Results 1 to 26 of 26
    Veteran Member Four Rings quietcropduster's Avatar
    Feb 21 2015
    2014 C7 Corvette 3LT Z51
    Ohio
    Odd clicking or tapping noise from engine bay
    2013 S4 w Roc Euro intake.
    Noise comes from engine bay, it straight sounds like the fuel pump ticking or clicking.
    When idle is can be faintly hear, when on the gas at around 2 rpm it's much more audible. Had it at the dealer for another issue but also had them check it out.
    They stated something like a rubber grommet of sorts that's on the firewall were the steering column comes though was not seated properly. They stated it was causing more engine noise 2 come thru the cabin.
    They adjusted it, now it's not nearly as loud but it's still there. Car has 35k miles on it. I can attempt 2 get a video of the sound.
    Thoughts?
    Sent from my SM-G900V using Tapatalk
    B9 S4 Prestige | Glacier White Metallic | B&O | Sports Diff | CF Inlays | Roc Euro Intake | APR FMIC | ECS Valved catback | 034 tour brace/RSB & trans mount | Forge Motorsports OCC | Michelin PS4s | EPL Stage 2 93 |
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    What brand & weight of oil are you using?
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Feb 21 2015
    Ohio
    Quote Originally Posted by jygesq View Post
    Oem including filter
    Apr 05 2016
    Portland, OR
    My throttle body makes a clicking noise at idle, you can only hear it with the hood up though...
    Veteran Member Four Rings shadycrew31's Avatar
    May 27 2013
    West Chester, PA
    I assume you have checked oil levels?
    Feb 21 2015
    Ohio
    Quote Originally Posted by shadycrew31 View Post
    Not with dipstick yet but the screen shows it at just above the halfway mark
    Veteran Member Three Rings 968Reckless's Avatar
    Sep 25 2010
    B8.5 S4, Porsche 993, BMW E30 s52 swap, BMW E30 vert, BMW 2002tii, gen 3 tacoma
    Syracuse, NY
    Quote Originally Posted by whiped View Post
    Mine does this as well, seems to be normal.
    @martino_motorsport
    Feb 21 2015
    Ohio
    Quote Originally Posted by 968Reckless View Post
    I swear it didn't do it b4 I had it at dealer for 35k service, at least I couldn't hear it in my cabin.
    Sep 25 2010
    Syracuse, NY
    Quote Originally Posted by quietcropduster View Post
    I've always had it but I only notice it when I give my engine a little rev in the garage. Just sounds like the TB opening to me.
    @martino_motorsport
    Feb 21 2015
    Ohio
    Mine does it at idle but it's very faint, and also with Rev it increases, ur right thou in garage it make it more apparent
    May 27 2013
    West Chester, PA
    I mean with our injectors there will always be clicking from them.
    2010 S4, DSG, too many random parts. 2004 Mazda RX-8, was highly modified then went back to stock.
    Senior Member Two Rings S4ilicious's Avatar
    Feb 09 2015
    2001 A4 2.8 Quattro
    Bay Area, California
    Have you tried looking at different S4's to see if they experience the same noise? Maybe even look at some S4 reviews to see if the engine makes the same ticking noise as yours OR even better post up a video
    2014 Brilliant Black | 034 Motorsports filter | 034 DSG Tune | Black Fine Nappa Leather | Prestige | 7 Speed S-Stronic | Apr tune | Roc Euro Intake | X pipe Exhaust | Akebono Brake Pads | Deval CF Rear Diffuser | ECS Spacer Flush kit 10F 12.5R |
    Feb 21 2015
    Ohio
    Quote Originally Posted by S4ilicious View Post
    I'll post up a video up soon and S4s are a rare breed in my area, I literally only know of 3. But I'm in the process of that.
    Veteran Member Four Rings Race Shooter's Avatar
    Dec 22 2006
    Raleigh
    Our injectors have a very audible clicking sound that is totally normal. It sounds bad and if you didnt know it was normal may think there is a valve tick or other kind of abnormal knocking, but its just how they are. Many direct injection engines sound similar but the Audi ones seem especially loud.
