Results 1 to 8 of 8
    Established Member Two Rings 2photors4's Avatar
    Feb 17 2011
    Kelowna, BC
    Does anyone use the same pads and rotors for track and street?
    If so, I was wondering what pads you are using and what kind of compromises you are experiencing. I need to replace my pads and rotors for the street but I am also going to start tracking the car and don't really want to get 2 sets of pads and rotors. I currently have Stasis/Alcon front brakes and stock rear.
    Thanks.
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    I run EBC YellowStuff pads. It maybe a S4 but I have RS4 front brakes and bigger 330mm rear rotors. My wheels are always dirty but it will stop on a dime. Don't hear any brake noise over the loud exhaust, suspension creaking, and radio.
    Make sure to run high temperature brake fluid.
    Veteran Member Four Rings ven0m's Avatar
    May 10 2015
    Audi RS6 c7 (Avant), Audi RS4 b7 (Sedan), Audi A4 AllRoad b8.5 (Avant)
    Slovenia
    AP Racing front rotors and Ferodo DS2500 pads all-round.
    DS2500 is a composite that works well on street and track.
    Jeremy Clarkson: "So when you were saying that it won’t slide, what you meant was, ‘I can’t slide it.’“
    James May: "Yes."
    Veteran Member Four Rings jareds941's Avatar
    Jan 12 2010
    Jackson, WY
    I ran EBC yellow only when I had my RS4. Lots of track days on them. Same story for another local. They won't give you track pad bite, but they get the job done and are rotor friendly.
    Mine: 2021 Ford F150 PowerBoost
    Hers: 2016 Daytona Gray SQ5
    Previous:
    2004 E46 M3 Track Car
    2019 Daytona Gray S4
    2014 Glacier White S4
    2014 Glacier White SQ5
    2008 Daytona Gray RS4
    Oct 02 2015
    B7 RS4, UrS4
    Boston
    I've used both DS2500s and yellowstuffs on past cars. Not as effective as pure track pads, and noisier than street pads but damn usable in both scenarios.
    2007 RS4, Daytona Grey, Euro headlights & taillights, PIAA yellow fog lights, ECS H-Pipe, JHM downpipes, SPEC Billet steel lightweight flywheel, JHM Solid shift linkage, Bilstein PSS9's, 19x10 Rotiform TMB (summer), 19x8.5 Rotiform LAS-R (winter)
    1993 S4, euro everything ( Sold, never forgotten... )
    Jan 28 2016
    San Mateo, CA
    I run the StopTech Street Performance pads on both street and track. Definitely an improvement over stock, and works reasonably well in both driving situations.
    Would you guys say the EBC YellowStuff is a better choice for street & track? I don't dislike the StopTechs, but if there's something better out there, why not.
    Established Member Two Rings WTF its Arturo's Avatar
    Jun 08 2011
    C8 RS6, B9 SQ5, B7 RS4
    Quote Originally Posted by rs4max View Post
    +1, I also use StopTech Street pads on the street and track. Have 8 track days on them and they definitely get the job done. More bite than OEM (and they don't dust as much), but I don't have experience with other pads. Also wondering what else is out there.
    Garage
    Ultra Blue RS6 | Sprint Blue RS4 | Ibis B9 SQ5 (wifey)
    IG: @rs.turo
    Apr 05 2015
    '86 Porsche 944, '73 Dodge Charger, '07 Audi RS4, '01 Audi S4
    Urbana ,MD
    I switch pads and keep the same rotors, however after my first 2 track days I was getting a lot of heat checking on the rotors around the drilled holes.
    Track Pads - Carbotech Xp10 , great initial bite, very predictable torque, havent faded them yet. Will squeal a ton on the street
    Street Pads - Factory, never used on the track.
