Page 1 of 3 123 LastLast
Results 1 to 40 of 84
    Veteran Member Four Rings shadycrew31's Avatar
    May 27 2013
    West Chester, PA
    Shadys 78k carbon buildup bonanza
    My car recently decided it was time for me to give her a good internal clean up via breaking the thermostat. Cleaning these should be fun...
    2010 S4, DSG, too many random parts. 2004 Mazda RX-8, was highly modified then went back to stock.
    Veteran Member Four Rings boomtime's Avatar
    Apr 22 2013
    Audi, BMW, Ford
    Rocky Mountains
    Is that chocolate in there?
    The eventual supremacy of reason.
    CPMB K04+e85
    Twin Turbo 391
    E36 Drift Queen
    Jul 14 2013
    British Columbia, Canada
    My thermostat just went out on me at 58k miles and my SA let me know there was very little carbon buildup. Decided not to get it cleaned since it was $1000CAD and I would have noticed little to no difference he said. Looking forward to seeing what another 20k miles looks like.
    2011 Phantom Black Effect S4 6MT Prestige, Sport Differential, Flat-Bottom Steering wheel with red stitching, RS4 Aluminum pedals, 034 Transmission mount, Roc-Euro Intake, Roc-Euro Short Shifter, 90mm AWE Touring Exhaust with stock downpipes, Unitronic Stage 2+, JHM 179mm Overdrive Crank Pulley, MercRacing heat exchanger, Stasis rear sway bar, CR-15, Gloss Black RS4 Grille, Sachs Xtend Clutch, 034 Density-Line Motor Mounts, Bilstein B12 Suspension Cup-Kit
    Veteran Member Three Rings skiptowncat's Avatar
    Nov 13 2014
    Manchester, England
    Mine looked pretty good at 90k when I changed the pcv.
    2015 C7.5 S6//DS1 STAGE 3//SRM INTAKES//034 X-PIPE//H&R SWAYS
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    That's just oil vapor condensing on the IC. Not carbon.
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    May 27 2013
    West Chester, PA
    Here's a better image. I believe that is carbon.
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    That residue comes off the I/c cores with brake kleen with just a good once over. Also, I believe it's oil, not carbon.
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    May 27 2013
    West Chester, PA
    Well I'm not going to argue what the scientific definition of carbon is. But I think we can all agree the sticky black V on the IC core is a large amount of buildup and needs to be cleaned. Thanks for the tip on using brake cleaner, I have tons of that stuff due to owning a rotary lol.
    Apr 16 2013
    15 Touareg; 03 Suzuki SV650 Superbike; 07 Ducati S2R1000; 95 Honda RVF400
    Westwood, MA
    When I hear carbon build up, this is what I think of
    http://mdmtechnik.co.uk/blog/rs4-4-2...m-technik-ltd/
    2013 S4 - 6MT - Estoril - Black/Black Alcantara - Sports Diff - RocEuro - Milltek (non-res) - GIAC - Pulley - ZKW - KW DDC - AK
    Nov 12 2015
    Here
    Quote Originally Posted by fromario View Post
    Thanks for that. You just gave me a serious RS4-carbon-battle flashback!
    "I'm hit! Jesus, I can't feel my intake valves! Medic!!"
    Mein ist grau
    Jun 28 2016
    US
    Quote Originally Posted by rtl5009 View Post
    This correct. The brown is oil vapor all over the cores. Clean it out by running 91% rubbing alcohol through the housing after you take the sensors all off. Just pour it in and slosh it around and pour out until everything looks clean again. Then just let it dry out before putting everything back together.
    Apr 16 2013
    Westwood, MA
    Quote Originally Posted by SportVier View Post
    LOL!! My bad for the PTSD inducing flashback
    May 27 2013
    West Chester, PA
    Ask an ye shall receive. Really hard to get a focused image in there, I'll be opening her later tonight updates will be up at that time.
    Dec 22 2012
    PHX
    Didn't Audi offer a free cleaning for carbon buildup last year? I remember getting a letter stating something about it.
