Results 1 to 11 of 11
    Apr 21 2016
    S6 Steering Wheel
    Hey guys,
    Can someone please tell me if the 2016-2017 Audi S6 Flat bottom steering wheel is thicker than the S6 Round steering wheel (cold weather package)?
    Or are they absolutely the same thickness, apart for the flat bottom.
    Someone told me the flat bottom steering wheel on the S6 is same thickness as the RS7?!?!?! couldn't verify this.
    thanks!
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Flat bottoms are thicker.
    I have an SQ5 with the flat bottom and it is thicker than my S6 with cold weather.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Mar 18 2014
    Salt Lake City Utah
    Quote Originally Posted by bdwonder View Post
    Hey guys,
    thanks!
    If interested I do have an '16 s7 flat bottom for sake although it does not include the airbag .
    2016 S7 Daytona gray, arras red interior
    RS7 performance steering wheel
    9500ci Passport with mid-city enginering module integrated into instrument display
    Resonator delete with x-pipe
    Apr 21 2016
    Quote Originally Posted by gk1 View Post
    are the steering wheels same for S6 and SQ5, in terms of flat bottom width?
    I believe the flat bottom are also little softer and fuller?
    Nov 27 2012
    Houston/Texas
    S6 Steering Wheel
    Feels a lot better than the round. I recently swapped mine. Used the VAG to disable the heating so it wouldn't throw a code when checking. The thickness is the same as the RS7.
    2016 S6 | Prestige | Daytona Grey Metallic (APR Stage 1 ECU/TCU, AWE Exhaust, Eurocode Sways and Links)
    Aug 06 2014
    NJ->CO
    I believe all flat bottom wheels are the same thickness regardless of model. Someone else would need to confirm.
    Not sure what you mean by softer or fuller? They can be many different leathers, or perforations, or alcantara if that's what you mean...
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Apr 21 2016
    Quote Originally Posted by Webtoker View Post
    Apr 21 2016
    got it. Thanks.
    I had the opportunity to see the round heated steering wheel, and the one for an RS7 at a dealership. And the RS7 one was perforated, of course, but felt also meatier if that makes sense. The round one felt very bony, like skin on bone. I felt all the hard materials underneath, like the metal or plastic, whatever is underneath.
    The RS7 one felt more plump. I didn't feel any hard metals or etc.
    Aug 06 2014
    NJ->CO
    got it. Thanks.
    Yep, flat bottom definitely feels better than round but you give up heat since there are no flat bottom heated wheels yet.
    If I was doing it over again and getting a 2016+ I would pass on the cold weather package to stick with the nice thick flat bottom.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Q7, Q7, F-type manual
    Since we have a steering wheel thread, I have a related but different question. Will a c7.5 heated wheel with paddles fit a c7 with no heat and no paddles? I am primarily interested in the paddles, but heat would be nice too. I can code the changes, but wondering if any physical changes are needed.
    Feb 11 2016
    earth
    Quote Originally Posted by andrewaw View Post
    Do you know if the c7 round airbag will fit?
