Results 1 to 6 of 6
    Registered Member One Ring Woodsy's Avatar
    Sep 26 2016
    Buffalo ny
    cam phase position
    Hello, Does any one know an acceptable range for cam adjustment adaptation phase position (VCDS block 93). The one i'm questioning is the Phase position on bank two it is reading -3.0* KW while bank 1 is reading 1.0 * KW
    Any advice or insight would be greatly appreciated. Also the motor is in fact a 4.2 V8 from a B6 S4. i have attached the picture of the vcds blocks under my member photos
    Veteran Member Four Rings q_dubz's Avatar
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    VCDS tells you what the acceptable range is just by hovering your mouse over the cell.
    Anyway those readings are fine.
    Sep 26 2016
    Buffalo ny
    Quote Originally Posted by q_dubz View Post
    thank you
    Jul 13 2014
    1997BMWZ3
    Daly City,CA United States
    I got -7 and -5. Normal?
    Jul 15 2015
    Rochester NY
    Hi guys, would you be able to point me to a link to understand how these measuring block things work and how to read them. I "kind of get it" but I wouldn't want to go into vcds and accidentally screw something up (especially after seeing the warnings that it displays in there! : )
    Sep 26 2016
    Buffalo ny
    @neilpaku hopefully you will find this informative. best of luck in your search!
    http://www.ross-tech.com/vcds/tour/m-blocks.php