    '11 S4 Prestige | 6MT | Sports Diff | ADS | Nav | B&O |
    Previous: E46 M
    WRB WRX
    May 27 2013
    West Chester, PA
    Quote Originally Posted by Mancha View Post
    Its not for the engine and only if you pop a CEL.
    Mar 27 2008
    San Diego
    Quote Originally Posted by shadycrew31 View Post
    Ewww, that looks like it could use a good walnut blasting. Out of curiosity what type of driving do you generally do? I'm at 60k but I'm definitely the use case most at risk; lots of 7-10 mile commutes where the the engine is really only up to temp for a few minutes.(this is why I take every opportunity to blast it to get it warm :)
    What is your driving style in general? I'm actually hoping to keep the S4 long term and thinking of replacing the crank pulley(with a stage 2 bonus) and getting a carbon clean done at some point.
    May 27 2013
    West Chester, PA
    Quote Originally Posted by jeffc31337 View Post
    I drive like a grandma with occasional WOT pulls. I work from home so I only drive the car twice a week at most, usually city occasional highway.
    Dec 30 2015
    Sacramento, Ca
    Wow that's some serious buildup!
    Aug 25 2008
    Boston, MA
    out of curiosity, what gas do you use? i wonder if there is actually an advantage of using gas like shell v-power exclusively to reduce carbon buildup...
    Feb 20 2006
    NC
    Direct injection.......
    Quote Originally Posted by dzasta View Post
    2021 BMW M340i
    2021 Tesla Model Y Performance
    GONE - 2019 RS5 Sportback
    GONE - 2021 Audi Etron
    GONE - 2019 Audi Sq5 - JB4 Rev9 intercooler
    GONE- 2013 S4 DSG - DP stage 2 EPL
    May 27 2013
    West Chester, PA
    Quote Originally Posted by scottycs View Post
    I only run Mobil or shell premium, and have done so since i bought the car at 44k, also I run Mobil 1 0w-40 and change the oil every 5000 miles. Direct injection is the culprit, your intake valves will eventually look like this.
    Jun 28 2016
    US
    That and the shitty PCV system which dumps a ton of oil vapors on the intake valves. If there was a way to super clean the intake mixture of air/oil vapor that the engine was injecting, this wouldn't be such a big issue because only clean air would be hitting those intake valves, but alas, that's not the case.
    May 27 2013
    West Chester, PA
    Quote Originally Posted by SwankP3RF3ct10n View Post
    Indeed, I tried trying to figure out our PCV system, but I was pretty high on gasoline fumes so all I did was lose a glove.
    Jun 18 2009
    Phoenix, AZ
    I dealt with this on my RS4 for a few years. Gasoline really is the best way to clean it, but I'm disappointed to see how much the S4 is affected.
    2017 Camaro SS 1LE
    Jun 28 2016
    US
    Fumes are pulled directly into the supercharger housing where the rotors are, so it's almost impossible to plumb something, unless you do it at the valve covers somewhere. I ran some CRC GDI IVD on mine yesterday and will do that every 2k miles for the next 10k in hopes of killing off some of the carbon buildup since the milage is up there in the 70k range. Maybe it'll do something, maybe it won't, but it's a simple process that doesn't take long and I don't really have to take anything apart to ingest the liquid. We'll see what happens.
    Jul 14 2013
    Im assuming italian tuneup doesn't do anything to burn off carbon?
    Mar 01 2006
    Kitchener, ON
    I have been paranoid about this all day too...especially since I had my car in for Audi's exhaust side cleanup. I have been burning oil too, and it feels like my gas mileage isn't as good as when I got it. Like usually my gas mileage is this bad in the winter time, not summer.
    https://www.ecstuning.com/Audi-B8_S4...Emissions/PCV/
    Looks like they have an oil seperator and PCV built into one? Under the supercharger. From what everyone is saying after replacing it with the new version from Audi after the TSB, everything is back to normal. Might clean up the carbon build up too. I am 90% sure my mechanic said I might want to replace it, but I can't remember if at the time I said sure when they replaced the thermostat and water pump...I know its like the one item under my warranty the item isn't covered on because it's considered emissions
    Here might be a useful link...used tiny url cause audizine hates said site
    https://goo.gl/hQXOc1
    2023 Audi S3 / Stronic // Daytona Grey
    Past
    2018 VW Golf R // 6 MT // Deep Black Pearl
    2010 Audi S4 // Stronic // Phantom Black
    2001 Audi S4 // 6 MT // Light Silver Metallic
    Jul 04 2016
    Stage II R53 Mini Cooper S
    Could you post a small DIY on how to actually do the cleaning? I'd like to do this to my car by latest this upcoming spring.
