    Nov 08 2008
    Los Angeles, CA
    Specifications Around Brake Rotor Replacement
    Hi All - I have my 2012 S4 going in for brake pad replacement this week, and am curious whether or not I will need to replace the rotors as well. Is there a minimum specification of some sort, at which point the rotors need to be replaced? Just want to be able to speak intelligently with the shop when they (undoubtedly) recommend replacing the rotors as well. Thanks!
    Established Member Two Rings brunogomes's Avatar
    Apr 21 2015
    New Jersey
    Quote Originally Posted by A4Ultrasport View Post
    I've had rotors last for two sets of pads.
    Rotors don't have wear sensors like front pads for example so you'd have to keep an eye out yourself.
    You can measure the thickness.
    Warping.
    Nov 08 2008
    Los Angeles, CA
    How thick is the minimum specification on our cars? Trying to determine the point at which replacement is necessary. Thanks!
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    You can have a legit shop turn/resurface rotors for $15 each to remove any pad buildup and the lip that forms around the outer edge as they wear. You should do this when you replace pads to give them a nice clean surface to bed into. Only time you need to replace the rotors are if they're cracked or you have worn/resurfaced them enough that they are getting thin and might crack, which is about 2 sets of street pads with resurfacing.
    I have a set of oem front rotors, 90% new oem pads, oem s4 calipers and brake lines for sale for $400 if interested.
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Aug 12 2015
    Minneapolis MN
    [QUOTE=A4Ultrasport;11938964]Hi All - I have my 2012 S4 going in for brake pad replacement this week, and am curious whether or not I will need to replace the rotors as well. Is there a minimum specification of some sort, at which point the rotors need to be replaced? Just want to be able to speak intelligently with the shop when they (undoubtedly) recommend replacing the rotors as well. Thanks![/QUOTE
    I would just replace if it were me.. Never tried the resurfacing as others have mentioned.
    2017 Audi RS7 Glacier White w/ Black Optics
    2014 Porsche Panamera Turbo Executive Amethyst
