Results 1 to 4 of 4
    Veteran Member Four Rings arjun90's Avatar
    Dec 27 2014
    2013 Audi Q5 3.0T
    Coolant Smell Coming From Front Driver Side Between Engine & Radiator
    I started the car after such a long time, and sensed a sweet coolant smell coming from the Front Driver Side Between Engine & Radiator. The bottom of my oil pan is a bit moist; used a paper towel and noticed the color pink---indicating coolant leak. Hoses look satisfactory to me, the smell is concentrated between radiator and engine (particularly driver side--near one of the main hoses feeding into the radiator). Can the leak coming from one of the radiator hoses?
    The water pump (and presumably gasket) was replaced last year at the same time when getting the timing belt changed. It would be shocking "if" the shop did not change out all the gaskets and seals; they can never prove it to you if they did unless you, the owner, got to the timing belt area yourself.
    Where should I start in terms of diagnosis?
    Thanks
    (Pictures to posted soon)
    Current:
    | Audi Q5 (B8) 2013 (3.0T, Quattro) |
    70,xxx Miles
    | Audi A6 (C6) Avant, 2010 (3.0T, Quattro) |
    182,xxx Miles
    Gone But Not Forgotten:
    | Audi A6 (C5) Avant, 2004 (3.0L, Quattro) |
    221,386 Miles [April 2014 - March 2022]
    New genuine Audi/VW parts for cheap within the US - audiusaoemparts.com
    New genuine Audi/VW parts for cheap if you can afford the wait - oemVWshop
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    Leaky thermostat housing? Maybe a tiny leak in hose?
    Dec 27 2014
    2013 Audi Q5 3.0T
    I'm hoping its just a tiny leak in a hose which can be seen visually without removing anything. Thermostat Housing? The thermostat was replaced last year during the timing belt service.
    Current:
    70,xxx Miles
    182,xxx Miles
    Senior Member Three Rings massboykie's Avatar
    Mar 14 2008
    '16 Audi S6, '16 Audi S5 Cab.
    Natick, MA
    Hi Arjun
    Mine did the same thing and it ended up being the secondary coolant pump that sits under the intake manifold. If you shine a flashlight in behind the throttle body you should be able to see if there is any pink residue around the pump etc.
    Hope that helps
    Cheers
    Massboykie
    2016 Audi S5 Cab. - ECS Intake, K&N DI
    2016 Audi S6 - K&N DI, 10mm VCDS drop+12mm Spacers, Disc Italia+HPS 5.0
    Not to be forgotten...
    2016 Audi A3 2.0T, 2006 Audi A4 Avant 2.0T, 2002 Audi A6 2.7T, MKIV VR6 GTI & GLI, MKIII GLX & GL Jettas
    http://www.VAGLinks.com - 2000+ VAG Links!
    http://www.PlanetVAG.com - VAG Only Search Engine!
