4B8 View Post
    Beautiful car!
    Thanks. Loving the car so far.
    I have been trying to find out the specs on the wheels including the weight...
    Mar 11 2016
    Las Vegas, NV
    after a quick wash....
    Mar 11 2016
    Las Vegas, NV
    Last Espresso & Exotics show for the year...
    .. and my new Audi flag...
    Apr 07 2011
    Nebraska
    Did you race that Lambo? I bet it would actually be closer than one would think!
    Mar 11 2016
    Las Vegas, NV
    I picked up some lowering links from Germany. Hope to have them on the car by the weekend.
    I just need to close the gap between the tire and the wheel well.
    Mar 11 2016
    Las Vegas, NV
    Closed the gap. May drop a little more but at least it doesn't look like a 4x4..... just Quattro now....
    before
    after ... a little over 1 inch drop
    Apr 07 2011
    Nebraska
    That looks great!!! Perfect!
    Active Member One Ring Bozz6363's Avatar
    Jul 03 2014
    Singapore
    before
    Beautiful after lower so much nicer
