Results 1 to 10 of 10
    Feb 06 2013
    WV
    Secondary air injection ???s
    I have been trying to get a grasp on this secondary air injection deal. I have a 01 awm that I am getting ready to build to handle all that can be thrown at it but the engine currently has an aeb head mounted on it. Could the sai still be hooked up?
    If it is should I delete it?
    If you can read this thank a teacher, since its English thank a veteran...
    Audi make a great car, but their heater cores are, well $h!t.....
    Mar 10 2016
    Quote Originally Posted by zandrew View Post
    i say get rid of it. If you aren't running a cat, which i assume you aren't because you're building your car, there's no need for the sai. Its just a heavy ass useless thing hanging over the front wheels and taking up space in the bay. I took mine out, and most people code there's out when they get it tuned; like i did mine. So then theres literally no need for it
    '01 Audi A4 1.8TQM - stage 2 daily
    '95 BMW M3 Coupe S52 swap - RIP
    '01 Audi S4 K04 Stage 3 - stolen
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    Get the SAI block off plate 20$. Rip that shit out. It literally just uses exhaust gas to warm the engine up, then once the engine is hot, it does nothing.
    Dec 05 2007
    Can't be used with the aeb head. No provision for combination valve for secondary air injection pump to add extra air to heat the catalytic converter. It is an emission item and the b5 ran fine on the aeb without it. If these cars could include an emission component for everytime you were to fart in your car, they would add that too. Like a reverse cabin filter...just for flatulence.
    Get rid of it and resell it to someone who needs it. That is what I did. I can get around those stringent inspection criterion even if it is illegal. Others don't have that convenience, and this is how my highly illegal car is street legal.
    Feb 06 2013
    WV
    My state requires state inspection....
    But.....
    My car does NOT require said inspection....
    It pays to be smarter then the rat trap....
    Senior Member Three Rings DoesntCare's Avatar
    Feb 28 2016
    SEPA
    I deleted the SAI on my 1.8t GTI, and got a tune to turn the monitor off on the ECU, and I had no problems getting through emissions
    Issue is fewer tuning companies are offering the emissions deletes with the tunes anymore.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    The SAI is a vestigial organ. Utterly useless.
    Take it out, burn the plastic pile of shit, and piss on the melted heap. But yeah, mitch is correct of course. You cannot run it because there is no provision for it in an AEB head
    Quote Originally Posted by Davdraco1 View Post
    It actually pumps fresh air into the exhaust to help heat up the catalyst quicker. It is not an EGR system. 30 seconds after starting the car, it is dead weight. If you have no cat, it is dead weight. All in all, it is dead weight that is an over-engineered piece of shit. Tits on a boar hog makes more sense than SAI.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Oct 10 2013
    State College PA
    Quote Originally Posted by redline380 View Post
    My bad redline. Thought it worked in the opposite direction to help heat the engine up instead of the cat. Eaithet way, I agree it's garbage.
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    1973 MG Midget, 1995 F150 302 v8, 2007 A4 Avant 3.2 v6, 2014 Odyssey EX-L
    Fredneck Maryland
    Its trash remove it. follow this and call it a day
    ---->>>CLICKY <<<-----
    SOLD the GOINHAM A4 ---> GT2860 Project
    Veteran Member Four Rings RENOxDECEPTION's Avatar
    Nov 04 2012
    2000 B5 A4 1.8TQM, 2000 B5 A4 1.8TQM
    Reno
    What seerlah said, AEB does not need a block off plate because there is no SAIP on pre 2000 model cars.
    Easiest delete for no CEL is to just have a tuner code it out.
    2000 Audi A4 B5 1.8TQM AEB/06A
    1998 Audi A4 B5 4.2QM (Thread)
    2000 Audi A4 B5 1.8TQM K24 Turbo, AEB Wideband