    May 27 2013
    West Chester, PA
    I was watching a video on that stuff, once all cleaned up I will use it going forward and see if it makes a difference when I crack it back open at 100k.
    May 27 2013
    West Chester, PA
    Quote Originally Posted by mach_kernel View Post
    I actually took pictures of the entire breakdown to get you to the valves. Depending on how cleaning goes I will do a DIY on the actual cleaning. The end goal is to do a comprehensive DIY on thermostat replacement and valve cleaning since they really should be done at the same time.
    Jun 28 2016
    US
    Quote Originally Posted by RudyH View Post
    Had the PCV replaced at the time my thermostat went out about 10K ago. Didn't do shit. So for me it's either the Mobil 0-40 thinning out bad or the mechanic didn't change the PCV, which I doubt. I normally ask for the old part, but in this case I forgot to ask. Considering my previous car burned this same oil the same way, I'm gonna blame it on that.
    Jun 28 2016
    US
    If you run it, it's hard not to get it to stall out with just one person if you follow their spray in 30 second bursts. I ended up locking the accelerator down to get 2k revs and then sprayed in quick 1 second bursts for 30 and then let the idle stabilize and then repeat. This kept the engine from revving down too much and all went fine. The rest of the instructions were followed.
    Aug 21 2012
    Boston, MA
    Where do you spray the stuff to? At the TB?
    May 27 2013
    West Chester, PA
    I'm thinking you could run a vac line from the port on the intake to the drivers seat and spray away.
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Hahaha
    When I did my 2.0T, I soaked the closed valves in BG ISC cleaner, melted the shit out of the buildup. Sucked the black goop out with a turkey baster and cleaned up as best I could with plastic picks, rags, and q-tips. Be careful though, that ISC cleaner melts plastic lol.
    Now on the A4, it was possible (tricky, but possible) to get a breaker bar and a socket onto the center of the crank with 2 people. This way with the car in neutral you can turn the engine over to open the freshly cleaned valves and close the still dirty ones so that you can clean them.
    It was literally the most work I've done to any car, but I saved a shit ton of money, and felt rewarded for the experience. I am not a mechanic, I don't really enjoy working on cars. If I can do it, anyone can. And this engine appears to be 100x easier to get into the valves, so really the job is 90% tedious cleaning. A lot more stuff has to be removed on the 2.0T, so I was doing thermostat as well.
    Sent from my SM-G930VC using Tapatalk
    2021 Audi S4, P34 Intake
    Dec 03 2008
    2018 SQ5
    Mine looked fairly bad, but yours definitely look worse. My milage was around 120k, REVO stage 2+ at the time. I noticed pretty much no difference in performance after cleaning them.
    May 27 2013
    West Chester, PA
    I am fairly certain my butt dyno will go up 30 WHP, but a real dyno wont show any gains :(.
    Getting to the valves is slightly difficult, tons of parts can break if you aren't careful. I'm very mechanically inclined but most of my experience is with the RX-8, I've rebuilt or replaced every part on the that thing. The S4 is somewhat easier in that it has less knuckle busting edges.
    May 27 2013
    West Chester, PA
    Quick update, the deposits are hard carbon, I thought they were the soft type which generally comes off with minimal effort. I've done three rounds of soaking with B12, from trial and error seems to be the best at dissolving the carbon besides BG44k. I may order some BG44k if another round doesn't do it. I didn't have time to post pics but will get some this afternoon. I should have purchased a media blaster but i'm too far down the rabbit hole now.
    Veteran Member Four Rings miztahsparklez's Avatar
    Dec 19 2010
    North CA
    What about sea foam? It's pretty much like gasoline.
    May 27 2013
    West Chester, PA
    Quote Originally Posted by miztahsparklez View Post
    Seafoam is useless
