Hey guys I have a tip 1.8t quattro and I'm very serious on doing a budget transmission swap. I have access to my school car shop (yes im in highschool and I'm 17) so Ill be looked over by a mechanic and will have lots of tools. The only thing is I dont want to spend a lot so I need to temperarly cut corners where I can. Also is the 6spd swap harder than the 5spd? I head that the 5 speed tip uses the same rear diff as the 6mt 01e? I also heard about a problem with the speedometer because the 6mt uses a different way of measuring speed or something? I've done a fair bit of research but of course some questions wont be answered. So here are some questions;
1. Will I have to swap my flywheel to fit the bearing (forget the right name of it), because I know the auto crankshaft or something is 2mm longer than the manual. I also heard of people just shaving it doen which I might do for time and money.
2. To not throw codes what am I to reflash in terms of tcu ecu and cluster? Do I NEED to reflash all 3? I just need it to pass my emissions test dont really care bout much else.
3. Not really a question but if you've done this swap, do you have any words of wisdom or something that you wish you knew before you did it?
Thanks guys I really apreciate it and how long (assuming I have all the parts) would this take?
Sent from my LG-K210 using Audizine mobile app
