Results 1 to 7 of 7
    Junior Member Two Rings
    Nov 06 2013
    Baltimore MD
    Question Dreaded Front Control Arm Pinch Bolt Questions
    The control arm job went all right. The pinch bolts came out with PB Blaster, Map gas and lots of pounding with the BFH. One side took 2 hours and the other 3, don't give up. It was steel using the magnet test.
    Questions:
    1) I did not get a new pinch bolt for one side. The nearest available bolt was 4 hours round trip away. I used a quality Audi bolt and self locking nut left over from other jobs. Is this all right? Should I get the official bolt and replace the one I used?
    2) Why does this bolt set up? It is somewhat lose in the steering knuckle hole. It is tighter with the control arm ball joint pegs in place, but not that tight. Any ideas?
    Many thanks.
    John
    May 20 2010
    Crazy Ray's. Could've gone in, popped off the pinch bolt and locking nut, paid probably $1 for the bolt (plus the $2 to get in) and been done.
    Veteran Member Three Rings LA4's Avatar
    Jun 16 2013
    E39 540i, NA Miata
    Pennsylvania
    Why not just get a new pinch bolt now (you can order online or your local dealer so it won't be a 4-hour trip), pop your wheel off, and throw it in. The bolt you just put in should pop out easily.
    Sorry this isn't answering your question, I just don't see the point in having a loose bolt jiggling around in your suspension when you can easily solve the problem for $2. The peace of mind seems worth it even if it is unnecessary.
    1998.5 A4 Quattro 1.8TQM AEB
    Stage 1 GIAC, 710N DV, ECS Snub Mount, ECS SS Brake Lines, A8 Rotors, Bilstein Sports/H&R Springs
    Nov 06 2013
    Baltimore MD
    I should have mentioned that we were in upstate New York so Crazy Ray's was not an option. Even so, my experience with this bolt is that the junkyard version would be difficult to get out and ruin the bolt trying.
    2003 A4 1.8t 5 speed - my brother
    Nov 06 2013
    Baltimore MD
    Quote Originally Posted by LA4 View Post
    Okay, I will get the right bolt. Thanks,
    John
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    Quote Originally Posted by myfreeaudi View Post
    John
    Get a set of stainless steel m10x100 bolts and nuts and never have to worry about them again.
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Nov 06 2013
    Baltimore MD
    Quote Originally Posted by King_ View Post
    Thank you.
