Results 1 to 3 of 3
    Jan 24 2012
    Connecticut
    Coolant leak only on cold nights when the car is sitting
    Getting frustrated with this car! I've replaced both coolant flanges already. The rear flange with sensor and O-rings as well as the side flange with the thermostat. Both flanges now look bone dry and I cant tell where the leak is coming from. My next guess would be the oil cooler gasket (which is less than a year old). Anyone have any thoughts? It's like something is shrinking up on cold nights and causing the leaking.
    Veteran Member Three Rings king_j's Avatar
    Sep 09 2009
    Minneapolis
    Coolant leak only on cold night when the car is sitting
    How much is it leaking?
    You can't see any signs of leaks?
    Smell burnt coolant after driving?
    Remove belly pan and park over night on a piece of cardboard.
    2006 A4 2.0T Q. S-Line 6MT - Arctic White
    JHM stage 1, 034 hfc, Europaparts exhaust.
    Miro 111 18x8.5 et 35, 034 RSB.
    Jun 17 2013
    jersey city nj
    Psi test the coolant system and where its leaking from
