Results 1 to 21 of 21
    Veteran Member Four Rings isles1's Avatar
    Oct 24 2012
    2013 S4, 2022 SQ5
    Nassau County, NY
    Angry How to completely remove drivers air vent B8.5
    Need to get the entire vent out. How to disconnect power wires? Need to get the vent out to realign slats. Impossible to do with vent dangling. Thanks!
    2022 SQ5, P+, Daytona Grey, S Sport, B&O, Black Optic, Black Badges, Dynamic Steering, OEM Sport Exhaust, Black/Black Dinamica.
    2013 S4, P+, DSG, Ice Silver Metallic, Black/Silver Alcantara, Sport Diff, B&O, 19" Peelers, Pilot Sport 4, SC Badges, Alu Kreuz, Endless MX72 brake pads, StopTech slotted rotors (front), APR Carbonio Stage I & II CAI. Winter shoes: OEM B8 S4 18" Wheels w/ Nokian Hakkapeliitta 7 Studless. Original owner; custom ordered.
    Aug 03 2013
    Renton, wa
    Pull the lower knee kick panel and you should see the connector for the lights on the vent. I did this recently to install/uninstall a P3 gauge from my old A4. You might be able to see it if you pull the side fuse panel as well
    '22 X3M - Stock...for now
    '14 S4 P+ DSG 034 Stage 2+ ECU/TCU 57.7/190, AWE Touring, MercRacing, AWE S-Flo, Stoptech STR-60 - Gone but not forgotten
    '14 A4 S-Line Sport Package 6MT - Totaled
    '12 Tiguan SEL 4MO.
    '03 Mustang Cobra "Stock"
    Oct 20 2008
    Denver
    ugh.
    Account Terminated Four Rings Pyromatic177's Avatar
    Aug 02 2015
    Corning NY
    I did it through the fuse access. It was a pain but I got it.
    Oct 24 2012
    2013 S4, 2022 SQ5
    Nassau County, NY
    Okay thanks. A project I did not anticipate.
    Oct 24 2012
    2013 S4, 2022 SQ5
    Nassau County, NY
    Quote Originally Posted by Pyromatic177 View Post
    I could prob unhook that way. Not sure I'd be able to reconnect it though. Do not want to pull knee plate. I can hear the rattles already.
    Oct 24 2012
    2013 S4, 2022 SQ5
    Nassau County, NY
    Quote Originally Posted by AudiTFSI3o3 View Post
    ugh.
    Yup. :(
    Apr 05 2016
    Portland, OR
    I realigned the flaps with the wire still attached.
    It was a bitch but totally worth it.
    Try angling the vent. It will align the silver piece better.
    Geoff
    Oct 24 2012
    2013 S4, 2022 SQ5
    Nassau County, NY
    The gecko will have to hold the slats until I find the patience to get those metal bars attached again. What a pain.
    Mar 21 2015
    No p3 in there? What were you doing with the vent?
    Apr 05 2016
    Portland, OR
    Looks like removing the P3.
    Geoff
    Oct 27 2009
    Miami, FL | Boone, NC
    Is there not a connector for the wires right at the vent? My B8 4 and B8.5 5 have one. It's less than a minute job to have the whole vent out of the dash.
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Mar 21 2015
    My 8.5 did not have one.
    Oct 24 2012
    2013 S4, 2022 SQ5
    Nassau County, NY
    Uninstalled P3 gauge. Was not poking around for fun.
    Apr 05 2016
    Portland, OR
    B8 does not have a wire to the vent.
    B8.5 does.
    It just controls the lighting on the dial.
    Geoff
    Oct 24 2012
    2013 S4, 2022 SQ5
    Nassau County, NY
    B8 does have wire. But it unclips from the vent itself.
    Oct 27 2009
    Strange that every B8 and B8.5 has a plug for the wire at the vent besides the B8.5 4.
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Jun 24 2008
    Encino, CA
    Anybody have any success assembling the vent slats and 2 metal brackets as functioning unit? Any tips?
    I was installing rear view camera and had to pull the dash apart. The vent just kinda fell apart into many pieces. I spend an hour trying to assemble it with no result.
    My slats are limp now , using "gecko fix" right now.
    Veteran Member Three Rings KRS Aaron's Avatar
    Jan 25 2011
    Evanston, IL
    I'm having trouble with the kick panel removal to do this. I took the 3 8mm bolts out and it won't come out for some reason. It will be difficult to get my P3 in and the suspension wiring if I can't do this.
    2024 RS6 Performance - Nogaro Blue
    2012 S4 - Nogaro Blue
    2017 Aston Martin V12 Vantage S - Onyx Black
    1994 BMW 850 CSi - Mauritius Blue
    M2 CS Racing
    Jun 24 2008
    Encino, CA
    Quote Originally Posted by KRS Aaron View Post
    You need to pull the panel towards you, after removing the 3 screws there are only clips remaining on top and bottom of panel
    Sep 11 2015
    2003%20VW%20Jetta%201.8T
    Western Mass
    My B8 had a connector right at the vent, like you said simple unplug and you have the entire vent out of the car. I have since upgraded to b8.5.......and will be looking to install my P3........I sure hope it is the same...
    2015 Mythos Black Pearl BO 6MT S4 P+ | 19" peelers | Nav | Carbon inlays | B&O | Sport Diff | Nappa
    Mods: 20% tint | EPL | OEM Audi Sport plate frame | HOEN fogs |ECS 10/12.5mm Spacers | Hardwired radar | ECS Trans insert | CTS intake | AWE Touring Exhaust - stock DPs | H&R OE Sports + Koni Shocks | Eurocode F&R Sway
