Results 1 to 27 of 27
    Mar 05 2013
    CA
    Tired windshield
    Any input?
    The second light hits it (ie sun, headlights) it turns opaque.
    Quote Originally Posted by Johnny1.8T View Post
    I've got the part number for the windshield if you want to shop around...
    8E0-845-099-P-NVB
    I just had mine installed this past friday. After having a windshield that looks like it got hit with a sand blaster (previous owner did a lot of highway driving maybe..?) WOW. Having a brand spankin' new windshield is amazing. I literally got a headache during my first drive after installation because it was so clear!
    Dec 05 2007
    Try to clay bar it see if it makes a difference.
    Jul 14 2009
    Pasadena
    just replace it. less of a headache then trying to refinish or polish out. its ~250 via safelite
    Widebody 19 Audi SQ5 ABT|HRE|034|WAGNER - GONE
    21 RS6 STERTMAN|HRE
    IG: @matthewee
    Dec 05 2007
    Worth a chance for like $20 and maybe an hour worth of work. And if it happens again then what, replace it again?!?!
    Feb 12 2008
    Michigan
    You can spray with glass cleaner or soapy water and scrape it with a razor blade or use 0000 grade steel wool, it won't make it brand new but will get all the crap off that plain washing can't do, similar to clay barring it
    Jul 14 2009
    Pasadena
    i feel like this is only something that would occur every 5-10 years.
    21 RS6 STERTMAN|HRE
    IG: @matthewee
    Dec 05 2007
    Is that dominatrix leather head garment OSHA approved? Clearly that PPE for eye protection is ANSI Z87 rated.
    Edit: And...now my post makes absolutely no sense. Reply post intended for removed.
    Veteran Member Four Rings MurkyRivers_A4's Avatar
    Dec 17 2009
    Tools, boxes of random car parts, 55 gal drum of used oil
    Kentucky
    Dont worry, I saw it. I was trying to reply with quote since Spike likes to delete his stuff.
    2015 Daytona Grey Audi S4 | DSG
    2013 Ibis White Audi A4 | Tip
    2006 Brilliant Black A4 Titanium | 6 speed
    Dec 05 2007
    Cool! Crazy man post is no longer crazy post.
    Jan 24 2010
    Paramus,NJ USA
    This!!!!This is a old skool detailers trick to get the windshield spotless and looking like new!!Although im not sure the steel wool will do much in your case its still worth a shot.If you can catch a fingernail in those scratches you wount be able to polish it out.
    Quote Originally Posted by Fast4esT View Post
    Ziddy Autowerks
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    I've tried polishing out windshields in the past and it just isn't worth the effort. If a clay bar doesn't make any significant difference i would just replace the windshield. You will be amazed at what a different outlook on life you will have with a fresh windshield;-) In my area Safelite uses Sekurit glass which is OEM and will replace it for $250.
    Veteran Member Three Rings john_gonzo's Avatar
    Feb 03 2009
    Florida
    Word to the wise - check your following distance. Backing off a bit will decrease the sandblasting.
    Spike00513, this is not directed at you. This just seems like a good place to mention it.
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    I have polished out small lines using cerium oxide and a decent power buffer. Agreed, lots of work. Mine was only a single scratch major scratch, however I did cleanup a few smaller marks. Easily four hours of work with large buffer. Super messy job.
    Jun 23 2008
    Your insurance doesn't cover new windshields? That will easily pass for a new windshield due to safety hazard.
    Jul 14 2009
    Pasadena
    dats wut i saiddddddddd
    21 RS6 STERTMAN|HRE
    IG: @matthewee
    Dec 05 2007
    Not saying at all that buying a windshield won't fix it. But...it is worth a clay bar trial before spending money on a new windshield. Not sure what others are seeing, but he isn't talking about that one larger scratch or the dirty streaks left by his wipers (which seems need replacing BTW). I am looking at what is boxed in red. And more throughout the windshield, yet not as visible. That is why people clay bar their windshield to begin with. I'll be doing mine before winter hits. If he blasts the heat on his front windshield, it goes away. Unless I totally missed it.
