- VCG
- CCT
- Oil sump service (2x because I got paranoid)
- Timing belt/tensioner/water pump/acc belt (2x)
- Idler Pulley
- Accessory Belt Tensioner
- Vacuum Lines
- Clutch (with transmission service)
- Control Arms (left: upper-leading, upper-trailing, lower-leading; right: lower-trailing)
- Wheel Bearings (both front)
- Brakes (4x?)
- Brake Lines -> Stainless Steel
- Rebuild after hitting a deer (radiator, AC condenser, bi-xenons, hood, fan cowl/support)
- Exhaust (went to APR stealth and now back to stock + 034 cat)
- Coil Packs (2x) and Spark Plugs
- Motor mounts
- Engine speed sensor
- O2 sensor
- Thermostat
- Rear coolant flange
- Fuel filter
- Auto RX treatment
I have a few questions that I've been wondering about, so if anyone has any wisdom, feel free to shed some light on any of these:
1. Judging by the list above, is there anything that jumps out as, "He hasn't done X yet -- that's going to fail soon!"?
2. Does anyone know a source for OEM sport-package suspension components? Or should I get something else to replace mine? I'm currently on the original sport-package parts. They aren't unbearable, still fairly tight, but when I drive a new car I realize maybe I'm missing something
3. My auto-dimming mirrors don't seem to do "enough". Is this common? When I shine a flashlight into it, it turns very dark, but driving at night blinds me and they don't seem to tint as much.
4. The lower half of my engine block is somewhat oily. It loses about a quart per 3000 miles, but I've just been accepting it. Is there anything I should do about this? It also smells when idling faintly of oil.
Thanks in advance!