    2014 Porsche Cayman S Guards Red
    2015 Sepang Blue S4 6MT Gone...easily forgotten.
    2004 Nogaro Blue S4 Avant 6MT Gone...but severly missed .
    Jim Sykes Photography motorsports photography
    Veteran Member Four Rings theswoleguy's Avatar
    Dec 07 2012
    Atlanta, GA
    most likely injectors or HPFP or both. Both are noisy
    '01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, E85, Sold
    '03 GTI: Gutted, Parted & Transplanted
    '04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, Sold
    '15 Audi S4: Stock, S-Tronic, B&O, NAV, ADS w/ Sport Diff, Smart Key, glacier white w/ magma red, 19" Shamrocks lol
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Quote Originally Posted by Race Shooter View Post
    This is good to know. I was on the highway the other day next to one of those concrete dividers. I had my front passenger window down and I punched it and heard some clicking. I was a little nervous, but kind of figured that it was normal since there was nothing else amiss.
    Senior Member Two Rings Wreckm's Avatar
    Oct 30 2013
    San Gabriel California
    check your intake. my roc euro was loose at the throttle and made a bad ticking.
    Feb 21 2015
    Ohio
    Quote Originally Posted by Wreckm View Post
    I shall be doing this when I get home.
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Road / drove the car back to back with mine. Definitely can hear the sound which seems to be coming from the driver side and gets louder as RPM's climb. 2500rpm is where it becomes noticable even with a mild tip-in to the throttle.
    At idle the engine sounds as quite as an Audi 3.0 is and matches mine less perhaps a bit more clanky'ish sound from the fuel pump. IMO the sound he's describing seems to be a pully of some sort. When the vehicle blips the throttle upon downshift it's apparant too. Odd.
    No conclusion reached excpet that if the dealer wants to drive mine side by side to hear it they are welcome to.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Feb 21 2015
    Ohio
    going to stop by the dealership with pdqgp's car to show them the difference, hopefully its something small.
    Feb 21 2015
    Ohio
    Headed 2 the dealer today with pdqgp, hope these idiots get it figured out!
    Mar 06 2015
    Columbus, Ohio
    Good visit today but not one that left me feeling 100% confident. I agree that the one guy may truly have been losing his hearing but the other guy....he heard it easily.
    LOL at his reaction when drving my car and getting it a bit tail happyas we exited the roundabout. "This car is definitely flashed"
    I like the fact that he seems to really feel confident in the platform and has plenty of experience on them but I don't like how easily he seemed to dismiss the noise on your exhaust mod.
    Feb 21 2015
    Ohio
    Quote Originally Posted by pdqgp View Post
    Agreed, I'll wait 2c what they figure out. I was just thinking, remember how my engine seemed 2 vibrate more than yours at idle? Maybe they don't have a motor mount Torqued down correctly which would be why we only hear the noise at certain rpms.
    Feb 21 2015
    Ohio
    https://youtu.be/CmnYg2Prbhk
    I thought I tracked down the cause of the noise I was hearing, I'm so enraged right now, the dealer fucked up so much on the VVT TSB that its astounding some customer hasn't went postal on them bec surely I cant be the only customer w issues.
    Turns out my issue still persists despite several trips to the dealer, audi corp here I come.
    Veteran Member Three Rings Allan691's Avatar
    Jul 23 2018
    Vicenza, Italy
    Mine never made this sound (what whiped described at the throttle body) until right after I did the PCV/H2O/T-Stat job.. and then it appeared after a few minutes of idling (while I was checking all was OK and the coolant was bled). It subsequently went away, but then returned. I shut her down, and started her up again to find it re-appear.. But then.. nothing. And now, several days later, I have not noticed it again. Strange.. and personally, I don't think it's normal.
    2009 Euro-spec Black Optics S4 Avant APR Stage 2 APR SC pulley + JHM187 with APR Open Air Intake • CR-15 + AK + Eurocode USS + Diff + Trans inserts • P3
    Senior Member Two Rings thaifoodninja's Avatar
    Feb 09 2012
    Bostonish
    Quote Originally Posted by Allan691 View Post
    Hey did you ever figure this out? I have the EXACT thing started after I upgraded my heat exchanger for the merc racing a couple days ago.
    2013 S4 DSG
    IG: @isaacdoescarstuff
