The Mann 950/4 is made in Germany, it has 71 pleats and a continuous pattern of holes on the internal filter structure. It has a silicone anti drain back gasket which is as good as they come in the oil filter world and a flat 4 foot filter base spring.
The Mahle OC105 is made in Austria, it has 65 pleats and has a ribbon of thin paper material at the base of the filter element which the Mann does not have (not sure what this does). Rather than a flat filter base spring it has a coil. It has a non continuous series of holes in the internal filter structure (may reduce ease of flow?). The anti drain back valve is not silicone it is rubber and therefore just is not form fitting or long lasting as the Mann silicone is.
Based on what I see with the internal filter cone structure being continuous, 71 pleats, silicone anti drain back, it's made closer to the place the car was made, these things all add up to the Mann clearly winning the comparison. Also I would like to add that it tends to be assumed that because something is more expensive it is therefore superior. In this case Mahle market price is higher typically as cheap as 13-14 dollars ebay. Whereas Mann is a commonly 10 dollar item ebay. Based on what I see with the rubber anti drain back... That shortfall is definitive, no silicone adbv and being more expensive don't mix.
I find this filter interesting. Because it has 2 filter elements with a brace screen between the two with a "synthetic" media.
I'm also reading the hype about royal purple "micro glass" filter. They say it does 99.9 filtration at 25 microns. It sounds good...
My question then is if I were to venture from Mann or Mahle, would there be a filter the same size and bypass, like the royal purple for instance.
Any one got good information to share about what oil filter they use?
