Results 1 to 9 of 9
    Aug 18 2012
    stage 3 b5 s4 (build in progress) / e46 M3
    Bay Area
    looking to buy a built 2.7t engine (KO4's??) + Clutch Kit
    So here's the deal. My engine needs some work done along with the clutch going out soon so I figure if I can find a good deal why not...
    Looking for 400whp engine and/or clutch set up. Let me know what you've got. Clutch Kit must be able to support big power.
    Senior Member Three Rings dbasaiint's Avatar
    Sep 20 2011
    86 Porsche 944 n/a
    illinois
    define built, like upgraded turbos or, rods, pistons, heads, valvetrain ect setup for max hp.
    #76 of 250 S4 B7 25Quattro
    ^Build Thread! http://www.audizine.com/forum/showth...swap-STK-Build
    Polar White A4 B6 Stage III
    Veteran Member Four Rings JMTx86's Avatar
    Oct 03 2005
    I have a FX400 6 puck for sale $600 + shipping, I also have full stage 3 components, ko4's, inlets, maf, fueling, daz tune, etc. Everything you'd need to be up and running.
    00 b5 s4 Single turbo
    1969 Chevy Nova 396 (Full resto, completed in 2016)
    1969 Chevy Camaro 454 (built 454/th400, body is a work in progress)
    11 Chevy z71 5.3 shop truck (Vortech V2 build in progress)
    Aug 18 2012
    Bay Area
    Quote Originally Posted by JMTx86 View Post
    I am looking for a clutch and will keep this clutch in mind. As for stage 3 components I'm looking for an engine as well. If I come around to picking up a build needing components I know who to go to.
    Aug 18 2012
    Bay Area
    Quote Originally Posted by dbasaiint View Post
    I'm looking for plug and play.
    Mainly looking for a stage 3 set up (engine, clutch, turbos, piping, fueling, intercooler, etc. ail included). I'm more than open to built internals and other turbo setups.
    Oct 03 2005
    I have a complete stage 3 engine, everything you'd need to drop in and go, including tune. Engine has 117k
    - - - Updated - - -
    It would put you in the 430hp area give or take as its equipped with f21 turbos and a daz tune
    - - - Updated - - -
    Timing recent done as-well
    Veteran Member Four Rings johnnybravo!'s Avatar
    Feb 20 2006
    323 EASTLOS, CALIFAS
    - - - Updated - - -
    - - - Updated - - -
    stock block? compression #s? leak-free? might you have time slips a/o Dyno read outs? how much you asking?......
    SRM K24 - Bosch 1000cc - Rods - 2.8 Cams- RR STG 4 clutch - AA-built 01E+4:1 - OS Giken LSD - ER IC's - JHM SS - SRM DPs - Vibrant 3" - Vast W/M - RS4 Y-Pipe - ASP MAF - APR Bi-Pipe - Ohlins MS Coilovers - AP Racing BBK - 034 Rear Sway
    C7 A7 Silver- Jackal STG 2+E40 Shane Horning ported s/c Merc HX- Pierburg 100-3 - Eibach Springs- OZ 20" UL wheels/Michelin PS4s- Eurocode Sway Bar- Borla- IE Intake
    Audi. Truth in Understeering.
    Jul 22 2013
    Woodbridge
    JMTx86 pm me about that motor
    Oct 03 2005
    Shipped out this afternoon. If anyone is looking for anything specific you can PM me.
    I have 2 other engines, one is being put together and prepped for someone already. It's getting full gasket, timing replacement, and engine mounts/snub w/ ko4's and fueling pre-installed. The other one is not being used at the moment.
