Results 1 to 15 of 15
    Senior Member Two Rings MassS4B5's Avatar
    Jun 01 2007
    Stage 3 B5 S4
    east coast
    First Gen Q7 brakes
    Were the first gen Q7 brakes 18z? I put these on my car 6 years ago. Car has sat for the last 4 years and I want to replace front rotors. Not sure which to buy and what pads to use.
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Yes, all US Q7s had 18Zs.
    Go with '03 ML55 (345mm) rotors if you want a single-piece option. The center bore needs to be opened by 1mm. Otherwise Girodisc and JHM sell a 350mm 2pc rotor.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Jun 01 2007
    Stage 3 B5 S4
    east coast
    Thank you sir.
    Apr 21 2013
    Longmont, CO
    Not all Q7's had 18z, fyi.
    Veteran Member Four Rings Austonwerner4's Avatar
    Feb 01 2011
    00 S4 & 04 A8L
    MKE
    Quote Originally Posted by Audi_From_Hell View Post
    Yes they did in the US. Other than 2017+
    Single Turbo on it's Way
    PM me for 17z and 18z Caliper Needs
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    So you're saying V6 Q7s had 18Zs? I don't think so.
    Dec 16 2014
    Irvine, CA
    Quote Originally Posted by Zba View Post
    I just looked up part numbers on ETKA and Q7's only have 1 front brake setup, V6 included. So yes every car had 18Z.
    Nov 05 2009
    Denver
    That's surprising that Audi would put the bigger more expensive brake option on Q7s that don't need it, especially when the 17Z was available.
    Do you have the part numbers? What was the disc size for those rotors? Call me skeptical.
    Dec 10 2011
    CLT | MKE
    The base Q7 was still over 5,000 lbs. That is a lot of car to stop, and on a premium SUV buyers expect good brakes.
    -Hayden
    Dec 16 2014
    Irvine, CA
    Here you go. 350mm rotors.
    Nov 05 2009
    Denver
    Quote Originally Posted by LINDW4LL View Post
    True but all V6 Cayennes had 17Z calipers hence why I ask
    Nov 05 2009
    Denver
    Quote Originally Posted by Kaane View Post
    You are looking up a 2011, try a 2007
    Dec 16 2014
    Irvine, CA
    Come on... I checked all the years. Here is a 2007.
    Nov 05 2009
    Denver
    just trying to clarify as in Porsche land 2011s had completely new brakes/calipers so thanks.
    Feb 01 2011
    00 S4 & 04 A8L
    MKE
    17Z:
    Cayenne V6
    Touareg V6 and V8
    18Z:
    Cayenne S and Turbo
    Q7
    Touareg V10
