Results 1 to 4 of 4
    Sep 27 2015
    San Francisco, CA
    Starting a full S6 Avant to RS6 Avant conversion shortly - S6 BBD Engine
    2002 Audi S6 Avant BBD Engine with 034 Motorsports Motor Mounts
    Engine is running strong and has zero issues
    Can be sold with or without 034 Motorsports RS4 clutch & lightweight aluminum flywheel
    The following work was completed within the last year before deciding on RS6 conversion:
    Engine - Timing
    Timing Belt
    Timing Belt Relay Roller
    Timing Belt Roller
    Timing Belt Tensioner Roller / Tensioner Lever w/ Roller
    Timing Belt Tensioner Dampener
    Water Pump w/ Metal Impeller
    Thermostat w/ O-RIng
    Accessory/Serpentine Belt
    Accessory/Serpentine Belt Tensioner
    Accessory/Serpentine Belt Roller (2)
    Socket Head Screw w/ Collar - Front Crankshaft Allen Bolts (8)
    Fan Clutch
    Intake Manifold Linkage Arms (Gruven)
    Camshaft Tensioner Gasket (2)
    Camshaft Sealing Cap (2)
    Valve Cover Gasket Set (2)
    Ignition Coil (oddly, just one needed to be replaced)
    Spark Plugs (New in box & not installed yet)
    Engine – Gaskets, Seals & Plugs
    Valley Pan Gasket
    Intake Manifold Gasket (2)
    Rear Main Seal w/ Flange
    Rear Main Seal Gasket
    Engine – Mounts
    Motor Mount – Street Density (2) (034 Motorsports)
    Resistor Bypass, Active Motor Mount (034 Motorsports)
    Motor Mount – Front
    Oil Cooler / Heat Exchanger
    Oil Cooler Tube (Gruven)
    Oil Cooler Gasket Set
    Heater Core Hose
    Oil Filter
    Clutch & Flywheel
    Audi 2.7T RS4 Hybrid Clutch Kit (034 Motorsports)
    Flywheel, Aluminum, Lightweight 2.7T (034 Motorsports)
    Here are pictures of some of the engine work being done:
    Sep 27 2015
    San Francisco, CA
    Pictures added
    Feb 01 2011
    Folsom
    I'm interested.
    I would need the ECU and wiring harness too though.
    I have a B5 with a 4.2 swap, and I am wanting a little more hp.
    Also would need to be shipped to Alaska.
    Sep 27 2015
    San Francisco, CA
    Thanks for the interest. Not a problem on the harness or ECU (would just need to let me know if you want an ECU for a 6-speed manual or an automatic). Shipping via freight not a problem. PM me you name and address so I can get a quote.
