    Jul 14 2016
    Vancouver
    wheel expert advice needed: Does S4 wheels fit on 2017 A4?
    Hi everyone,
    The 2015 S4 wheels specs:
    Genuine OEM Audi S4 Titanium matte 5-arm Rotor 19" Wheels
    8K0601025AR
    Made in Germany
    Ronal 2728
    Rim size: 8.5 J x 19"
    Wheel bolt circle: 5x112
    Wheel offset: ET43
    Bore: 66.67
    Tires: OEM Continental SportContact3 Summer tires RO1 - Audi spec
    Tire size: 255/35 R19 96Y XLs
    Will this fit on my new B9 A4?
    Feb 16 2016
    Belgium
    My s-line wheels on B9 are 18 x 8 ET 40.
    If you want to be sure about that take a wheel off and check the inner side of the rim,info should be on there
    i wouldn see any problem fitting a 8,5 x 19 ET 43,meaning the wheel will be 0.5 inch wider and will be tucked in 3 mm more.
    if you have an ET 40 they leave a tolerance for -5 + 5,meaning ET 35/ET 45 in youre case
    Mar 26 2016
    I'm looking to do the same. Did the wheels fit? Pics would be awesome!
    Active Member One Ring vaca's Avatar
    Apr 04 2017
    msk
    hello!
    8x19 et42 - be a good?
    Established Member Two Rings Four rings fan's Avatar
    Sep 10 2016
    Florida
    Here's some info so you'll never have to be spoon fed again.
    B9 A4 oem 18's .... 18x8 +40
    B9 A4 oem 19's ... 19x8.5 +40
    http://www.1010tires.com/Tools/Wheel-Offset-Calculator
    Your 19x8 +42 will tuck 8mm more than the oem 19's. Not a good look unless you run spacers. A 10mm spacer at minimum if your at stock height and more if your lowered.
    Also Audi's run ball seat lug bolts. Most aftermarket wheels not specifically for Audi's run conical seat lug bolts.
    B9 A4 hub bore is 66.56.
    B9 A4 oem lug bolt size is 14 x 1.5 x 28mm (ball seat)
    2018 S6 Mythos Black Prestige
