Results 1 to 16 of 16
    Sep 25 2011
    Ohio
    2001 A4 2.8 quattro 5 spd 170k
    $4000 obo, located in Akron/Cleveland area OHIO
    LINK: https://cargur.us/dsvlt
    Behold, one of the cleanest B5 A4's you will find. Interior 9.5/10, Exterior 8/10 (no rust!)
    Service records and summer/winter tires+wheels included!
    5 speed manual, all wheel drive, everything on it works, timing belt and water pump service done April 2016, and every seal in the engine was replaced by the previous owner, motor pulled, all seals done, reinstalled. No accidents from what I can tell.
    I bought this car in April 2016 as a backup car for the rest of winter, it's served me well and I'm selling it because I just got a new truck.
    Recently repaired/replaced (2016):
    Timing belt and water pump service, including tensioners (April)
    LF axle and wheel bearing (May)
    RF lower forward control arm (May)
    Trunk struts x2
    Coolant flush
    misc. dry-rotted vacuum lines
    New Conti Extreme Contact DW tires (less than 10k on them)
    cabin air filter (April)
    engine air filter (April)
    Powder coated stock wheels including spare "kingsport gray"
    rear sway bar links x2 (June)
    LR axle (June)
    rear alignment bolts x4 (June)
    regular oil changes with Mobil1 5w30 and Mann filters every 4k, it is due for another one soon.
    New Spark plugs/wires, it had a rough idle and this fixed it.
    New washer pump
    PS forward pos. 02 sensor (Dec 16)
    PS rear wheel bearing (Jan 17)
    The bad:
    The DIS (display in the cluster) has dead pixels but can mostly still be read...this is a common problem for these cars if you aren't familiar.
    The rear bumper could use a respray because it has ugly touch up paint marks on it, there are also minor dings and a few scratches/chips from over the years which are all within acceptable condition for a car this old. (other exterior flaws also pictured)
    Senior Member Three Rings mfdk's Avatar
    Jul 25 2012
    A4 B5 V6 2.8l
    Fort Mill, SC
    Damn it, i wish i was a little closer
    Mar 10 2016
    extremely clean car man, well specced too!
    '01 Audi A4 1.8TQM - stage 2 daily
    '95 BMW M3 Coupe S52 swap - RIP
    '01 Audi S4 K04 Stage 3 - stolen
    Sep 25 2011
    Ohio
    Bump still available,
    Sep 25 2011
    Ohio
    BUMP
    Sep 25 2011
    Ohio
    bump
    Sep 25 2011
    Ohio
    bump, price drop.
    Sep 25 2011
    Ohio
    bump
    Sep 25 2011
    Ohio
    bump
    Sep 25 2011
    Ohio
    bump still available
    Sep 25 2011
    Ohio
    bump, price drop, miles updated
    Sep 25 2011
    Ohio
    bump still FS
    Sep 25 2011
    Ohio
    bump!
    Sep 25 2011
    Ohio
    bump!!!!
    Senior Member Three Rings TheRedGlacier's Avatar
    Oct 31 2015
    1994 Firebird Trans Am GT 6MT
    New York
    Hey, no offense, but you should probably drop your price down a few hundred dollars. $4000 for a 2.8, which is generally the less desirable engine around here, with 170k miles is asking a bit too much. Figure you could buy an S4 for $4k. Again, no offense, maybe post a thumbnail here from the listing in the original post. Good luck with the sale! Make sure she finds a good home!
    2001 A4 TQMS
    Equus boost gauge, GIAC X Tune, 007 Clone, DV cold side relocation, N249 Bypass, PROPER intake heatshield.
    __________________________________________________
    Both my in-dash cupholder, and my ashtray work. That's good enough for me!
    Sep 25 2011
    Ohio
    Quote Originally Posted by TheRedGlacier View Post
    Thats why the price is OBO