    Veteran Member Four Rings Furly's Avatar
    Dec 19 2013
    Quote Originally Posted by Spike00513 View Post
    I was going to ask
    Quoted before spike deletes his post for no reason
    Audi Club Bay Area
    Feb 12 2008
    Michigan
    Problem is when you drive into the sunlight and it glares off all the tiny pits in the glass. I think that can be cleaned up a good chunk but won't clear it away.
    Dec 05 2007
    Quote Originally Posted by Furly View Post
    I spotted one he deleted. Seems he researched this quite intensively and was just asling for suggestions. Pretty sure he already has a plan in mind, and wanted opinions on the matter along with what brand to go with due to pros and cons of each brand.
    My opinion still stands. 1-3 hrs of work and $20 of supplies is well worth the gamble before spending money on a replacement. And who knows the quality of work that will be performed once he takes that plunge. I personallly don't like Safelite and they replaced mine couple years back. Replaced my mother's couple years back (I think) and she was disgusted by how they put the panels back together. Think she even went back to have them correct it. Next time, using a reputable shop my friend is taking over from his pops. And will use whatever glass he suggests (also a modder who fab welded my old smic. built a sweet mini chopper too).
    Jan 06 2009
    Take a look at Larry@AMMO NYC on YouTube. He has some good glass cleaning videos. I use the razor blade technique a couple times a year with good results but it won't repair the damage you are seeing. Neither will a clay bar. For that you need extensive compounding but for the effort and cost of new glass, just replace it. If you do replace it, don't use anything other than Saint-Gobain Sekurit glass or you will be disappointed.
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Dec 28 2006
    Western Maryland
    Sekurit for sure. Do not let anyone install a PPG windshield!!
    Mar 05 2013
    CA
    Quote Originally Posted by DownhillA4 View Post
    Should it? They said it's wear-and-tear. And that even in the case of chips/cracks, you still pay out of pocket because it costs less than the deductible.
    Dec 17 2009
    Kentucky
    Deductibles should not be needed when replacing a windshield, at least not with my insurance. Its a safety thing and most insurances will replace it as long as you have comprehensive coverage and the glass can be replaced with a company in their network.
    Dec 05 2007
    Check your coverage to see if it has glass repair included in your comprehensive. I did at the time (car is too old to treat like a unicorn's droppings, and now just have collision) and paid nothing. Reason for my repair was for a chip that grew to a crack (held off to long on filling). During that time also had towing covered under my plan, but am a AAA+ Gold member.
    To state the obvious, last thing insurance companies want to do is come out their pockets. Just be sure he isn't taking advantage of you and is correct in his assessment. Look into your coverage yourself.
    Jun 23 2008
    Some. I pay a $100 deductible for a brand new windshield, installed.
    Quote Originally Posted by MurkyRivers_A4 View Post
    Truth.
    Mar 28 2015
    My opinion still stands. 1-3 hrs of work and $20 of supplies is well worth the gamble before spending money on a replacement. And who knows the quality of work that will be performed once he takes that plunge. I personally don't like Safe-lite and they replaced mine couple years back. Replaced my mother's couple years back (I think) and she was disgusted by how they put the panels back together. Think she even went back to have them correct it. Next time, using a reputable shop my friend is taking over from his pops. And will use whatever glass he suggests (also a modder who fab welded my old smic. built a sweet mini chopper too).
    I agree it will clean up. My experience is that using a buffing wheel and cerium oxide works, but it takes a while and is pretty messy. Pretty much the polish gets everywhere. That said, if you have a few hours, I would go for it.
    http://www.garagejournal.com/forum/s...d.php?t=167565
    http://www.garagejournal.com/forum/s...d.php?t=141951
    Jun 26 2015
    Tampa, FL
    This varies by state.
