Results 1 to 11 of 11
    Established Member Two Rings rcz22's Avatar
    Aug 19 2015
    2014 Cherokee Overland, 2011 Ducati 848 EVO
    New Jersey
    B8.5 Iphone 7 bluetooth issue
    hey everyone,
    I believe there is a thread about some issues with the new iPhone 7 but I couldn't find it. My particular issue is sporadic - sometimes when connecting via bluetooth the MMI shows a call being made to my number - however the phone is not in use...and I cannot end the call, so its stuck with just the time counter increasing every second. And in the dash display at the top it just reads "My Number" with the phone icon. The only way to disable this is to turn off Bluetooth on the phone.
    I haven't found any pattern for recreating this same error all the time, seems random. Wasn't sure if anyone else has also experienced this if so, please don't be shy.
    Its super annoying - next step is to remove the phone completely from the MMI and re-pair, but I would hope there is a better solution.
    2014 S4 / Moonlight Blue Metallic / Prestige / Navigation / B&O / JL10W6 custom enclosure + Alpine Amp / Black Optics / Sports Differential / DSG | 19" Peelers / Ziza LED Interior / 35% Tint / VLED VX3 Fogs / CR-15 /
    AWE Touring Exhaust / ECS Luft-Technik Carbon Intake
    Jan 11 2012
    07 LBZ Duramax, B8.5 S4 6MT, 05 RC51
    Nashua, NH
    Is the MMI software the most up to date?
    I have a similar issue with my iPhone 6 and it displaying the actual song / album information every time I am playing music from my phone.
    I know there is an update for Navi, and maybe it touches on some other components of the MMI system?
    b8.5 S4 PP 6MT || CF Inlays || Alcantara || Sport Diff || Roc - Euro || AWE Non-Res Dp + STaSIS Challenge || CR15 || 034 Inserts (Trans/Diff/Subframe)
    b6 04 S4 6MT || Daily || VMR 705 || Nitto || JHM Piggies || Fast Intentions || - Sold
    b6 A4 Sport 6MT || AMB / AEB || IE || JE || GT28R || AWE Tune || 480cc || R8 Coils || RS4 Clutch || Billy Boat || Podi || - Sold
    Established Member Two Rings brunogomes's Avatar
    Apr 21 2015
    New Jersey
    On my 2013 B8.5 S5 I've had zero issues and I connect my iPhone 7 bluetooth at least twice a day on the way to and back from work. (Have never updated anything on the car)
    Jun 17 2010
    Madison WI
    Quote Originally Posted by rcz22 View Post
    hey everyone,
    I had this exact same scenario happen to me in my 2015 with an iphone 7 yesterday. After rebooting my phone and MMI multiple times each, I did delete the bluetooth pairing and then re-paired, all has been working fine since.
    2015 6MT S4, EPL Stage 2 no more...
    2010 6MT S4, APR Stage 2 no more...
    Aug 23 2015
    Texas
    There have been a few Bluetooth issues noted in the early versions of iOS 10. So far they seem resolved on 10.1 beta.
    Mar 21 2015
    OP mine has done the exact same thing one time so far. I don't think updated mmi software will make a difference.
    Aug 19 2015
    New Jersey
    Thanks everyone - glad its not just me. After writing this post, it hasn't happened since. weird. If I notice it again I'll try unpairing/pairing....
    I did see a lot on the google around BMW owners having issues with IOS 10 and their car bluetooth systems. Apple is working on it...
    Veteran Member Three Rings Jv218's Avatar
    Jun 10 2015
    15 S4, 2012 civic
    Boston
    Is anyone that is currently using a iPhone 7 and streams music via tune2air having play issues?
    15 Ibis white, Dsg, P+, magma interior, F1 35% pinnacle tint, ECS RS4 grill, AWE Track 90mm tip, 19x9.5inch HRE FF01, ECS Carbon Intake
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Not sure, but I believe the key is to delete all current bluetooth devices before pairing your new phone. Did that and then paired my tune2air. No skipping and phone seems to work just fine. Never did a software update on my 2011.
    Veteran Member Three Rings sirsycott's Avatar
    Sep 20 2013
    Orange County/CA
    had this on my iphone when i went to ios 10
    would consistently disconnect bluetooth when streamming music
    the trick was to remove the device from bluetooth on mmi
    then go into phone and forget the mmi
    numerous other threads point to resetting network settings helps
    but i got away with just removing and deleting the bluetooth tether off mmi and then off iphone
    Aug 19 2015
    New Jersey
    Quote Originally Posted by sirsycott View Post
    After some more testing - I also found the connection to streaming music (for me Spotify). If I was listening at the time I turned off the car, and closed the app on the phone - the next time I started the car the MMI would search for the song I was just listening to. Now with the HTC M8 (previous phone) spotify would load back up and start playing - seems like with the iPhone its hit or miss...sometimes it did and music played, and sometimes it did not and I get the My Number across the screen.
    so if I loaded up Spotify and selected a song - the my number went away and music started streaming. I'll continue to test...
