Results 1 to 18 of 18
    Jul 06 2010
    Max Offset 20x9?
    Anyone running ET 25 on sport suspension with 20x9? What's the max offset without rubbing and looking crazy with either a 255 or 265/35/20?
    Feb 11 2016
    earth
    On my s6 I am running 20*9 et29 and lowered about 17-20mm. It only rubs on hard turns in dynamic mode.
    Feb 11 2016
    earth
    255.35.20 Michelin pss
    Jan 30 2015
    2012 A6 3.0T Prestige + others
    Irvine/CA
    I ran 20x9 et25 on sports suspension, never had issue, no rub at all
    Jul 06 2010
    Do you mind posting a pic or two when you can? I found Rob's S6 with 265 tires and his looks good but he's lowered.
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    i would imagine the spoke design would have a large impact on what offset you can use with the s6 brakes
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Veteran Member Four Rings psiaddict85's Avatar
    Dec 16 2008
    Cleveland OH
    Anything lower then et29 on 9" wide wheel will poke in the rear unless you adjust for some negative camber. In the front can run a few more mm before the wheel starts protruding. You can still get away with a slightly lower offset, just depends on the look you're after.
    Feb 11 2016
    earth
    Oct 16 2012
    pa
    Quote Originally Posted by fatboydelights View Post
    looks good, any more pictures?
    Jul 06 2010
    Quote Originally Posted by psiaddict85 View Post
    Is this the case with standard sport suspension on A6?
    Dec 16 2008
    Cleveland OH
    Quote Originally Posted by r1racer View Post
    That's the case on my 16 with sport suspension. On a lowered car you'll have more negative camber so you can generally get away with s lightly lower offset.
    This is final et23 on 8.5, same at et29 on 9" and it's about as flush as you can get.
    22 []S6 Glacier/Arras
    19 []S4 Quantum/Magma
    16 A6 3.0T S-Line/Glacier
    15 []SQ5 Audi Exclusive/Ibis/Magma RIP
    09 []S5 V8 6MT/Ibis/Magma
    06 A4 2.0TQ StgII+ DTM/Moro
    99.5 A4 1.8T StgIII Silver
    Mar 14 2008
    Audi S5, Porsche 718 Spyder, Audi RS5
    MA
    Some of this is also going to depend on the specifics of the tire sidewall geometry. For example, I have found that Continental runs wide. A Yokohama 255 is wider than a Michelin 275, etc, etc. When you are pushing the envelope of fitment to millimeters, it makes a difference. The best fit IMO for a 265 on a 9" wheel is ET35mm. You fill fit very nicely, lowered or stock, and will have no rubbing no matter what brand of tire you choose.
    Here is a 265/35/20 Michelin PSS on 20x9 ET 35, lowered about 15mm:
    Current Fleet: Porsche 718 Spyder * Audi S5 Sportback * Audi RS5 Sportback
    On order: Audi RSQ8 Performance
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by VVG View Post
    How are those tires? I always wonder about the difference of the "star BMW" tires on other makes. I'm sure it is minimal but just don't know all the details. I know for example the Michelin K2 spec tires for Ferrari start with 3/32" less tread depth than the non-K2 spec. I see from Tirerack the BMW spec is 1/32" less to begin with just don't know what else is different to make is "star BMW" and how that would affect its use on AWD Audi.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Jul 06 2010
    Addict, that setup is perfection. I'm going to run the ET 35 rs7 reps for now as a winter setup and move to the OEM SQ5s (polished black with machined face) for the summer.
    Senior Member Three Rings Carl Weathers's Avatar
    Dec 20 2014
    Chicago
    A6 and S6 max offsets are different in the front. A6's front caliper is bulkier in spots, generally limiting the offset, unfortunately. Just make sure you go somewhere and test fit as some of the recommendations made by the S6 guys won't necessarily work on an A6.
    2012 Audi A6 3.0T Fully loaded sans B&O/Nightvision, 20" Rohana RF2 wrapped in Ventus V12, APR Stage 2, AWE exhaust
    2005 Pontiac GTO, Procharged with D1SC 553/550 at rear wheels on 7lbs of boost
    Veteran Member Four Rings PKmode's Avatar
    Sep 19 2005
    Milwaukee, WI USA
    Quote Originally Posted by Carl Weathers View Post
    THIS. Not only that but the A6 uses floating calipers vs the S6 monoblocks. What this means in the real world is your caliper face sticks out further with fresh pads. Point being, if you test fit with worn brakes, take that into consideration if the spokes are close. Pay particular attention to the torx head on the cover plate as it sticks forward farther than anything.
    Do it right, or don't bother.
    Dec 20 2014
    Chicago
    Quote Originally Posted by PKmode View Post
    That DAMN torx head! It was the bane of my existence while shopping for my set up.
    Veteran Member Four Rings madyspop's Avatar
    Nov 19 2005
    07 S8, 07 V10 Treg, 11 Stasis S4, 13 S6
    Central IL
    20x9.5 BBS LM et30 on a 265/35/20 PSS
    13 S6 Glacier Stage 3 llllllll APR DP's l Akrapovic l EC sways, endlinks and Alu Kruez l 034 mounts l Garrett GTX2873 turbos l Custom ECU/TCU tune l 3m tint l CETE Bluetooth Lowering Module l Escort 9500ci built in radar/laser diffuser l AWE Gen 2 intake l Xpel l P3 Gauge l RS 6 Grill l E-codes l APR HE l Carbon Designs valance & mirror caps l Dynamic tails l facelift rear bumper l 20" BBS CX-R on Blizzaks l 20" HRE P101 on Mich PSS l 034 density mounts
