Results 1 to 12 of 12
Thread: Wiring and ecu
    Sep 25 2016
    96&98 discovery, Audi a6, TRX 450r, xc700sp. 86 Ford bronco
    Upper peninsula of Michigan
    Wiring and ecu
    I have a 98 a4. I'm swapping in a 2001 40v 4.2. I'm having troubles figuring out the wiring to get the engine harness to match the body. Also need to know if someone can tweak my ecu for a manual, and Sai delete, egr delete and immobiliser defeated
    Sent from my XT1585 using Audizine mobile app
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    You're going to need a facelift pedal assembly too, in order to convert to DBW from the 98 DBC I believe, you probably already knew that though.
    I believe you just need to splice the 5 body plugs, no?
    2016 S3
    Instagram- @Thisisastickup
    Sep 25 2016
    Quote Originally Posted by b6Hate4 View Post
    Idk was thinking that's all I needed to do. However was seeing if someone knew for sure. I know that there are more wires in the v8 harness to the body. Was seeing if anyone else have done this and what to do. Yes I'm taking the pedal and mount out of the a6
    Oct 27 2010
    Norwood, MA.
    http://www.motorgeek.com/viewtopic.php?f=6&t=50232
    This is a very detailed write up of what is needed to swap a v8 into any b5 in existance. I would PM the OP and see what he has to say about any questions you have.
    2016 S3
    Sep 25 2016
    Ok that's man am much appreciated
    Sep 25 2016
    Quote Originally Posted by Tddybrwn269 View Post
    Well I checked it out and it says that the topic doesn't exist
    Oct 27 2010
    Norwood, MA.
    Interesting, link works for me.
    Sent from toilet stall #4
    2016 S3
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    Worked for me
    Maybe PEBKAC?
    Sep 25 2016
    Oh oic hmm. So what wiring will I need to do? I have a pre facelift
    Jul 07 2009
    Socal/IE
    U will need to search! Read threw the build threads. Nollywood is a good source of info
    Sep 25 2016
    Quote Originally Posted by tar View Post
    Worked for me
    Maybe PEBKAC?
    Oh yeah btw this is what happens
    Sep 25 2016
    Ok I have been and I'll look into it.
