Results 1 to 8 of 8
    May 03 2016
    B7 S4 brake maintenance
    Hey everyone.
    New to owning the S4 Avant.
    It has 92,XXX miles on it.
    Just did an oil change and some filter changes. About to tackle the brakes and trying to do some upkeep.
    About to buy, Goodrich SS brake lines and the TyrolSport's brake calipers stiffening kit
    Any brake fluid recommendations?
    And
    While I'm there. Anything else I should buy to have ready while I'm down there?
    Brakes and pads are good for now.
    Car is new to me, but I know things wear out and want to have many happy years of driving t around!
    Thoughts, suggestions welcome!
    Senior Member Three Rings AllroadMass's Avatar
    Oct 30 2015
    Massachusetts
    I would do a brake fluid flush and ss line first and see how the pedal feels. Heard mix reviews on the stiffening kit.
    http://www.audizine.com/forum/showthread.php?t=432301
    Sent from my Nexus 7 using Audizine mobile app
    Apr 18 2012
    1995 Toyota Land Cruiser (FJ80/FZJ80)
    Central Texas
    the rear caliper bolts are a PITA. clearance is tight back there, so make sure you have suitable tools; i ended up buying an inexpensive hex driver socket and cut it down to fit. spraying some penetrating oil a few hours before will help, too.
    - emilio
    May 03 2016
    Time to change my brakes!
    Any pro tips?
    About to order the Stoptech performance kit. Slotted/drilled rotors and Stoptech street pads. And the stainless brake rotor bolts.
    Any thing else I need?
    Any problems I’m in for?
    Established Member Two Rings Mike50design's Avatar
    Feb 17 2017
    Mission/BC/Canada
    If you pop the lower bolt out of the rear struts, it makes it way easier to get the rear caliper off
    2007 Audi S4 (DTM)
    Veteran Member Three Rings caliizaktiv's Avatar
    Dec 20 2010
    Used Oil
    East Coast
    Quote Originally Posted by Mike50design View Post
    Only necessary if you remove the caliper carrier, which you shouldn't do anyway for this brake job. Removing the slide pin nuts and pins themselves are all you need to pop the caliper piston off and get at the pads.
    OP. You may run into seized slide pins in the rear. If you do, the pins themselves are not readily available without actually purchasing an entire new caliper assembly.
    Fronts are pretty straight forward. Just remember to use anti squeal brake grease on the pad to caliper contact points for the front and rear pads. Get yourself a nice torque wrench too.
    07 RS4 | 03 M5 | 24 RS6p
    May 03 2016
    About to tackle this
    This weekend.
    Should I order new hex bolts for the carriers?
    I’ve heard they strip pretty easy.
    Anyone have a part #?
    Feb 17 2017
    Mission/BC/Canada
    Quote Originally Posted by nyc joe View Post
    This weekend.
    You'll be fine if you're careful.
    2007 Audi S4 (DTM)
