Results 1 to 3 of 3
    Sep 21 2013
    Hamilton, NJ
    Engine is out of car what else could I check or change ? 2002 A6 2.7
    I am having my transmission replaced in my 2002 A6 2.7t. I will be replacing most coolant hoses and oil cooler hose. The mechanic says the turbo was dry inside n seemed to be ok. He did notice oil build up in the intercooler for both sides. What does that mean? I am also changing valve cover gasket. Mechanic says it might be good idea to change the starter since engine is out? Thoughts recommendations ?
    Thanks
    Tom
    Mar 10 2007
    Nemo S6 - for sale
    Sioux Falls, SD
    You could always disassemble the starter, clean it, check the brushes, or just have it tested. Unless it's been problematic, I wouldn't dig into it much.
    Spider-hose may be cracked and broken if it's OEM. I'd rebuild it with appropriate hoses vs buying an OEM replacement.
    Valve cover gaskets are known problems, so that's a good idea. Same with cam-plugs, half-moons, etc.
    Inspect the timing chain pads while you have the valve covers off and replace if necessary.
    Timing belt is a piece of cake at that point too. Hard not to give that a thought as well.
    '03 Nemo Blue S6, AirLift, Garage queen/spare.
    '00 A6 2.7t 6sp. Message me for parts requests
    '01 allroad 6sp, parts car. Message me for parts requests
    Sep 21 2013
    Hamilton, NJ
    Thanks for follow up. I replaced timing belt, water pump, at 125k miles. It has 160k miles now. Should be ok. Valve cover gasket leaking like crazy on both sides! Explains why I had to add oil all the time. Oil was all over the engine!
