Results 1 to 2 of 2
    Mar 05 2016
    Montana
    [Noob question] Cylinders misfiring, should I replace spark plugs or coil packs?
    A friend ran some software on my car and it showed 3 of the 4 cylinders misfiring (error codes P0299, P0303, P0304, P0302, P130A, and P0300). Should I replace the spark plugs, the coil packs, or both?
    What brands/retailers should I look at buying from?
    If I need spark plugs, what should I "size" them at? Sorry, I forget the proper term.
    Copy-paste of the error codes:
    6 Faults Found:
    5671 - Boost Pressure Regulation
    P0299 00 [096] - Control Range Not Reached
    Intermittent - Not Confirmed - Tested Since Memory Clear
    4060 - Cylinder 3
    P0303 00 [100] - Misfire Detected
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 143462 km
    Date: 2016.10.06
    Time: 18:37:48
    Engine speed: 3759.00 /min
    Normed load value: 87.5 %
    Vehicle speed: 111 km/h
    Coolant temperature: 95 °C
    Intake air temperature: 17 °C
    Ambient air pressure: 880 mbar
    Voltage terminal 30: 13.216 V
    Unlearning counter according OBD: 72
    4063 - Cylinder 4
    P0304 00 [100] - Misfire Detected
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 143462 km
    Date: 2016.10.06
    Time: 18:37:48
    4057 - Cylinder 2
    P0302 00 [236] - Misfire Detected
    MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 143792 km
    Date: 2016.10.07
    Time: 20:16:19
    Engine speed: 1864.50 /min
    Normed load value: 33.7 %
    Vehicle speed: 65 km/h
    Coolant temperature: 96 °C
    Intake air temperature: 20 °C
    Ambient air pressure: 800 mbar
    Voltage terminal 30: 13.169 V
    Unlearning counter according OBD: 40
    7960 - Cylinder Disabling
    P130A 00 [032] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 143792 km
    Date: 2016.10.07
    Time: 20:16:34
    Engine speed: 1972.50 /min
    Normed load value: 17.6 %
    Vehicle speed: 58 km/h
    Intake air temperature: 21 °C
    Voltage terminal 30: 13.358 V
    Unlearning counter according OBD: 39
    4051 - Random/Multiple Cylinder Misfire Detected
    P0300 00 [236] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 143462 km
    Date: 2016.10.06
    Time: 18:37:48
    2009 A4 Premium Plus 2.0T quattro
    Mods: OEM gloss black exhaust tips; ECS gloss black RS 4 mesh grille; OEM titanium S5 peelers
    Junior Member Two Rings charny's Avatar
    Oct 22 2013
    05 A4 6MT, 08 A4 6MT
    Medina/Ohio
    If you are having multiple misfires it is most likely an issue with you vacuum/pcv system. If you can't visually find the leak or problem area you should have it smoke tested. Also mileage and maintenance history are also helpful when diagnosing a problem. There are plenty of threads on here regarding cool and plug selection and will also cover proper spark plug gapping for your application.
