Results 1 to 18 of 18
    Feb 24 2004
    Minneapolis
    Transverse link, rear, camber bolt frozen
    Need to get car aligned before winter tires. Left rear camber bolt is rusted to bushing in transverse link. Seems my options are:
    1. Cut bolt, change bushing in place. Seems tough to me. Anyone?
    2. Remove transverse link.
    Bentley says I have to remove subframe to get the inside bolt. Does "remove" mean remove? Or can I just loosen bolts and pry it down?
    Do I really have to drop the subframe? If you look at these pics, it looks like the bolt might slide forward (once I figure out the size of the nut hiding up there.....is it a 22mm?)
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    Dang those rear subframes are always a pain. When i did mine i had to drop the subframe. The outer eccentric i had to use a hack saw because the bushing was seized, and the inner bolt would not budge. I also had to weld the press fit nut on the inner link because it would spin with the bolt.
    Sent from my SM-G920P using Tapatalk
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Feb 24 2004
    Minneapolis
    Thanks for the reply Denio.......I think.
    So you didn't just pry the sub-frame down, you dropped it out of the car?
    Oct 24 2015
    Perth, WA
    Try getting it out, I am pretty sure I did this recently and it does come out without lowering the sub. Just put a jack under the arm so it doesn't prevent the bolt from being able to be removed.
    My respray thread
    Feb 24 2004
    Minneapolis
    I just took a better look at it at my buddy's lift. I see what Denio is saying about welding that nut on the inner bolt. You can't get a socket around it because it's too close to the rest of the sub-frame. Thank you Mr. Audi.
    Jan 24 2013
    Chicago
    Yep the rear is truly a pain, but once you get to it, not really that bad. Many people manage to take the inner bolt out with a wrench or at least loosen it so the control arm can move, but alot of times the press fit nut just moves with the bolt. In that case you would have to drop the subframe and just do the necessary repairs. Honestly all you need is a floor jack to drop the subframe. FYI for clarification to anyone else reading: the inner bolt on the upper control arm doesnt adjust camber, only the outer, but when adjusting the camber it helps if both inner and outer bolts are loosened.
    I had a writeup from another forum that is no longer running, so I tried posting that go the DIY section here but the mods never approved it. Ill upload to photobucket on this thread and you can use that as a reference.
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by Denio24 View Post
    When you talk about the "press fit nut", are you saying the nut on the inner bolt is self-holding? I can't get a good enough look at it (best view I can get is with my cheekbone against the muffler) but that would make some sense. So if I'm lucky, I wouldn't have to hold that nut, just back out the inner bolt?
    Jan 24 2013
    Chicago
    It is supposed to be press fit but it rusts out and loosens. There are actually slight straight edges for a socket to hold on to it but usually it is so rusted it is rounded out as well. Some people have tried holding onto it with vise grips with success. I think if you take off the subframe bolts on the side you are working on you may be able to loosen the inner link. Just use some penetrant for the bolt.
    Jan 24 2013
    Chicago
    This was the DIY when euroaddiction forum was still up. Original writeup creds go to dougyfresh, I only edited and made it look nice.
    Feb 24 2004
    Minneapolis
    Thanks Denio. I saw a link to that but couldn't get there. So that's what you mean by a "pressed nut." So it looks like I should soak mine in PB, then try it. If that nut spins, I'm dead.
    Feb 24 2004
    Minneapolis
    I soaked the threads that stick out of the bolt for a few days. Last night I loosened the bolt a couple turns. Took lots of torque, even after it broke lose but that pressed nut held. So, new traverse arm is on the way and then I'll cut it out and replace.
    By the way, I took a closer read on the directions above to remove the rear suspension. I think they left out a very important step. There's nothing about compressing the springs...in fact they aren't even mentioned!!!!!!!!!
    Feb 24 2004
    Minneapolis
    Tried to remove the inner bolt today after a week of soaking it in PB. The nut turns. So the sub-frame has to come out.
    Only thing that looks tough is the springs. If I raise the right front as high as I can, shouldn't I be able to put a compressor tool on the left rear spring and it's compressed enough to remove?
    Jan 24 2013
    Chicago
    Quote Originally Posted by mtroxel View Post
    You don't need to compress the springs or anything. When I dropped the subframe I don't worry about the springs I just back out the subframe bolts slowly with a jack and some wood supporting the frame/diff.
    Feb 24 2004
    Minneapolis
    I had kicked that around in my head. But I always imagined a fight to get the suspension jacked back up with the springs in place. It's not a problem?
    Jan 24 2013
    Chicago
    Not really. Just a little bit of going back and forth to set the springs in place and jacking up the frame a little bit more, then going back to see if they are still in place.
    May 31 2015
    2017 Mazda CX-5 Touring
    Twin Cities, MN
    2020 and this job hasn't gotten any easier. My subframe is lowered but not removed yet. My 18mm socket is digging into the bolt and seems like it wants to round it so waiting on the PB blaster to soak and then probably gonna heat it and hope that nut doesn't spin. Thanks for the info though
    '06 A4 Avant 2.0TQM S-Line Brilliant Red- | JHM High Flow Cat | Bosal Center exhaust | 034 Snub, motor, & trans mounts | 034 Spherical Front Sway End Links | 034 Street Density Control Arms | Meyle HD tie rods | ST coilovers | 750# Hyperco rear springs | Bilstein B8 rear shocks | S4 rear brake swap | Mk2 TT Turbines w/Pilot Sport AS3 | Blizzaks for snow
    -Plans: 155k and going...
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    Quote Originally Posted by Tsinsta93 View Post
    Fyi, the nut is gonna spin. Its a press fit nut, not welded in place like some think. I lowered the subframe down a few inches, and got a small pipe wrench on the nut to hold. Make sure to buy new hardware. Loosen opposite side subframe bolts, remove the side your working on, and lower down with a jack. Give yourself room. And should have new subframe bolts. I did all my arms, with all new hardware, nice now
    Sent from my LM-G710VM using Audizine Forum mobile app
    May 31 2015
    Twin Cities, MN
    Quote Originally Posted by Jayz691 View Post
    Yep ordered hardware to replace and also using the unilateral lowering approach. As expected it spun and I think some dirty threads hung it up. Even with a very good hold on the press nut I couldn't turn the bolt any further with a breaker. So I ground through the nut until it finally broke free. One side out, now to remove the other while I wait for the bolts to arrive. I will be glad when this is done!
