Results 1 to 6 of 6
    Established Member Two Rings Garf's Avatar
    Aug 23 2016
    Audi A4 B6 3.0 Quattro 6MT
    Toronto, Ontario
    Best way to gain access to headlight washer pump
    What is the best way to get access to the headlight washer pump? Many have said to remove the front bumper, but I think it seems a lot work to do it that way. Can I good access to it via the inner wheel covers on the driver side?
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    You can squeeze your arm down to it if you take the driver's side headlight out. It's tight, but you can remove and reinstall by feel.
    Sent from my DROID Turbo 2
    Aug 23 2016
    Toronto, Ontario
    I thought about that, but it was impossible to unplug it and my hand got cut up by the sharp surrounding parts. That's why I thought if the access to it via the inner fender well was better than taking the bumper off.
    Apr 15 2014
    Ottawa/Gatineau Canada
    I do headlight and reaching up from underneath in tandem
    Aug 23 2016
    Toronto, Ontario
    I just removed the plastic belly pan cover. Got full access to it now.
    Nov 15 2011
    Montreal | I sell in USD
    best to access headlight washer pump
    Quote Originally Posted by Garf View Post
    Make sure the reservoir is empty before removing it (or dont keep your face under it, it freaking burns when you get a drop in the eye, dont ask me how I know) and change the "oring" washer when replacing the pump.
    *****I sell in USD*****
